rover 1.8 75 fuel tank size - MG-Rover.org Forums
post #1 of 8 (permalink) Old 04-06-2010, 16:15 Thread Starter
Smile rover 1.8 75 fuel tank size
does anyone know what capacity fuel tanks these cars have? just trying to work out how good they are on fuel, as when i got the car it had a full tank, i've done 100 mile and its down to 3/4. doesn't seem to bad to be honest, plus its an automatic and i've had the aircon going as weather has been fantastic!!!!
hbk123 is offline
post #2 of 8 (permalink) Old 04-06-2010, 16:23
Car: Honda Odyssey EX-L
I think the tank is the same in all petrol versions, about 68 litres. Dunno about the diesels or the V8's tho.
Edd
Mr Edd is offline
post #3 of 8 (permalink) Old 04-06-2010, 20:00
All models have the same capacity fuel tank, which is rated as 64.8 litres or 14.25 gallons.
Don't rely on the computed fuel consumption if you have the Highline system. It's optimistic by default, but can be adjusted to give an accurate figure after you've given it some real world data using brim to brim consumption figures.
TC
T-Cut is offline
post #4 of 8 (permalink) Old 04-06-2010, 20:11
Car: 2013 MG 3 VTI Tech Style
Personally I find my MPG computer pretty accurate on my ZT CDTI.
It was showing around 42MPG the other day and when I filled up and worked out my MPG it was actually over 43MPG so the computer was actually showing less, my correction factor is set at the default value of 1000 iirc.
Simon
simcor is offline
post #5 of 8 (permalink) Old 04-06-2010, 20:17
Yes, some will and many won't be very accurate. That's why the adjustment routine is available in Diagnostic mode.
TC
T-Cut is offline
post #6 of 8 (permalink) Old 04-06-2010, 22:34
Simon
When the injectors start to wear does the computer start to tell you fibs ??????
COLVERT is offline
post #7 of 8 (permalink) Old 05-06-2010, 07:17
I actually found this adjustment section the other day and didn't understand how it worked.
So how do you adjust it? Yes I know by pressing the reset button but what is the calculations?
Edd <just being a numpty>
Mr Edd is offline
post #8 of 8 (permalink) Old 05-06-2010, 08:37
No idea Johnny boy, however I do according to Terry's T4 that my injector values are okay so hopefully I wont see any injector issues fingers crossed.
Simon
simcor is offline
fuel tank size? Deano MGF and MGTF (Sponsored by MGFnTFBITZ) 34 01-03-2013 06:39
Fuel tank size - mk1 Colin_NI MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 10-05-2009 16:25
75 CDT 2004 full tank range? MPG etc? Has anyone done the same; results? Tank size? Kú150N MG ZT / Rover 75 (Sponsored by Rimmer Bros) 30 25-03-2008 21:22
Rover 114 fuel tank size fetler Metro / Rover 100 5 19-07-2004 12:00
Rover 200 Sdi Fuel Tank Size ? swebb MG ZR / Rover 25, 200 & Streetwise 4 25-10-2002 20:34
