Top engine oil leak, high presure under oil filler cap and black smoke, PCV? - MG-Rover.org Forums
post #1 of 2 (permalink) Old 24-09-2008, 20:49 Thread Starter
Car: MG ZTT
MG ZTT, 72K, FSH, never any trouble before. (Think it's depressed as selling soon, need to run BioDiesel 100%)
OK, done the MAF thing, lost the misfire but suddenly of the last few days the car has started chucking out black smoke.
Engine still runs like a dream, good power, better with new MAF, but the new MAF did not cure the smoke.
I noticed an oil puddle (used oil) on the top of the engine in the drivers side engine top cover screw hole, when replacing the MAF I tried the engine without the cover and had a small high pressure jet of oil come from the screw hole, I put my finger over the top to stop the car getting covered, turned the engine off and to relive pressure undid the oil filler cap.
I put the whole lot back together, curing the oil leak, the misfire etc, but not the black smoke. I read on Rover Rons site about the PCV valve, could this be the cause?
I would search on the forum, but it looks like the web server is running low on virtual memory (like me) so won't action a search.
Any help appreciated,
Many thanks, Neil.
NeilM is offline
post #2 of 2 (permalink) Old 24-09-2008, 20:54
Many thanks, Neil.
do no harm to clean/change it after 72k , buy the bmw one its cheaper than rover part . also clean or bypass your egr valve. flyer.
FLYER is offline
smoke from the oil filler cap jayzee787 Rover 600 4 09-05-2008 08:44
cdti, black smoke, also oil leak? teebee&ceebee MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 09-02-2008 06:36
Oil leak/Idle issue/exhaust fumes from filler cap.. si_rover_220 Coupe 5 04-11-2007 18:42
Under oil filler cap -I could not believe my eyes GROUNDHOG01 MG ZR / Rover 25, 200 & Streetwise 4 14-12-2006 18:45
Under oil filler cap could not believe my eyes GROUNDHOG01 MG ZR / Rover 25, 200 & Streetwise 1 12-12-2006 20:43
