Rover 75 Club - New Instrument pack/trip computer retro fit. Help needed. - MG-Rover.org Forums
post #1 of 112 (permalink) Old 31-10-2005, 20:36 Thread Starter
I've just bought a new instrument pack for my 75. Its a club model and is fitted with the basic clocks with warning light display. The new clocks have the lcd dot matrix display at the top.
I fitted them this morning and all the pictorial warnings seem to be showing correctly in the display (glow plugs, doors open etc). The rev counter, speedo, fuel, trip, coolant temp and outside temp gauges are working fine. My only problem is that the mileage is showing as 999999. On replacing my old clocks the mileage goes back to normal. Also, the auto gearbox "selected gear" display is active on the new one, my old pack has this but it is not illuminated.
Can anybody give me any pointers? Do I need to have the new clocks coded to my car with testbook? My workshop manual doesn't say anything about this.
Thanks in advance.
Ross R75 is offline
post #2 of 112 (permalink) Old 31-10-2005, 21:20
Car: MG ZT 180 SE in XPG.
Can you explain what you mean about auto selected gear display please? I assume your car is an auto? Are the old clocks correct or the new one?
The i pack is supposed to be coded to the car. The i pack holds the mileage data and a backup of the mileage is stored on your Lighting control module. A specialist digital mileage frigger should be able to sort this. Although i suspect once coded to the car this would possibly right itself.
Only problem is im not sure how many times an i pack can be coded.
MattL is offline
post #3 of 112 (permalink) Old 31-10-2005, 23:00 Thread Starter
Car is a manual 2.0 CDT. Transmission display doesn't light up on my old i pack. Going to take it to the dealer and have a quiet word with the boys through the back, see if they'll stick it on testbook for me.
Ross R75 is offline
post #4 of 112 (permalink) Old 01-11-2005, 05:01
Good luck!
Alex30013k is offline
post #5 of 112 (permalink) Old 01-11-2005, 06:48
Car: 75 Conn SE Auto CDT
Pretty sure this will have to be set up at a dealers
madone is offline
post #6 of 112 (permalink) Old 01-11-2005, 15:52 Thread Starter
After reading the system description on RAVE. The i pack confirms it has the same VIN as the light control unit before it will show a mileage. Need to get the VIN changed at the dealers.
Ross R75 is offline
post #7 of 112 (permalink) Old 01-11-2005, 15:59
Just as i thought then. I love being right.
MattL is offline
post #8 of 112 (permalink) Old 01-11-2005, 16:01
Car: 98 Vectra 1.8 Arctic (sorry!)
lol... smart ar5e
CRNeo is offline
post #9 of 112 (permalink) Old 01-11-2005, 16:04
Originally Posted by CRNeo
lol... smart ar5e
I was actually being modest.
MattL is offline
post #10 of 112 (permalink) Old 01-11-2005, 16:21
Car: bippety-boppety-boo!
So does this mean (if I can find one) that I can fit the instrument pack with the clevertrevor graphic display to mine too without major surgery, just a visit to the dealer to get it to shake hands with the control module?
If so, might be time to start hunting!
V8King is offline
post #11 of 112 (permalink) Old 01-11-2005, 16:32
As long as they can reflash the i pack then yes. Pretty sure they can but thats the one thing im not sure about, i know they can do new ones but im not sure about a used item.
MattL is offline
post #12 of 112 (permalink) Old 01-11-2005, 18:00 Thread Starter
If its a standard EEPROM they'll be able to reflash it. I'd be amazed if it was anything different.
Ross R75 is offline
post #13 of 112 (permalink) Old 04-11-2005, 09:40
instrument pack problem
Just to confirm a new pack has to be reprogrammed using the diagnostic equipment "T4" at your rover dealer. They need to download the information from your old instrument pack, install the new pack and then upload all of the information.
The new pack is then coded by the chassis number to the vehicle and to my knowledge cant be changed there after, therefor you are unable to reuse second hand instrument packs.
hope this helps
rvr garage is offline
post #14 of 112 (permalink) Old 04-11-2005, 11:49 Thread Starter
hope this helps
I've spoken to my Rover dealer about this. The instrument pack can be re-programmed as its a standard EEPROM chip, the same as your ECU memory. There is no way of making an EEPROM chip an once only chip, if it can be written once, it can be written again.
Ross R75 is offline
post #15 of 112 (permalink) Old 04-11-2005, 12:11
Car: Rover 75 V8
Interesting. All that I have been told and read in the past said that a s/h 75 pack couldn't be re-programmed to a different car, and I guess there will be security implications if they can.
Please keep us informed as to when you get the one you have reprogrammed.
Mike
MikeM is offline
post #16 of 112 (permalink) Old 04-11-2005, 12:13
When are you having it done then Ross? Are you going to let us know how you get on at the dealer?
The EEPROM can always be reflashed with a chip programmer but if its done via diagnostics port then it is probably being flashed via another device which CAN have a software counter in it, thus making it alot harder for you to recode things.
MattL is offline
post #17 of 112 (permalink) Old 04-11-2005, 12:27
In response to Ross 75, appologies for the wrong info in my last thread.
I just had had a chat with one of the techys in the workshop. Ross 75 is correct that a second hand instrument pack can be used. The Techy said that there is only one problem, the mileage is something that can not be decreased so if the instrument pack you are using has come from a car with higher mileage you cant alter it to your own lower mileage.
If this is the case and you can find a used lower mileage instrument pack then thats great because from memory a new one is several hundred quid.
post #18 of 112 (permalink) Old 03-12-2005, 21:29
Did you get it to work in the end?
post #19 of 112 (permalink) Old 29-01-2006, 09:44
Car: Rover 75 2.5KV6 manual
Originally Posted by jamescj
A bit of a challenge - but that is part of the fun Has anyone any updates on this??? RossR75??
A bit of a challenge sounds about right. I'd love to upgrade to the trip computer at some stage. I follow your progress with interest.
If you do the work yourself, take some snap shots while you're at it.
< N I C K > is offline
post #20 of 112 (permalink) Old 29-01-2006, 15:18
Following this thread with great interest!
Can the new display show which door is open, or just "a" door?
Keep us posted on your progress Chris, if you can pull this off, I'll be buying one on ebay tomorrow
(er, well, whenever you do confirm its recalibrated to correct mileage and new stalk controls mpg etc!)
RichK is offline
MG ZT-T Instrument panel/trip computer failure mlpoulton MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 14-02-2012 02:19
Trafficmaster Retro-fit to Driver's Intelligence Pack Equipped 75 & MG ZT Models Dr Dave How Do I - Answers To Common Problems. 165 04-10-2010 14:19
Retro fit Trip Computer Tomcesca MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 02-02-2007 22:13
retro fitting trip computer chilljohn MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 24-07-2006 15:03
R75 Trip computer/Drivers Intelligence pack johnny MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 18-05-2004 12:06
