Changing dipped beam bulb. - MG-Rover.org Forums
post #1 of 10 (permalink) Old 12-11-2016, 21:05 Thread Starter
I'm sure I've changed this one before, but I can't seem to do it this time. 75 CDTi, drivers side lamp, pulled the connector off, and I thought there should have been one of those god awful fiddly spring clips to contend with, but I couldn't feel one in there. The bulb just seemed to twist/pull out. I have visions of removing the bumper and the headlamp unit just to change the bulb!
JensenHealey is offline
post #2 of 10 (permalink) Old 12-11-2016, 21:59
Car: MGZT pbt derv
My mk2 zt is just twist and pull, my mk1 has a spring clip.
Dave is offline
post #3 of 10 (permalink) Old 13-11-2016, 07:01 Thread Starter
Thanks Dave, both of my 75's have been Mk 2's, so I don't know where I got the spring clip idea from! Do the high beams use clips? Or maybe that's my wife's 45?
post #4 of 10 (permalink) Old 13-11-2016, 10:06
The Mk1 lamps use the awful wire clips. The Mk2 headlamp bulbs have a quarter turn bayonet fitting. These photos show examples.
Mk1 Headlamp
Mk2 Headlamp (non-HID)
Note that Mk1 models with HID/Xenon dipped lamps also use the same bayonet system as the later models.
Apparently, some later Mk1 non-HID models also use the bayonet type bulbs.
TC
T-Cut is offline
post #5 of 10 (permalink) Old 13-11-2016, 11:52 Thread Starter
Thanks TC, now I just need the hands of a 4 year old to get into the damn things!
post #6 of 10 (permalink) Old 13-11-2016, 15:17
Unfortunately they come with the attention span of a 4 year old so you still won't get it done!
post #7 of 10 (permalink) Old 13-11-2016, 16:26
We haven't seen this one for a while.
TC
T-Cut is offline
post #8 of 10 (permalink) Old 13-11-2016, 16:31
TC
No, there's been a crack down on child-labour over the last few years; that must be why.
post #9 of 10 (permalink) Old 13-11-2016, 17:10
And expert bulb swappers are getting hard to find.
TC
T-Cut is offline
post #10 of 10 (permalink) Old 13-11-2016, 19:45
Car: MGZT pbt derv
That sounds so wrong, did you know Rolf Harris at all??
Dave is offline
changing dipped beam bulb 600ed Rover 600 7 28-12-2012 12:56
Changing dipped beam bulb John Ridley MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 27-10-2010 23:22
Headlamp bulb - dipped beam swinny0 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 28 03-12-2009 18:52
dipped beam bulb geo752 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 8 06-12-2008 19:19
Dipped Beam bulb replace... Dom MG ZT / Rover 75 (Sponsored by Rimmer Bros) 23 07-01-2006 11:07
