K-Seal anyone? - MG-Rover.org Forums
post #1 of 8 (permalink) Old 23-12-2009, 07:55 Thread Starter
Car: Rover 75 CDti Conne SE Saloon Silver/Gold 67K
K-Seal anyone?
When i bought my 1.8T (ultra low 25k) the cooling fan used stay on for few seconds after switched off (never did that on my old 1.8T)
Started loosing water
Couple months later cylinder head gasket blew to the tune of £550
It's been OK for few weeks until last night when the dreaded cooling fan came after i pulled in the drive
1/ I need to get some coolant/anti-freeze in quick (haven't got time to shopp around), what do Tesco or Halfords sell that's suitable
2/ I am also putting some K-Seal in (i can't afford another £550) - anyone had any experience with this - best methods?
The good news is when i drove it to work this morning and switched off - no fan blissssssssssssss
Chris-K is offline
post #2 of 8 (permalink) Old 23-12-2009, 08:06
Dumped a can of it in my 45 2 weeks ago after doing the head gasket. Seems to be working nicely, as the liners on mine had moved slightly.
Do read the can first which says shake vigoriously for 30sec before dumping it in, rather than the reverse then having to stir vigoriously !
igundwane is offline
post #3 of 8 (permalink) Old 23-12-2009, 08:22
Although not reccomended, I've used K Seal with great results recently.
As above, shake and add to the expansion tank making sure you don't overfill. Run engine, go for a drive.
post #4 of 8 (permalink) Old 23-12-2009, 09:51 Thread Starter
Great - thanks
any ideas on universal anti-freeze to top it up?
haven't looked yet, but i'm assuming coolant will have dropped
Chris-K is offline
post #5 of 8 (permalink) Old 23-12-2009, 09:54
Use only OAT based antifreeze, pink/orange in colour.
post #6 of 8 (permalink) Old 25-12-2009, 08:34
Car: Rover 75 2.5 v6
i put k seal in my 75 when i put ut back together after replacing the head gasket just to make sure//!
hasnt used drop of water in the 2k miles since
now if i could only get it to run again!!
twopoke is offline
post #7 of 8 (permalink) Old 25-12-2009, 09:50
Car: 2002 MG TF 160
You might find this an interesting read.
http://www.the75andztclub.co.uk/foru...ad.php?t=36562
Get a brew first it's a long thread.
Bob.
Bobert is offline
post #8 of 8 (permalink) Old 25-12-2009, 10:07
As for the antifreeze/anti corrosion inhibitor.
OAT is recommended. Its main claim to fame is longer service life. I have, from practical experience, got to the point, that I realize there is no way that I will get 4 years of uninterupted service from my cooling system, so for me, this feature is not worth paying for.
In stead I use normal antifreeze, which has served millions of people over the years fine, at a fraction of the cost.
I have recently had one engine opened, and it was clean as a whistle inside. Just remember that the service life of this type is about 2 years.
But you can use it with confidence.
As for the addition of k-seal. Go for it. I don't claim it will cure HGF, but it certainly sorted my leaks past the liners out.!
kaiser is offline
Looking for exterior door trim/seal/strip for MGF ("Outer waist seal"?) ohansen MGF and MGTF (Sponsored by MGFnTFBITZ) 2 02-12-2008 18:58
Rover 600 rubber door seal, can I use a Rover 400 rubber seal istead? megmeg Rover 600 10 28-06-2008 14:55
Rover 600 rubber door seal, can I use a Rover 400 rubber seal istead? megmeg Rover 800 0 19-05-2008 09:24
mg zr door seal and sunroof seal irish pa MG ZR / Rover 25, 200 & Streetwise 1 12-01-2008 14:49
