Heated seats not working - MG-Rover.org Forums
post #1 of 4 (permalink) Old 01-03-2017, 21:03 Thread Starter
Car: KV6 2.5 Petrol Conn SE
Hello guys again,
I've been searching threads on this topic for a while and didn't find the solution.
As i think this topic is not deeply solved and lots of owners have the problem, lets discuss it here.
I began research on dash buttons, they are glowing (lights are on).
My seats are not heating any more and today i removed the seat, found the connector for heating seats as i know (upper connector on the picture is from the dash towards the seat, other on splits power to back and bottom heater):
What should i expect on that connector and on dash buttons?
Any ideas how to trace the problem?
Regards,
Dragan
foghorn is offline
post #2 of 4 (permalink) Old 03-03-2017, 10:02
firstly you need to check for power to the plugs in the seats,, but the problem is most likely a break in the heating elements. so check continuity in the heater element side of the plugs.. . i retro fitted the heater elements and electic adjustment to my zt seats.(from a rover 75) and during fitting i did check continuity of the elements.. and actually saw the burnt out place in the element.. simply rejoined..
keith8000_0 is offline
post #3 of 4 (permalink) Old 09-03-2017, 18:09 Thread Starter
Thanks, checked it all and there was a problem with stat...
I removed the seat today and replaced the thermostat, now i have continuity and i checked the heater by connecting it to 12V supply it all works!
Strange thing now happens, when i check the supply voltage on the dash button(switch) i am not getting nothing similar to 12V between yellow and orange/white wires.
Any ideas? I checked the fuse 49 and it is ok...
How can i check the switch or wiring?
Regards
foghorn is offline
post #4 of 4 (permalink) Old 10-03-2017, 10:41
have you checked both fuses,, i think there is one in the in car fuse box, and a big one in the engine compartment fuse box..
Heated seats not working - sorted. criky18 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 06-06-2011 19:43
Heated seats not working Naffdave MG ZT / Rover 75 (Sponsored by Rimmer Bros) 8 16-03-2011 11:55
heated seats not working sc9ar MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 28-12-2007 04:01
heated seats not working terry2 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 22-12-2006 19:39
Heated Seats stopped working... FloatingRover MG ZS / Rover 45 & 400 3 29-05-2006 21:30
