"Door open" dash warning light intermittently on - MG-Rover.org Forums
post #1 of 9 (permalink) Old 02-11-2006, 11:53 Thread Starter
Car: ZT 260 XPG
HI All,
This has just started happening. Is it a known fault?
All doors are shut........
Hmmmmmmmmmmmmmmm
tapped is offline
post #2 of 9 (permalink) Old 02-11-2006, 12:09
Car: MG ZTT
I get this from time to time on my Tourer.
I find that opening the tailgate using the remote switch
in the cabin, then closing the hatch again cures the fault.
Took alot of slamming doors to figure it out though !!!
craigdm is offline
post #3 of 9 (permalink) Old 02-11-2006, 12:20
Car: Rover 75 CDT Tourer
You may well find that it is the bonnet causing the problem and yes, it has come up on this forum. I find that mine somtimes flashed on and off intermittently when driving in high winds/ high speeds although the bonnet is in fact locked down. The bonnet is lifted by the wind just enough for the switch to break. Then as wind relaxes, the bonnet rests correctly restoring pressure to the switch and the light goes out.
I fiddled with the rubber stops and stuck a tiny block of rubber on the underside of the bonnet to ensure the switch stays pressed. I did consider disconnecting the wires to the switch and bridging them permanently, but resisted doing this.
EnEnGee is offline
post #4 of 9 (permalink) Old 02-11-2006, 12:23
Car: Rover 75 V8
Screw in a touch the two rubber stops on the bonnet slam panel. A false indication is often caused by the bonnet closing too high and therefore not fully depressing the switch you can see on the slam panel. Either that or the switch itself may be faulty
hth
Mike
MikeM is offline
post #5 of 9 (permalink) Old 02-11-2006, 12:50
7T5
Banned
Car: Classic Rover
is it saying door open or bonnet open/boot open? as on my 75 it tells you where the problem is, so to save hassle of messing around with bonnets/boots etc it could be the door and vice versa
7T5 is offline
post #6 of 9 (permalink) Old 02-11-2006, 13:08
Car: Rover 75 V8
On some models there are individual warnings, and on others just one
MikeM is offline
post #7 of 9 (permalink) Old 02-11-2006, 13:12 Thread Starter
Car: ZT 260 XPG
Thanks all, will have a look
It doesn't have message centre on mine so it just lets you know "something" is open!
Going on and off on bumpy roads so bonnet is probably likely I guess
tapped is offline
post #8 of 9 (permalink) Old 02-11-2006, 13:25
Car: Rover 75 Tourer
hi if its the bonnet the light on the dash comes on but the interieor light stays off if its a door switch the intereior light comes on as well
andrewmsteve is offline
post #9 of 9 (permalink) Old 02-11-2006, 14:01
Car: Rover 75 V8
Good point And one to remember
Mike
MikeM is offline
1996 416sli "Check Engine" warning light at.jazz MG ZS / Rover 45 & 400 0 06-04-2008 22:41
ZT Door Open Dash Light alexward MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 02-03-2008 17:47
Boot light and "boot open" indicator - R200 Vi garlum MG ZR / Rover 25, 200 & Streetwise 4 14-04-2006 18:19
03 ZS - Problem "Check Engine" Warning Light mrstinchcombe MG ZS / Rover 45 & 400 3 29-12-2005 17:58
Rover 75 1.8 T "Bulb out" warning light tapped MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 01-11-2005 17:26
