A cure at last. - MG-Rover.org Forums
post #1 of 3 (permalink) Old 21-04-2012, 20:49 Thread Starter
Car: 75 2.0 CDTI Connie
A cure at last.
After moving my front tyres for the back and visa versa I noticed how badly the rear tyres had worn on the out side and were perfect and untouched on the inside I decided to have a little play with adjusting the rear toe in that to me was way to high, any way,s I adjusted the toe to practicably nothing and now I seem to have cured the problem of the rear end stepping out on mid corner man hole covers and also in a straight line the car feels very planted ( before a bit twitchy) so all in all I am pleased with myself. Also the steering wheel is still in the quarter to three position so I think I have the toe in equal on both sides.
Great.
renagade is offline
post #2 of 3 (permalink) Old 22-04-2012, 11:53
How did you measure the rear toe to practically nothing?
TC
T-Cut is online now
post #3 of 3 (permalink) Old 22-04-2012, 19:29
Of course you can't check the true behavior of the car if you are still running on those badly worn tyres.
As post above; how did you check the toe in/out ????
Colvert.
PS. And did you invent your forum name yourself ???
COLVERT is offline
Acne cure. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 25 03-07-2010 17:59
Cure possible misfire. Figo MG/R Modification & Tuning 1 08-12-2009 21:45
new clutch cure? marius v MG ZT / Rover 75 (Sponsored by Rimmer Bros) 11 04-09-2009 21:39
Someone please come up with a cure.... VOLVO-MASTER MGF and MGTF (Sponsored by MGFnTFBITZ) 27 05-10-2007 12:02
Ticking cure pointer Others 0 29-09-2004 20:17
