Zt 2.5 v6 - MG-Rover.org Forums
post #1 of 12 (permalink) Old 26-07-2012, 20:55 Thread Starter
Car: MG ZT 2.5 V6 160bhp
Angry Zt 2.5 v6
Hi every one just wanted to rack your brains, the other day my car over heated and i lost the coolant but could not find any signs of any leaks, i have toped it up and ran it and nothing has happened again, I have looked under neith the engine and could only see this item that was rusty, so what do you think the item is and why would i loose coolant, checked oil and its nice and clean? I did notice an oil leak any ideas what this is too?
Really need your help as I do not want my engine to blow up
Jason
JasonGawn1975 is offline
post #2 of 12 (permalink) Old 26-07-2012, 21:21
cant see any pics, but the usual suspect is the thermostat housing whithin the V of the engine, shine a torch between the black inlet manifold to see if you can see any coolant or coolant staines.
keith8000_0 is offline
post #3 of 12 (permalink) Old 26-07-2012, 23:45
Car: MG ZT 190+
Is the fan working?
Nev-ZT is offline
post #4 of 12 (permalink) Old 27-07-2012, 07:03
Car: ROVER
My V6 also loses coolant and no clear signs of why. I know of one area worth looking at.
There is a coolant pipe that is supposed to be attached to the battery-cradle. A common problem is that when mechanics temporarily remove the cradle, they don't realise that they should re-attach the coolant pipe afterwards (and sometimes the clip on the cradle snaps off). This fairly common mistake causes the coolant pipe to droop down and rest against transmission cables.
Effects of this are:
1. Wear to the coolant pipe (which might cause coolant loss).
2. Rusting of transmission cables.
3. Perishing of the bungs that attach transmission cables to gears (these came right off on mine..).
When I examine the coolant pipe on mine, I can see the rubber is thinner where it had (historically) rested against the transmission cables. It does not look like a leak, but when hot coolant is forced through the rubber pipe, the rubber will expand.. I don't know if expanded-thinned-rubber will gradually leak coolant? But it probably does leak because something has to cause signs #2 and #3.
Also, the reservoir tank is poorly designed. It traps tiny amounts of coolant between the MIN/MAX markers, which can result in a reading when in fact there is no coolant. At one point my car had lost 2L of coolant (and temperature dial shot up) but the reservoir still showed it as above MIN!! Clearly a lying marker because it was fed an extra 2L of water and then drove on fine..
stormbind is offline
post #5 of 12 (permalink) Old 27-07-2012, 16:18 Thread Starter
Smile
Thank you I will check this out and let you know what i find
post #6 of 12 (permalink) Old 27-07-2012, 16:19 Thread Starter
Smile
Originally Posted by Nev-ZT View Post
Is the fan working?
Yes the fan is working
post #7 of 12 (permalink) Old 27-07-2012, 16:20 Thread Starter
Smile
Sorry but I do not know how to up load pictures, if you can help please do
post #8 of 12 (permalink) Old 27-07-2012, 19:34 Thread Starter
Smile
Just uploaded the pictures at long last
post #9 of 12 (permalink) Old 28-07-2012, 15:16
Car: MG ZT+190 Anthracite
My ZT lost water for a couple of reasons ........... these being thermostat housing also oil cooler matrix which is located below and behind the radiator this was a major cause of coolant loss its a common fault that is often overlooked check it out
Jaycue58 is offline
post #10 of 12 (permalink) Old 30-07-2012, 10:54
I had small amounts of coolant loss over periods of time and could never figure it out,pressure tests showed no loss. Finally found had a small weeping leak at the plastic elbow (o ring seal) where the hose goes into the top of the radiator.
It only used to happen after the engine was at operating temp and only noticed it because of a slight mark down the side of the radiator.
The O ring gets hard and wont seal properly.Got some high temp silicone gasket maker which sorted it out.
Seems 90% of major coolant issues on the KV6 are related to the plastic thermostat housing ,the remainder are bolt on bits,clamps etc.
genpk is offline
post #11 of 12 (permalink) Old 30-07-2012, 12:19 Thread Starter
Smile
Thanks ill check it out
post #12 of 12 (permalink) Old 30-07-2012, 12:19 Thread Starter
Smile
