Play in wheel/handbrake? - MG-Rover.org Forums
post #1 of 5 (permalink) Old 06-03-2017, 07:48 Thread Starter
Following on from my spare wheel request, I noticed that there's about 10mm of rotational free-play on each rear wheel when the hand brake is on. Is that normal?
JensenHealey is offline
post #2 of 5 (permalink) Old 06-03-2017, 09:15
Mine has been like that since I got it and has passed MOT OK, so I guess that it is normal and due to the handbrake inner drum and shoe setup. It does lock the wheels.
Mike T is offline
post #3 of 5 (permalink) Old 06-03-2017, 09:35
They all do that! In this case it's actually true. Nobody has yet come up with a really convincing explanation of why the brake-locked drum can rotate a degree or two, but they do. I'm of the opinion it's a simple design fault in the shoe/adjuster/pivot mechanism.
TC
T-Cut is offline
post #4 of 5 (permalink) Old 06-03-2017, 10:11 Thread Starter
Thanks chaps, that's put my mind at ease.
On a slightly different point, the reason I was asking for a new spare wheel was that my existing spare is a different size to the other four. The reason I needed to use the spare was that the left rear stopped holding air quite suddenly.
Now, when I took the wheel off and inspected it there was no obvious damage, and the rim seemed ok, but there was a very odd wear pattern. The outer edge was more worn than the rest of the tyre, but only around about 30% of the circumference! I've never seen that before, and I'm not sure how it's even possible, Any thoughts?
Actually,one thing has just occurred to me- manufacturing defect?
post #5 of 5 (permalink) Old 06-03-2017, 11:07
Uneven circumferential wear may be due to tyre imbalance or a binding brake shoe/pad. Your best bet would be to get advice from a good tyre fitting depot.
TC
T-Cut is offline
Play in handbrake. Smitch76 MGF and MGTF (Sponsored by MGFnTFBITZ) 1 05-04-2013 13:18
Play in wheel jac11 MGF and MGTF (Sponsored by MGFnTFBITZ) 3 20-01-2013 17:44
Play in wheel kristianhitchen MGF and MGTF (Sponsored by MGFnTFBITZ) 8 05-10-2011 13:13
Handbrake play Freebird MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 10-02-2010 07:22
play in handbrake - light on jimmysutt MGF and MGTF (Sponsored by MGFnTFBITZ) 7 12-06-2007 15:21
