Rough running problems. Cdti - MG-Rover.org Forums
post #1 of 18 (permalink) Old 24-08-2011, 19:06 Thread Starter
Car: '04 MG ZT-T+ Cdti 135
Send a message via MSN to blinkinink
Seems to be a common question this one.
But mine seems a bit different.
Several things really.
Main problem is coughing and 'missing', although I realise a diesel doesn't literally miss like a petrol.
I've seen posts about leakback etc, and my car has done 175k.
No receipts for injectors in its history.
Was fine when I picked it up 3k miles ago. And had been fine till now.
Has synergy 2 and pierberg maf fitted by me. Was fine on that too. And running great for a while.
Went to Norwich (300 miles) an back last week.
I broke down 2 times on the way there. Car started to cough and splutter and then cut out on the 3rd lane of the m25.....
Engine warning light came on.
Car started again but I didn't dare run it with light on. Left it 5 mins and had a fiddle about under the bonnet.
Eventually tried it again and the light went out. So I carried on my journey.
Spluttering on and off persists. Sometimes cuts out at idle. Always starts though.
And always starts fine from cold too.
Have turned the power section of synergy 2 off now and no really made much difference to splutter.
blinkinink is offline
post #2 of 18 (permalink) Old 24-08-2011, 19:23
Car: Vauxhall Astra 1.9 CDTI SRi 150 ps + x/pk 10 reg + Vauxhall Meriva 1.6 16v MPV 57 reg.ZT CDTI sold!!
Thumbs up
Hi the first thing i would do is disconnect the synergy box completely (remove it) your car will not run properly with the pierberg maf connected but if you have an old Bosch maf fit it or just disconnect it and the ECU will run in default mode, the following are things to check,
1 Plenum drain for water ingress, ECU wet.
2 Fuel pumps are running, under bonnet and intank.
3 Fuel filter, when was it last changed.
4 Leakback test done, this will say if any of the injectors are faultily.
5 EGR, either clean or bypass.
6 PCV, either clean or replace with filterless type.
This is just a few things to check as there are others but only if the problem persists, Steve
top mg zt is offline
post #3 of 18 (permalink) Old 24-08-2011, 20:01 Thread Starter
Ok
Well I've already done:
Pcv clean and change to filterless element.
Egr bypass and intake clean.
Has just had fill service by me with new fuel filter included.
I do have the original maf. So will fit that back and see what happens.
I currently have the power turned off. Its just the maf section Working.
Will perform leakback as soon as I have the stuff needed to do it.
post #4 of 18 (permalink) Old 24-08-2011, 20:02 Thread Starter
Also it's a 2004 with a single pump which had already been replaced by the last owner apparently just before I bought it.
post #5 of 18 (permalink) Old 24-08-2011, 20:50
Car: 2013 MG 3 VTI Tech Style
First I have heard of a single pump set up being replaced tbh, are you certain it only has the single pump, have you got a picture of the engine bay?
Simon
simcor is offline
post #6 of 18 (permalink) Old 24-08-2011, 22:21 Thread Starter
No I'm not certain it is as I am not familiar with the differences.
But I can find out.
post #7 of 18 (permalink) Old 25-08-2011, 09:09
Car: Connoisseur SE CDT
Try the connections as per this on Rover Rons site http://tuning-diesels.com/75Zt/R75serv.htm#CF
roverrattles is offline
post #8 of 18 (permalink) Old 25-08-2011, 14:00 Thread Starter
Yeah, i've been through some of them.
Its like one big trial and error mission!!! lol
post #9 of 18 (permalink) Old 25-08-2011, 15:42
Car: MG ZT-T CDTi+ 135/ Mini Cooper 1998 Classic /Volvo XC60 R Design 2010
With all this rain we've been having , I would also check your plenum chambers. Are they dry?
zony is offline
post #10 of 18 (permalink) Old 26-08-2011, 15:19 Thread Starter
Ok so got a new symptom.
Engine has cut out twice in the last week. Both times producing engine check/warning light. The one with the exclamation mark.
First time light went out pretty quick and the engine started straight away anyway.
This time cut out coming up to a roundabout. Eml came on. Started straight away.
But the light is still on....
What should I do..?
post #11 of 18 (permalink) Old 26-08-2011, 15:52
Car: Rover 75 CDT Con. SE. Bike: Norton Commando Roadster 750 Mk V
Have you tried running with the MAF disconnected yet?
Mike
Mike Noc is offline
post #12 of 18 (permalink) Old 26-08-2011, 16:24 Thread Starter
No, not had the chance to get the air cover off yet. been working.
post #13 of 18 (permalink) Old 26-08-2011, 16:55 Thread Starter
Ok. So unplugged the maf sensor via the connection on the synergy connector. Power section is turned off too. So it's now running free of the synergy and maf....
Eml went out once disconnected.
And have run it home from the gym and its been fine so far.
But, with that in mind. the original symptoms have been erratic at best. Sometimes its fine.
So I will have to run it with the maf and synergy disconnected for a little while to see if any of the symptoms appear in the meantime.
I'd be surprised if the pierberg maf is faulty....?! It was used, but only 3 months old.
I bought the synergy 2 second hand mind and its the older type with the 3 maf and power sections...not 2.
Worth sending it to Rover ron for a checkup?
post #14 of 18 (permalink) Old 26-08-2011, 21:58
Thumbs up
I would say your problem is with your tuning kit, i had the same one fitted and had some problems and mine was new, removed and no problems at all.
I think that the problem with them is the wiring and plug connections gives intermittent signals which gives erratic running, you are not first to have problems with these boxes, my advice would be for you to go back to standard and if you wish for more power etc go for a remap, Steve
post #15 of 18 (permalink) Old 27-08-2011, 14:28
Car: 75 conn cdt 2001
I had same sort of symptoms on my cdt and it turned out to be fuel rail pressure sensor connections were dirty . just cleaned them n all fine . well worth a look i'd say n cheap fix 0000 . hth .
Rich
rich-i-wish is offline
post #16 of 18 (permalink) Old 27-08-2011, 14:35
Car: MG ZT 160+ 2.5 V6
By no means an expert but I had similar symptoms on a previous car and it turned out to be a split HT cable. Mine was visibly sparking in the dark. Once changed, it was back to normal idle etc.
Worth a look.
Jamturbo is offline
post #17 of 18 (permalink) Old 27-08-2011, 15:10 Thread Starter
Originally Posted by Jamturbo View Post
Worth a look.
Tis a diesel. No spark plugs. But thanks for the input.
As for the fuel pressure sensor, may well be that. Will buy some proper contact cleaner and do that.
Has been good since I disconnected my maf and then plugged synergy back in with power off. Might have been a dodgy connection There.
It has also been "over revving" when I let off the throttle?
Like when I go to change gear and dip the clutch and let off the throttle, the revs hold for a second or two, and sometimes actually increase before dropping?
post #18 of 18 (permalink) Old 27-08-2011, 17:42
Worth a squirt. As they say ,lol. good luck !!!
ZT CDTI Fuel pump problems UBP continuously running MaccaOZ MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 01-06-2009 23:52
220 GSi, Extremely Rough Running Problems vikingpower 'R8' Rovers (aka Wedges!!) 2 01-06-2009 10:22
Still running rough - swordy21 Rover 800 3 24-03-2008 15:53
Rough Running BIGGUNS Coupe 3 24-08-2007 18:32
R416 Problems with Rough Running... Funkyfin2000 MG ZS / Rover 45 & 400 8 30-06-2006 10:17
