Minimum Brake disc thickness - MG-Rover.org Forums
post #1 of 7 (permalink) Old 03-10-2006, 17:38 Thread Starter
Anyone know what the minimum thickness is for the brake disks front and back?
And does this thickness include the gap in the middle of the disc, if you see what I mean?
Rear Pads are worn down and I don;t know whether I have to replace disks also.
There is a guy on greedbay selling mintex brake box kits really cheap, but I don't know if they are any good or not, but they are certainly cheaper including postage than the ordinary discs and pads I see on there.
Thanks.
myjess is offline
post #2 of 7 (permalink) Old 03-10-2006, 18:49
Car: Rover 75 v6 2.0 and MG ZR 105
I believe it is 19mm front , and only 8mm rear ! sounds thin for the rear, but thats what the ref says . The measurements are between outside faces , taken 10mm in from the edge .
chris75 is offline
post #3 of 7 (permalink) Old 03-10-2006, 19:30 Thread Starter
Thanks for that.
myjess is offline
post #4 of 7 (permalink) Old 04-10-2006, 07:49
Car: ZT 400 and a T4
It is printed on the disk as well you should be able to get a vernier on them without to much trouble.
Keith Alexander is offline
post #5 of 7 (permalink) Old 04-10-2006, 18:04 Thread Starter
You know, for the bother of grinding the outside edge and then getting the vernier in, I might as well go and buy a set!
Thanks.
myjess is offline
post #6 of 7 (permalink) Old 05-10-2006, 04:13
Disc Wear
Thanks.
I think a rough and ready 'rule of thumb' would be that if there is a healthy ridge at the outside edge then fit new discs.
It dosn't take me long at all to rub the ridge off with an orbital sander to measure the thickness and it gets rid of the rust. However you could use something like 2 feeler gauge blades of known thickness. one each side, and subtract that from total on the gauge, after all you are only trying to get a fairly rough idea of thickness and half a milimeter isn't going to be critical.
I also paint the hub part of the disc with smooth Hammerite. Looks much better than rust through the alloys !
crofts is offline
post #7 of 7 (permalink) Old 05-10-2006, 15:32 Thread Starter
Thanks, but I'm gonna gpo with the mintex discs and pads I think.
myjess is offline
vvc Minimum head thickness iparkes MG / Rover Related Chat - up to 2005 6 04-11-2008 21:04
Minimum Brake disc thickness! CEJM MG ZR / Rover 25, 200 & Streetwise 3 25-02-2008 19:49
new brake disc VW Camper MGF and MGTF (Sponsored by MGFnTFBITZ) 8 21-02-2008 15:35
R220 262mm brake disc query - Strange cut on lip of 1 disc. G13SJC 'R8' Rovers (aka Wedges!!) 21 11-03-2006 21:19
Brake Disc Minimum Thickness 218is 362 MG ZR / Rover 25, 200 & Streetwise 2 24-06-2005 12:01
