MG ZT Cdti Temp gauge to max, limp mode - MG-Rover.org Forums
post #1 of 3 (permalink) Old 09-05-2017, 17:33 Thread Starter
Hi guys,
I have MG ZT Cdti 2003
Cars in some kind of safe mode now as i cant go any faster than 15mph or so.
Temp gauge goes to the max as soon as i turn ignition on. (Checked with obd reader and it shows teperature over 100 with cold engine, no error codes)
No warning lights on dash.
Also it takes like 10-15secs to start the car.
Changed engine coolant sensor (the one in the centre of engine below inlet manifold, not sure if theres more than one)
Checked old one with tester at 20k and it seems to be working fine, also connected it straight from the ecu(to be sure theres nothing wrong with wires between ecu and sensor)
No succes so far
Thinking of buying second hand ecu but would it work straight away or itll need some coding?
Any ideas?
Any help would be much appreciated.
Thank you in advance.
Mike Lis is offline
post #2 of 3 (permalink) Old 09-05-2017, 17:55
I moved this thread to correct section.
post #3 of 3 (permalink) Old 09-05-2017, 20:40
Hi and welcome to the forum
I replied over on the Xpower forum.
James
Limp mode notlongnow MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 28-05-2013 20:48
Limp mode !! Driverr77 MGF and MGTF (Sponsored by MGFnTFBITZ) 12 04-04-2013 08:01
CDTI Ticking and limp mode problem gazzati MG ZT / Rover 75 (Sponsored by Rimmer Bros) 12 01-03-2011 20:11
Keeps going into limp mode stuart9976 MG ZR / Rover 25, 200 & Streetwise 6 13-01-2008 00:52
Temp gauge sender fail mode Avocet Metro / Rover 100 1 28-04-2007 17:35
