what is this screw for on the throttle body? - MG-Rover.org Forums
 2Likes
  • 1 Post By Andy400
  • 1 Post By keith8000_0
post #1 of 8 (permalink) Old 07-06-2017, 15:25 Thread Starter
Car: 75
i was gonna give my tb a good clean by taking it out but stupid me didnt do proper research on how to do it and so given up when i couldnt unhook the cable out.. before i tried unhooking the cable i removed various screws including the one circled in green.. i dont remember how deep in it is, i thought it controled idle speed and played around with it to see if it did control idle speed but i dont think it does.. how deep should i screw it in and what is it for really?
my idle speed is between 770-860 (1.8K T) is it high? handbook said it should be around 750+-50
i ended up just spraying the inside of the TB with brake cleaner, throttle opened and closed..
pingpong is offline
post #2 of 8 (permalink) Old 07-06-2017, 20:23 Thread Starter
Car: 75
figured it out, i think.. it's called an idle stop screw, ****** around with it all afternoon ******* up my idle speed to the point my engine overheated to 112 which i then promptly turned off. found a sweet spot, loosen it if the engine's over revving.. tighten if the gas pedal feels sticky like fingers with hunny. moral of the story is dont **** with this ******* screw
pingpong is offline
post #3 of 8 (permalink) Old 08-06-2017, 12:00
yes basically its a stop screw to prevent the butterfly flap from sticking everytime it shuts.. as you say there is a sweet spot between ticking throttle and revving
keith8000_0 is offline
post #4 of 8 (permalink) Old 08-06-2017, 19:22
this screw it set at the factory and their is never ever any reason to adjust it what so ever after it has left the factory.
as said it is just a stop for the butterfly valve so it doesnt stick and start to wear out faster than when in normal use.
Andy400 is offline
post #5 of 8 (permalink) Old 08-06-2017, 20:26 Thread Starter
Car: 75
Question
speaking of throttle.. is it normal for rovers to have a "dead zone" in the gas pedal? like about half an inch on the accelerator is blank and wont start revving past the half inch. it was annoying on my 214 and so i adjusted the throttle cable, i leave it for now on my 75 cause i got used to it now but other cars ive driven dont have it. is that normal or do they usually go loose?
pingpong is offline
post #6 of 8 (permalink) Old 08-06-2017, 20:29 Thread Starter
Car: 75
yea i found that out when googling it. tbh i was gonna pull the throtle body out and just started taking out screws.............
pingpong is offline
post #7 of 8 (permalink) Old 09-06-2017, 00:48
you can as you already say adjust the cable to remove the slack but remember to make sure it isnt over tightened when at full throttle due to over tightening.
pingpong likes this.
Andy400 is offline
post #8 of 8 (permalink) Old 09-06-2017, 13:48
As Andy has said, the throttle cable can be adjusted to take up the slack. this slack is what you will be going through with the pedal before it pulls on the throttle cam..
throttle cable for 48mm & 52mm throttle body ThumpJunkie For Sale 1 15-02-2010 21:18
Throttle Body questions (or Throttle my local garage question!) Neal MGF and MGTF (Sponsored by MGFnTFBITZ) 22 30-08-2006 15:59
84ps throttle body vs 104ps throttle body Steve McF MG ZR / Rover 25, 200 & Streetwise 5 29-04-2004 23:35
Throttle Body adjustment screw (52mm alloy) Richie R Others 5 24-02-2004 19:29
Grub screw on throttle body Fat John Others 10 16-08-2002 14:25
