still got cold heaters... please help - MG-Rover.org Forums
  • 1 Post By russr
post #1 of 14 (permalink) Old 25-01-2012, 17:35 Thread Starter
Car: MK2 ZR 160, MK2 ZS 120, MK1 ZR 120 monogram, MK2 ZT 190
ok so i got told this could be a problem with the heater matrix so i took it out, cleaned it thoroughly until it was getting hot all over and put it back in
still cold.....
thought it may be an airlock so continued to bleed system through and still nothing.... until....whilst engine was running i undid the cap to see how much pressure was in the system and low and behold... HEAT!
But when u tighten the cap back on it goes cool again, i am completely stumped...
also just tried the ATC diagnostics check and came up with no fault codes
any help would be greatly appreciated
its a 2.5 v6 2005 ZT 190
Nick
nickc09 is offline
post #2 of 14 (permalink) Old 06-11-2016, 16:43
Car: MGF 1.8 VVC Nightfire and MGZTT 190 Firefrost
still cold.....
Nick
Hi did you resolve this problem, and if so I have the same issue. Please tell me how ??
Sent from my SM-G925F using Tapatalk
russr is offline
post #3 of 14 (permalink) Old 06-11-2016, 16:56
Car: F. Fiesta 1.6 ECOnetic
SAAB valve?
david.anthony is offline
post #4 of 14 (permalink) Old 06-11-2016, 19:22
Can you describe exactly what happens in your case. The OP's situation seems rather unusual to me and I'm wondering if your issue is exactly the same. Does the header tank cap figure in the way things work or don't work? It's a fascinating problem if it does. Which engine do you have?
TC
T-Cut is offline
post #5 of 14 (permalink) Old 07-11-2016, 12:19
I have the 2.5 V6 190. I cannot get heat from the heaters. Experience a little residual heat when the car has been running for a while. The header tank is holding the water at the correct level. Have had stat changed, water pump and cam belts done, had the heater matrix removed and flushed out. 1st frost on car took 20 mins to clear two small holes, still pretty dangerous to drive with hat, coat and gloves for me and demist is an issue. No idea what else to do. MG specialist running out of ideas too.
russr is offline
post #6 of 14 (permalink) Old 07-11-2016, 12:20
My car is gas converted and I replaced the header tank capacity 1st.
russr is offline
post #7 of 14 (permalink) Old 07-11-2016, 12:24
Sorry header tank pressure cap.
russr is offline
post #8 of 14 (permalink) Old 07-11-2016, 12:35
Assuming the engine runs at the correct temperature (near 90C using the trip screen diagnostic routine), then coolant isn't getting through the heater circuit. Since the usual suspects have been renewed, I'd say there's an airlock in the cooling system because it wasn't refilled using the correct method. This requires raising the header tank as high as possible. It can be resolved using the specified filling and bleeding proceedure set down by MGR. It's in the Haynes Manual and can be located on the forum using a keyword search. Let us know if you need help.
TC
T-Cut is offline
post #9 of 14 (permalink) Old 07-11-2016, 12:49
Thanks TC, I took the car to Lates and they removed and flushed the matrix, put the car on the T4 and ran the diagnostic, couldn't find the fault. I'm sure they bled the system and refiled using a pressure/vacuum tool. They are as puzzled as I.
russr is offline
post #10 of 14 (permalink) Old 07-11-2016, 15:11
Went out for a 15 minute thrash with the diagnostic setting for 7 the temp ran between 86 and 90 lowest was 82 when first started highest 90 while deceleration from 4500rpm. Highest speed was 70mph. Does this tell you anything??
russr is offline
post #11 of 14 (permalink) Old 08-11-2016, 08:53
- - - the temp ran between 86 and 90 lowest was 82 - - -
It's on the low side and certainly shouldn't drop to 82C when driving. It could go that low if freewheeling downhill I guess. I'd suggest you consider the thermostat.
TC
T-Cut is offline
post #12 of 14 (permalink) Old 08-11-2016, 16:00
OK thanks TC will get another.
russr is offline
post #13 of 14 (permalink) Old 21-12-2016, 12:09
Turned out that I needed a new heater matrix and the water pipes on the LPG system rerouting so the heater got the hot water first and then the lpg evaporator also had to replace the radiator as there was a leak where hose clips were rubbing against it. All sorted now.
T-Cut likes this.
russr is offline
post #14 of 14 (permalink) Old 11-01-2017, 18:40
So, I took the car to Phil T4 who, fitted a new heater matrix then rerouted some of the heater hoses from the lpg evaporator so they went to the heater matrix first then to the LPG system, also replaced the radiator as we found a slight leak at slight pressure. He also resolved my inoperative reverse sensors by replacing the loom and two sensors. I only went to get a new sunroof motor fitted. But at last after some eight years I have absolutely no issues (touching wood).
russr is offline
cold air from heaters Joe_rover45 MG ZS / Rover 45 & 400 9 28-02-2011 20:15
Need Urgent Help! Cold Heaters and Cold Hoses ryancoates MG ZR / Rover 25, 200 & Streetwise 4 06-12-2010 21:21
Why are heaters blowing cold? Madtriumphman MG ZS / Rover 45 & 400 14 10-11-2009 10:32
Heaters blowing cold L8un08 MG ZR / Rover 25, 200 & Streetwise 17 05-08-2009 21:53
cold heaters - not HGF!! Grego228 MG ZR / Rover 25, 200 & Streetwise 8 05-04-2008 01:13
