FBH odd behaviour - MG-Rover.org Forums
post #1 of 17 (permalink) Old 12-10-2009, 12:17 Thread Starter
Car: Rover 75 Tourer CDTi Connoisseur
Question FBH odd behaviour
It was cold one day last week - the car's temp sensor said 3.5C. When I got to work, and switched off the engine, I noticed the FBH was running. After about 15 seconds it switched off.
So, assume that it has worked correctly by activating itself due to the temp being below 5C.
However, it takes me 40 minutes to get to work, so the car would have got to operating temperature easily. Also, when I got to work, the temp was 7.5C. So why would the FBH still be operating when I got to work?
Is this normal behaviour? I always assumed that it would switch off once the engine got near operating temperature.
Al
al_dente is offline
post #2 of 17 (permalink) Old 13-10-2009, 10:11
Car: 75cdt +Ronbox+ FBH thanks to FrenchMike
Unhappy
If you do a "Search" for the FBH..........lot`s of info. Sounds like yours has the pcb problem that lots have. If it just starts on it own or when you open a door or the bonnet, then it gone west!
You will need to remove the power cable or it could run the battery down over night. Cost of a fix.........
pete
75pete is offline
post #3 of 17 (permalink) Old 30-11-2009, 12:28 Thread Starter
Pete, thanks for your reply - I've only just noticed it -I thought nobody had bothered!
Can you point me in the right direction to a thread re this PCB issue please.
The FBH seems to work in itself, however I would have expected it to switch off after the engine has warmed up, not stay running all the time. What is normal behaviour for the FBH?
BTW, I've just bought a new battery because the car wouldn't start this morning. I'm now wondering if the battery might be OK because the FBH is playing up!
Al
al_dente is offline
post #4 of 17 (permalink) Old 30-11-2009, 12:35
al it may or may not be true that the fbh switches off when temp is reached but i noticed last week that mine was still running at journey end , however it was only 3.5 outside at the time , the same happened this morning and journey end was 2.0 outside so it looks like it runs on outside temp and not coolant temp , something new i have learned methinks. Flyer.
FLYER is offline
post #5 of 17 (permalink) Old 30-11-2009, 13:35
Trader Supporter
Car: MG Express (Van)
See my post for webasto
ts autos is offline
post #6 of 17 (permalink) Old 02-12-2009, 22:37
Car: MG TF 135, MG ZS+ 120
I'm also having troubling with my FBH. It's doing the the common trick of turning on briefly when the car's unlocked or disturbed but not turning on via the remote or control panel in the armrest.
Had a slight glimmer of hope earlier. I checked all four fuses and since doing so, the unit starts as does the ATC but then cuts off within a second.
From what I read during numerous searches it looks like my FBH is shot but haven't been able to find any definite answers. I'm going to try the reset procedure (unplug the 6-pin then 2-pin plugs) and see how it goes.
I was chuffed when I saw the car had the FBH and bloody miffed when it didn't work!
LeRich is offline
post #7 of 17 (permalink) Old 02-12-2009, 22:41
Trader Supporter
plug in may help with t4 there is a diagnostic procedure on there
ts autos is offline
post #8 of 17 (permalink) Old 02-12-2009, 22:53
i had the very same thing on my first 75 fbh , the fan would start up when you lifted the bonnet then stop just as suddenly , needless to say the pcb had took a permenant hissy fit and it became a working or non working unit for the rest of its useless life aarrghh . flyer.
FLYER is offline
post #9 of 17 (permalink) Old 02-12-2009, 23:03
Car: 06 MG ZT CDTi
You guys are so lucky to have a FBH - I crave that warmth in winter mornings.
However I once had a Metro with the blower button jammed on, the elastic band that moved the vent distribution had snapped and the heater did not work so I had cold air blowing on my hand and face permanently - great on a winters morning.
I had to drive that thing with gloves, scarf and a balaclava as it was warmer outside.
stuartm1 is offline
post #10 of 17 (permalink) Old 02-12-2009, 23:09
Trader Supporter
Ive seen pick up pipes missing from the tank pump a couple of times can only assume they were dislodged when replacing or checking tank pump it's like a drinking straw from the top union down into the fuel a pipe within a pipe
ts autos is offline
post #11 of 17 (permalink) Old 02-12-2009, 23:31
Talking
i dont like to rub it in stu but i must say these last couple of days the 75 has been TOASTY hee hee. nite mate . flyer.
FLYER is offline
post #12 of 17 (permalink) Old 03-12-2009, 09:50
The "issue" with the pcb is that you can not just buy one. It appears that Webasto do not give out information etc and you have to book the car in for them to investigate. Others on here have done lots to find away around this but as far as i know.........no luck.
When i phoned, was told that it may cost 300 to fix! Now thats just a rip off!
If you have any luck, do please repost.
pete
75pete is offline
post #13 of 17 (permalink) Old 03-12-2009, 09:56
iirc keith alexander had the same problem when he was repairing FBHs for members in that he could,nt source the printed boards, sadly after being let down by some folk he no longer repairs them . Flyer.
FLYER is offline
post #14 of 17 (permalink) Old 06-12-2009, 16:16
Update: I pulled the plugs out to reset the FBH unit and now it behaves slightly differently. It activates upon unlocking/opening door as before but now when I tun the unit on, I can hear coolant being circulated which happens for longer then the unit fan stays on. Any ideas if this is a good or bad sign? I want it working!!
LeRich is offline
post #15 of 17 (permalink) Old 06-12-2009, 16:25
if it,s firing the fan should run , if you aint getting warm exhaust coming out of the exhaust pipe then it,s not firing up IMHO , flyer.
FLYER is offline
post #16 of 17 (permalink) Old 06-12-2009, 17:33
Cheers Flyer. The fan seems to run but not sure about any exhaust gases. Whereabouts is the exhaust pipe?
LeRich is offline
post #17 of 17 (permalink) Old 06-12-2009, 17:39
it,s a straight down pipe that comes out of the bottom of the unit , it,s stainless steel so you cant miss it , if the unit is running correctly it will be hot so dont grab it [ouch] , flyer.
FLYER is offline
Indicators and Brake lights - odd behaviour vyper 'R8' Rovers (aka Wedges!!) 4 11-10-2009 06:17
Odd alarm behaviour!! smeagol_vvc MGF and MGTF (Sponsored by MGFnTFBITZ) 9 19-08-2009 20:44
Odd engine behaviour after starting rich_b Diesel Forum! 10 19-02-2008 06:29
Traffic Announcements - odd behaviour CD413 PCK121 In-Car Audio, Entertainment, Sat Nav etc... 0 10-11-2007 15:06
Odd behaviour! SteveChilds MGF and MGTF (Sponsored by MGFnTFBITZ) 17 25-07-2006 07:38
