ZT/75 wind noise - MG-Rover.org Forums
post #1 of 5 (permalink) Old 01-06-2004, 22:18 Thread Starter
Car: MG ZT + CDTi 135 XPG
Question ZT/75 wind noise
Has anyone else with a ZT/75 had the same problem with wind noise from either the windscreen surround or the A pillars?
The noise isn't a whistle, it's the same type of rapidly moving, "rushing air" noise that the car's cabin fan makes on intermediate level settings. Noise starts from about 35mph and gets noticeably louder at 60mph and by 70mph it's annoying and if cruising at 80-90mph it's loud enough to easily be the only noise you can hear in the car.
The car is booked into the dealer for a couple of days next week for other warranty work so if there is a known problem/fix or tech bulletin I can refer to it would help to get the problem sorted.
Dealer has already 'adjusted' the fit of the front doors by 1mm and wound the rubber bump stops all the way in but the noise hasn't changed.
The 75s and ZTs I test drove definitely didn't have the same problem so I am missing a seal somewhere?
Thanks in advance
terrymac is offline
post #2 of 5 (permalink) Old 02-06-2004, 04:25
Car: Rover 75 V8
Thanks in advance
There was a problem with early 75's and wind noise from the drivers door seals etc. A tech bulletin was issued some time ago. My car had the work done last year when I reported the problem.
hth
Mike
MikeM is offline
post #3 of 5 (permalink) Old 02-06-2004, 12:08
Car: Chrysler 300c CRD Lux
hth
Mike
Unless it was fixed before i got the car I have never had such a problem
Y
yorky is offline
post #4 of 5 (permalink) Old 02-06-2004, 17:33
Car: Rover 75 V8
Y
Probably 'cos cars with Serpents were considered to posh to have problems
Mike
MikeM is offline
post #5 of 5 (permalink) Old 02-06-2004, 17:57
Car: Tahiti Blue mk3 200
Send a message via MSN to seringo
was there not a similar problem on the mk3 200s? mine does pretty much the same thing. i got a tech bulletin printed off the net, but can't find the file. something to do with i)the seals, ii)the spacing of the door and frame and iii) something else. i'll try dig out my printed copy, see what that says.
seringo is offline
ZT wind noise nwj MG ZT / Rover 75 (Sponsored by Rimmer Bros) 28 18-11-2006 10:44
zt wind noise stu p MG ZT / Rover 75 (Sponsored by Rimmer Bros) 50 05-05-2005 14:57
MG ZT Wind Noise ! stu p MG ZT / Rover 75 (Sponsored by Rimmer Bros) 31 24-08-2004 00:16
Rover 75 / MG ZT excessive wind noise GOODSHARE MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 20-08-2004 14:51
ZT Wind Noise smirker MG ZT / Rover 75 (Sponsored by Rimmer Bros) 22 02-12-2002 22:20
