Intercooler oil leak - MG-Rover.org Forums
post #1 of 4 (permalink) Old 02-06-2011, 20:01 Thread Starter
Car: Rover 75 2.0 CDT
Following a relatively long journey ~100 miles a couple of months ago, I noticed a little patch of oil on my driveway. I took my car to the local garage and they said that the oil came from the intercooler. They cleaned the residue off and said that it's such a small amount of oil that it's not worth replacing the intercooler until it gets much worse. There were no more oil leaks until today, when I went on another 100 mile trip (50-60 mph). I usually use my car for local driving to town etc without any problems.
What do you think is causing oil to leak only after long journeys?
Some forums have mentioned the crank case ventilation (CCV) system, and others have mentioned turbo seals and much scarier sounding stuff. The leak is coming from the bottom near side corner of the intercooler. What do you think?
BTW, 75s look great on sunny days.
Cheers,
Kris.
Rover 75 Kris is offline
post #2 of 4 (permalink) Old 02-06-2011, 20:08
Trader Supporter
Car: MG Express (Van)
Start with the easy stuff, PCV and o'rings, also check the rotor on the turbo, but they are a rare failure if regular servicing has been adhered to
www.tsautos.com
ts autos is offline
post #3 of 4 (permalink) Old 02-06-2011, 20:10
I'd suggest your renew the intercooler duct O-rings (eBay?). The originals swell and allow oil mist to cause wetting then dripping from the nearside of the matrix. Easy fix.
TC
TS -snap!
T-Cut is offline
post #4 of 4 (permalink) Old 02-06-2011, 20:17 Thread Starter
Thanks for those suggestions. Much appreciated.
diesel intercooler pipe leak CCM MG ZR / Rover 25, 200 & Streetwise 15 08-08-2011 16:48
oil leak, exhaust leak, engine noise stevexyg Diesel Forum! 2 16-02-2008 11:38
intercooler pipe leak chris_h MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 16-04-2007 11:00
Intercooler oil leak rover400gsi Diesel Forum! 9 13-04-2007 22:22
oil leak coolant leak and mis-fire - great! mtm81 MGF and MGTF (Sponsored by MGFnTFBITZ) 7 18-04-2006 08:46
