TOAF worry ye not! - Page 5 - MG-Rover.org Forums
 182Likes
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 2.60 average. Display Modes
post #81 of 523 (permalink) Old 14-04-2016, 08:29
You can put resistor, but this is not safty, bcu have pins to connect drivers and passanger side anti trap. There are rhd and lhd anti traps, you can mount both but dont forget, you can loose your fingers buahaha
About dde and ews, yes Brian have right, when you try to synchronize working ecu it will brick it,, but for now we already found where the problem is. And update will be done today or tomorrow.
If some body bricked ecu this way. Dont be scared you can use INPA to resynchronize (tested) or wait for updated version of toaf. Brian you try to harm this project, but you helped us to be better. Thank you very much
longer86 is offline
post #82 of 523 (permalink) Old 14-04-2016, 09:16
Interested to know more about which bcu pins need to be modded for one touch up..Can you give more details? ,, And have you found the problem to correct the mirror dipping when selecting reverse gear?..
keith8000_0 is offline
post #83 of 523 (permalink) Old 14-04-2016, 09:22 Thread Starter
Read a long time ago about the dipping mirror feature on BMW's been problematic but what people hadn't realised is that the mirror had to be selected on the door card switches as well.
You know that left and right button.??????
Shawn is offline
post #84 of 523 (permalink) Old 14-04-2016, 09:30
yeah mine is selected for passenger side. but not working.. My mate has this feature on his mk2 v8 75.. factory..
post #85 of 523 (permalink) Old 14-04-2016, 09:32
and this link has details of bcu pin outs.. but still need some advice regarding resistors/connections etc.. Obviously at peoples own risk..
https://www.google.co.uk/url?sa=t&rc...19408272,d.ZWU
post #86 of 523 (permalink) Old 14-04-2016, 11:07 Thread Starter
For anyone who bought a 3 quid VAGCOM KKL as I did, I didn't put a big blob of solder on mine but cut a piece of insulated wire about an inch long and bared and tinned the ends so that I could easily reverse it or put a switch on in the future if I wished.
Shawn is offline
post #87 of 523 (permalink) Old 14-04-2016, 11:39
https://forum.roverki.eu/viewtopic.php?p=736643#736643
Here you have Got BCU pinout, connector C0660 with 54 pins
Pins 3 and 4 anti traps for back Windows
Pins 20-21 anti traps for front windows
Best way is to install anti traps or have one and check resistance, maybe is just connected to ground . I have to check this way
longer86 is offline
post #88 of 523 (permalink) Old 14-04-2016, 11:47
yes i have a spare. but i will check for resistance.., but i suspect Linking pins 3,4,21 to pin 20 will work. using the resistance of the drivers sensor for all 3 passenger windows..
post #89 of 523 (permalink) Old 14-04-2016, 12:01
Give it a try.
Remember watch out for your fingers, they could be needed to write here about results
longer86 is offline
post #90 of 523 (permalink) Old 14-04-2016, 12:07
Give it a try.
Lol.. just measured the resistance of a spare trap sensor. measures 3kohms.. and obviously a direct short when pressed..
so either fir a 3k resistor between pins 3.4.21 to earth. or no resistor and link pins 3.4.21 to the drivers door trap sensor..
edited due to incorrect pins info..now correct
post #91 of 523 (permalink) Old 14-04-2016, 12:08
Longer 86. any news on the dipping mirror when selecting reverse?
post #92 of 523 (permalink) Old 14-04-2016, 12:28
You have mistake In pins not 2,3,20,21 but 3,4,20,21.
What do you mean with dipping mirrors?
longer86 is offline
post #93 of 523 (permalink) Old 14-04-2016, 13:42
when you put the car into reverse, the passenger mirror folds down a bit for reversing.. you have it in TOAF but doesnt work..
post #94 of 523 (permalink) Old 14-04-2016, 14:18
Could you post print screen here? I dont know what you talking about, I will ask Marek or Marcin.misek
longer86 is offline
post #95 of 523 (permalink) Old 14-04-2016, 14:55
will try to get a screen shot,, but its a coding option in the SMAC MODULE.. and as i have electric seats it should work.. but maybe a communication issue between the bcu and smac ?
post #96 of 523 (permalink) Old 14-04-2016, 15:40
disabled the 4km/h auto locking that I kept activating on the drive, and locking my wife out
That can be a good thing - locking the wife out, that is!
Mike T is offline
post #97 of 523 (permalink) Old 14-04-2016, 16:02
You have spoken with Marek. SMAC module is the same as used in BMW e46 Or e39 for example. But in BMW is used more Advanced BCU. Marcin do all SMAC Option Visible but this will not work with our truncated BCU. Sorry.
longer86 is offline
post #98 of 523 (permalink) Old 14-04-2016, 16:12
I have a friend who has the rover 75 v8. and the mirror dip in reverse is working from factory..
post #99 of 523 (permalink) Old 14-04-2016, 16:49
Check BCU numbers in his car, this may help.. Check also smac module number.
For example in BCU is option to open boot using remote, but works only on specific numbers bcu 1521 and 1522. Maybe here is the same
longer86 is offline
post #100 of 523 (permalink) Old 14-04-2016, 17:00
might not be able to check his bcu etc. as the car is in storage.. but my car has the mk2 bcu fitted and has the remote boot release option. I will check my bcu number tomorrow..
TOAF nearly here? Will you be getting a remap? Shawn MG ZT / Rover 75 (Sponsored by Rimmer Bros) 19 03-07-2016 09:47
TOAF was going to be a free diagnostic program. Shawn MG ZT / Rover 75 (Sponsored by Rimmer Bros) 26 27-01-2016 19:42
I worry too much! djb MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 06-03-2011 20:13
why do we worry alan1234 MGF and MGTF (Sponsored by MGFnTFBITZ) 13 05-08-2010 22:03
