Oil leak near intercooler? - MG-Rover.org Forums
post #1 of 9 (permalink) Old 18-11-2011, 18:41 Thread Starter
Car: 2004 MG ZT+ CDTI
Took the bumper off today and spotted this...
Large oily build-up around the bottom of the intercooler, but ONLY on the passenger side.
O-Rings were done ~25k ago, but they were ok when changed.
Is my intercooler shot?
Jakg is offline
post #2 of 9 (permalink) Old 18-11-2011, 20:14
Trader Supporter
Car: MG Express (Van)
If your intercooler was damaged you'd be permanently down on power as the turbo won't be able to pressurise the system, check your o/rings and the elbow for alignment then clean off the crud as that could be residue from the previous leakage.
www.tsautos.com
ts autos is offline
post #3 of 9 (permalink) Old 18-11-2011, 20:15 Thread Starter
O-Rings were fine...
I am down on power, fwiw... 153hp with a Synergy, EGR Bypass, Decat etc, whereas other owners get 165+
Jakg is offline
post #4 of 9 (permalink) Old 18-11-2011, 20:21
Trader Supporter
Any black smoke evident on rev's
www.tsautos.com
ts autos is offline
post #5 of 9 (permalink) Old 18-11-2011, 20:35 Thread Starter
Under load, in third gear, yes... Idling, no.
Jakg is offline
post #6 of 9 (permalink) Old 25-11-2011, 19:26 Thread Starter
Bump.......
Jakg is offline
post #7 of 9 (permalink) Old 25-11-2011, 19:50
Car: Rover 600
When the o-rings were replaced did you use viton seals? also did you make sure it was pushed home correctly as it can be quite difficult. Apart from any wear/cracking/puncture in the hoses I can only see the seals causing this fault. Cheers Paul.
Bikerogg is offline
post #8 of 9 (permalink) Old 26-11-2011, 18:17
Originally Posted by Jakg View Post
Bump.......
As TSAUTOS said, clean off the oil. If you check it then it won't be long before you'll see exactly where the leak is from.
If it was a pinhole in the rad then araldite will seal it easily.
Otherwise the seals are shot or moved and need fixing.
Colvert.
COLVERT is offline
post #9 of 9 (permalink) Old 26-11-2011, 21:06
Car: 75 CDT Tourer Conn SE
I had a similar issue.
It turned out that when the top pipe was back in place, lined up with the bolthole it was not fully pushed in and still leaking.
I cut the hole in the pipe so it became a slot instead and used a large washer when refitting. It only sits 5 or 6 mm deeper but cured my issue.
Good luck
RoverInTheWoods is offline
diesel intercooler pipe leak CCM MG ZR / Rover 25, 200 & Streetwise 15 08-08-2011 16:48
Intercooler oil leak Rover 75 Kris MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 02-06-2011 20:17
intercooler pipe leak chris_h MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 16-04-2007 11:00
Intercooler oil leak rover400gsi Diesel Forum! 9 13-04-2007 22:22
oil leak coolant leak and mis-fire - great! mtm81 MGF and MGTF (Sponsored by MGFnTFBITZ) 7 18-04-2006 08:46
