Rough running 75 CDTI Tourer - MG-Rover.org Forums
post #1 of 4 (permalink) Old 27-04-2017, 10:36 Thread Starter
I am getting a bit desperate with my CDTI. I thought it would be a silent and smooth car but now after five moths ownership I'm getting tired of the overall roughness of the ride. The whole car shakes and vibrates especially at idle and on the move it is hard to hear the radio over the engine and road noises. This is very annoying because some of the fellow owners here write that the car should really be quite refined and smooth.
I have analysed the engine with TOAF and according to it there should not be any faults. The engine seem to work well apart from a slight jerking at lower speed especially when cold. The crank pulley and DMF do not cause any special noises as far as I can judge things.The rear muffler has been changed to some aftermarket one but it is not the exhaust sound which is the problem. It's more like the engine was leaning straight on the body. I have inspected all the mounting rubbers and they seem to be ok. Also all the original sound deadening material is still there so there should not be any extra road or other noises caused by that. Do I have some false expectations about the smoothness of a Rover 75 or is there something wrong with the car? Either way, it is a much more louder and harsher car than e.g. my previous Citroen C5 diesel. Any thoughts about the issue?
mytf is offline
post #2 of 4 (permalink) Old 30-04-2017, 22:21
Car: MG ZT-T CDTi+ 135/ Mini Cooper 1998 Classic /Volvo XC60 R Design 2010
Exhaust dropped and resting on cross supports?
zony is offline
post #3 of 4 (permalink) Old 18-05-2017, 09:01
Car: MG ZT
It sounds like the lower engine mount to me, get the car on ramps or axle stands, chock the back wheels with handbrake on, remove the under tray if your car as one, with the car in neutral remove the lower engine mount and test it, the whole process should take no longer that 30 minutes.
At the same time check the lower wish bone bushes to see if they are in good condition or not.
Replace any and all if need be Skicon
Skicon is offline
post #4 of 4 (permalink) Old 20-05-2017, 22:38
Came across a great site with a wealth of info re running the Diesel engines in our cars -synergytuning.co.uk
genpk is offline
Sudden onset random rough idle/ rough running issues onepostwonder Diesel Forum! 2 01-03-2016 13:28
ZR running rough clydesmith90 MG ZR / Rover 25, 200 & Streetwise 10 19-08-2012 21:41
rough running 1.4 spudspeirs MG ZS / Rover 45 & 400 8 06-11-2011 23:28
Rough running problems. Cdti blinkinink MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 27-08-2011 17:42
Rough running Leaver32 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 26-05-2010 22:23
