preparations for new head gasket K- engine 1.8, 2000 model sedan. - MG-Rover.org Forums
post #1 of 6 (permalink) Old 21-07-2010, 21:41 Thread Starter
Question preparations for new head gasket K- engine 1.8, 2000 model sedan.
Hi.
I have bought a full gasket kit with stretch bolts on the Ebay.(The "new" gaskets). My friend is a professional mechanic, but has never fixed a Rover 75. I have the Chilton repair manual. Can someone tell me what he should check/ be looking for when it comes to motor damages of any kind /check out during the overhaul. Not much knowledge in my country(Norway) when it comes to Rover 75. The car is loosing water and gets hot. No heavy sounds from the engine, but there is a loss in power/ not all cylinders are working.
I love this beautiful car and I want it back on the road.
I will be very grateful for tips/answers.
Regards Martin, Oslo, Norway
øksefisk2 is offline
post #2 of 6 (permalink) Old 21-07-2010, 21:50
Car: MGF Trophy 160, MGB.
If possible, get him to pressure test the cooling system first to find out where the coolant loss is. Often it's the water pump so might be a good idea to get one first. No point in replacing the HG without first fixing the leak though.
kelvin is offline
post #3 of 6 (permalink) Old 21-07-2010, 21:54
Replace the water pump, timeing belt, thermostat,and inlet manifold gasket at the same time.
Check the highet of the cylinder liners when the head is off (should be higher than the block by 1-3 thou)
Also check that the radiator fan is working as a faulty one will soon destroy the head gasket.
pernix is offline
post #4 of 6 (permalink) Old 21-07-2010, 22:10 Thread Starter
Prep for H gasket
Hi.
Thank you so much.
Shall I by the water pump with the evaporation chamber or not?.
Regards Martin
post #5 of 6 (permalink) Old 21-07-2010, 22:12 Thread Starter
Hi. Thanks for answering.
Shall I buy a water pump with or without a avaporation chamber?
Regards Martin
post #6 of 6 (permalink) Old 21-07-2010, 22:22
Trader Supporter
Car: MG Express (Van)
Regards Martin
It's doesn't make any difference,
www.tsautos.com
ts autos is offline
is there a rover/mg model out there that doesn't have the head gasket problems? snakenath MG ZR / Rover 25, 200 & Streetwise 28 16-03-2011 20:16
rover 25 1.4 16v 2000 new head gasket, dvd player, 2 sets of alloys cm1989 For Sale 3 20-08-2009 10:07
Rover 620ti - 1997.5 Model Year - Low Compression after head gasket change steve hawkins Rover 600 29 02-05-2007 15:58
Rover 25i 2000 - Cylinder head gasket problem i think smfcpaisley Others 3 24-10-2005 20:00
ROver 1.4 8V 14k2 head gasket :-( Model? krionix 'R8' Rovers (aka Wedges!!) 11 21-04-2005 13:00
