***Hints and Tips, F/TF How-to Guides & TYRE GUIDE*** - MG-Rover.org Forums
  • 1 Post By 673NN
post #1 of 13 (permalink) Old 09-09-2007, 16:22 Thread Starter
I have tided this thread up by combining this post with the How-to guide post, the suggestions and comments can be viewed and added to in this new thread.
Welcome to this section of the forum dedicated to all things related to the MGF and TF. This thread is no way meant to be comprehensive but it may help to answer some of the more common questions, however if you are still not sure then please don't hesitate to post a question in the forum.
Why does my feel unstable?
Why does my car wander? Some simple checks.
Head gasket
Head Gasket Failure (HGF)
Not sure about the symptom's or think your car has a HGF then take a look at this thread on the subject.
Detailed information relating to causes of HGF and what can be done about them.
What parts do I need to change the head gasket?
Badges
My cars MG badges need replacing, how do I do it?
Coolant
What is the correct level for the coolant and what should I use to top it up with?
Hood
My hood locks up halfway down.
Cleaning the hood using an Autoglym hood cleaning kit.
I have just bought a 115 TF and the central locking (CL) and rear speakers do not seem to be working.
The 115 did not have CL and rear speakers installed at the factory although these can be retro fitted.
What parts from other cars fit the F/TF?
Donor Car Parts and Mods MGF/MGTF
Other common questions.
What lamps (bulbs) does my car use?
Location of sensors and other useful stuff
How to check the battery
Will ZR wheels fit my F/TF?
When I open the boot just after the engine has been switched off I hear a high pitched noise, what is it?
How do I remove the TF's high level brake light?
What colours we the cars made in?
How to fit a start button
Fuse Listing
post #2 of 13 (permalink) Old 09-03-2008, 00:06 Thread Starter
F/TF How-to Guides
You may find the following how-to guides useful
Please remember that the use of these guides is at your own risk.
A big thanks to CJJ for writing most of the following links, however if you know of any more suitable ‘how-to’ type threads and posts on this site then please PM me.
Servicing
How to adjust your alternator belt
How to replace your alternator belt
TF cam belt (non vvc)
Changing AP Discs and Pads
Rear Disc & Pad Change
TF 30K mile service
Pipes and hoses
Repair & Replacement
How to - TF Rear compliance bush (n/s)
How to remove the front subframe
How to remove the rear subframe front mounts
How To - MG TF Rear Upper Ball Joint replacement
'How to' Stepspeed primary gearbox bearing
Replacing complete boot hinges
How to... repair boot wiring harness
How to fit Torque Tamer bushes
How to: Fit rear polybushes (MGF)
How To: Replace the Dipstick Oil Filler
How to fix MGF MY2000 high oil temperature gauge
How to fit stainless steel under floor coolant pipes.
HOWTO - Replacing your aerial mount
How To: Replacing the gearstick and Handbrake Gaitors
How To: Replace radiator with Aluminium one (without removing Bumper)
TF Throttle Cable Change
Fit a Stainless Steel Flexipipe
Clutch Change How To
Replacing suspension bushes (rear) on MGF
How to rebuild wiper motor
How to change a handbrake cable.
How maintain your AP callipers.
Fitting a modified Clutch Release Arm
How to change the fuel pump
How to - remove the TF's front bumper
How to replace the radiator
Repairing seatbelt pretensioner plugs
Central locking mechanism replacement
Repairing the central locking mechanism
Replacing the electric window motor
Replacing faded MG badges
Removing the 3rd brake light on the TF
Checking Hot/Cold Cabin Temperature Linkage
How To - Replace Rear Callipers
Rear Calliper Rebuild
Rear Brake Refurbishment/Rebuild
How to replace clutch and flywheel
Repair of clutch master cylinder
Rear bumper removal
How to - Remove the engine from a TF
Replace the Hydragas Units and Install Lowering Pins
Hood Replacement
Damaged seat repair and cover removal with seat in car, MG TF..
Modifications – Performance
Fitting a 4-2-1 Manifold
Fitting a MIL Eliminator
Fitting a new exhaust
Installing AP TF160 brake kit to the F/TF?
Porting & Polishing Throttle Body
Removing the instrument panel
Changing the alternator
11 Spoke Wheel Refurb
How to remove TF's centre console
Modifications – Cosmetic
BAS Hood Liner fitting
How to: Fitting Mike Satur Roll Hoops
How To - Change Rear Lights
How to change your dash dials to NAC style
painting brake calipers
How to fit MS wheel adapters
Quad Lights
Modifications – Audio
How to: Steering wheel audio controls
New Fitting a DAB aerial
Fitting new door speakers
Fitting an Alpine Sub woofer
A pillar tweeter builds for a MY2000F/TF
Modifications – miscellaneous
Heated Seats How To Guide
How to fit Hyundai Coupe S3 seats into TF
HOW TO fit MGF Headlamp converters
Fitting the MGF Side Scoops
DIY Coolant level warning with pics and wiring
Fitting a MGFMania glass rear window
Sports Buckets Into MGF
Re-trimming the windscreen surround
Dynamating the inspection cover
Heated seat kit - Installation
Installing cruise control into a TF
Installing a ZS wheel with cruise & stereo controls
Installing Rover 800 stalks
Fitting Parking Sensors
Installing Air Conditioning in an MGF - CMMGRCC?For Enthusiasts of Post-1980 MG and Rover Motor Cars
post #3 of 13 (permalink) Old 14-11-2008, 18:34 Thread Starter
post #4 of 13 (permalink) Old 07-01-2009, 13:10 Thread Starter
Tyre information for the MGF - Please note that these specifications are from Rover/MG-Rover at the time of the cars manufacture.
MGF RECOMMENDED TYRES and PRESSURES – All models
All Mgf (except Trophy)
Wheels and tyres -(no other arrangements are recommended):
185/55 R15 V Goodyear NCT3 fit to 6 x 15 alloy wheels - FRONT only
205/50 R15 V Goodyear NCT3 fit to 6 x 15 alloy wheels - REAR only
215/40 R16 Z Goodyear Eagle F1 fit to 7 x 16 alloy wheels - front & rear
175/65 R14 T fit to 5.5 x 14 steel spare wheel only
Wheel alignment:
Front 0.10’ 6’ toe out
Rear 0.10’ 6’ toe-in
Tyre pressures lbf/in bar
185/55 R15 V (front wheels only) - 26 lbf/in ......... 1.8 bar
205/50 R15 V (rear wheels only) - 28 lbf/in ......... 1.9 bar
215/40 R16 Z (front wheels) - 24 lbf/in ........ 1.7 bar
215/40 R16 Z (Rear wheels) - 28 lbf/in ........ 1.9 bar
175/65 R14 T (spare wheel only) - 30 lbf/in ........ 2.1 bar
WARNING: The spare wheel is for temporary use only, and the car must not exceed
50 mph (80 km/h) with the spare wheel fitted.
TROPHY MGF
195/45 Z R16 Goodyear Eagle F1 fit to 7J x 16 alloy wheel - FRONT only
195/45 V R16 Yokohama A539 type fit to 7J x 16 alloy wheel - FRONT only
215/40 Z R16 Goodyear Eagle F1 fit to 7J x 16 alloy wheel - REAR only
215/40 V R16 Yokohama A539 type fit to 7J x 16 alloy wheel - REAR only
NOTE: Goodyear Eagle F1 tyres are directional tyres and MUST be fitted in accordance with the direction of rotation shown on the sidewall of the tyre.
Mixing Goodyear and Yokohama tyres on the same car is NOT
recommended.
Trophy Tyre Pressures - Goodyear tyres
Normal driving conditions lbf/in bar
195/45 ZR16 (front) - 24 lbf/in ......... 1.7 bar
215/40 ZR16 (rear) - 36 lbf/in ......... 2.5 bar
Trophy Tyre Pressures -Yokohama tyres
195/45 ZR16 (front) - 26 lbf/in ......... 1.8 bar
Trophy Tyre Pressures over 100mph(160km/h) lbf/in bar
195/45 ZR16 (front) - 30 lbf/in ......... 2.1 bar
MGTF RECOMMENDED TYRES and PRESSURES – All models
MGTF Wheels and tyres -(no other arrangements are recommended):
185/55 R15 V Continental Premium Contact fit to 6 x 15 alloy wheels - FRONT only
205/50 R15 V Continental Premium Contact fit to 6 x 15 alloy wheels - REAR only
195/45 R16 Z Goodyear Eagle F1 fit to 7 x 16 alloy wheels - FRONT only
215/40 R16 Z Goodyear Eagle F1 fit to 7 x 16 alloy wheels -REAR only
175/65 R14 T fit to 5.5 x 14 - steel spare wheel only
195/45 R16 Z Goodyear Eagle F1 fit to 7 x 16 - alloy spare wheel
MGTF Tyre Pressures
205/50 R15 V (rear wheels only) - 36 lbf/in ......... 2.5 bar
175/65 R14 T (spare wheel only) - 32 lbf/in ........ 2.2 bar
195/45 R16 Z (spare wheel only) - 32 lbf/in ........ 2.2 bar
MGTF Tyre Pressures over 100mph(160km/h) lbf/in bar
195/45 ZR16 (front) -28 lbf/in ......... 1.95 bar
185/55 R15 V (front wheels only) - 28 lbf/in ......... 1.95 bar
WARNING: The spare wheels are for temporary use only, and the car must not exceed 50 mph (80 km/h) with either type of spare wheel fitted.
NOTE: Goodyear Eagle F1 tyres are directional tyres and MUST be fitted in accordance with the direction of rotation shown on the sidewall of the tyre.(except for above)
Note there have been some reported problems with Marangoni Zeta Lenea and GoodYear GD2/3 tyres. See this thread for details.
Info on this page gathered by Aiketgate.
Note: Toyo compound has changed see
Thanks to Jason in this thread
Good afternoon Jason,
We had to make some changes to the tread compound on the T1R to meet the EU tyre labelling regulations. All tyres produced in Malaysia and Japanese production after September 2014 have the new compound. This change has, in some cases, changed the handling characteristics of the MGF/TF, if you have original spec Japanese production on the front and Malaysian on the rear, by fitting Malaysian all rounds corrects the issue.
I have been in discussion with the MG Owners Club and they are preparing some advice on this.
Best regards
Alan Meaker
Technical and Motorsport Director
Toyo Tyre UK
T +44 (0)1933 414537
F +44 (0)1933 410221
M +44 (0)7879 813915
post #5 of 13 (permalink) Old 13-04-2009, 20:51
Stu
Stu's Avatar
A link to the Goodyear / MGR advisory for use of GSD2 / 3 tyres.
http://forums.mg-rover.org/attachmen...2&d=1145552975
Stu
Stu is offline
post #6 of 13 (permalink) Old 13-03-2011, 17:49
Car: MG TF 135 Spark
****************Hints and tips, F/TF How-to Guides & TYRE GUIDE*******
All,
Following all my questions on tyres, please find below email from Roger Parker at MGOC regarding MG's advice following the removal of Goodyear Eagle F1's:
“The GSD2 Good Year tyre is the approved OE fitment to MGTF. This tyre (and NOT the GSD3) is still the only fully approved tyre for this vehicle.
Where the GSD2 is unavailable, MG Motor recommends either the Falken Ziex ZE912 or the Toyo Proxes TI-R as appropriate. MG Motor has conducted limited testing on these alternatives to the Good Year when fitted as a car set.
MG Motor currently has no data on extended tyre wear for these alternatives.
Technical details of tyres tested:-
Front – Falken Ziex 195/45 R16 80V I0123 Extra Load, country of manufacture - Thailand.
Rear - Falken Ziex 215/40 R16 88W I0123 Extra Load, country of manufacture - Thailand.
Front - Toyo Proxes T1-R 195/45 R16 80V PXT1-R-2 ANH3608, country of manufacture - Japan
Rear - Toyo Proxes T1-R 215/40 R16 88W PXT1-R-3 ANH3608, country of manufacture - Japan
MG Motor is committed to support the customer gain the most from their car and would advise strongly that tyres should be fitted as a vehicle set.
Once tyres have been balanced and fitted, the car should be checked on a 4-wheel laser alignment machine against the correct data. This will prolong tyre life and ensure that the car is configured to our recommended settings.
The advice of a reputable tyre specialist and/or MG Motor Approved dealer should be sought in tyre selection and fitting to suit local conditions and vehicle use.
Mixing tyres across the same axle is not recommended. Mixing tyres front to rear (i.e. having different tyres on the front axle to the rear) is also not recommended.
Although the legal minimum tread depth in the UK is 1.6mm across the contact patch, tyre manufacturers will advise that wet grip deteriorates below 3mm.
Tyre pressures will be found in the vehicle handbook. 26psi front and 36 psi rear will suit 135s and LE500. 85th Anniversary cars run 30psi front, 36psi rear.
pmheathcote is offline
post #7 of 13 (permalink) Old 24-03-2011, 15:28
Car: MG Motor 2011 TF135
Just received a recall notice for my MGTF from MG Motor UK. This does not apply to Fs or TFs built/sold by MG Rover.
Readers Digest type summary:
An issue was identified in the suspension set up of a new MGTF. Review suggested it was a one off component specification issue. Another was subsequently found at a dealership. Checking and repairing the car should take 1 - 3 hours. Courtesty car should be provided. Issued by Keith Harris 16 March 2011.
I've just booked my TF in for 1st April but no courtesy car available until 6th April. It's a safety problem so I'll provide my own courtesy.
Sprinter is offline
post #8 of 13 (permalink) Old 07-06-2012, 14:54
Due to the sad news of a couple of cars being in accidents yesterday, it stirred a memory of something I read on the X part flyer called the close call scheme, not sure if it has already been discussed.
Close Call is a programme aimed at keeping MG Rover vehicles on the road by reviewing parts prices on body and mechanical products, so that repair costs become economically viable.
A programme that will build close working relationships between Insurance Companies, Bodyshops and vehicle repairers to ensure all MG Rover vehicles are kept on the road where possible.
A programme that will guarantee a response turnaround time of 24 hours from receipt of the estimate from the repairer.
The aim of ‘Close Call’ is to keep where possible MG Rover vehicles on the road. We have analysed car parc trends and we
are determined to keep as many MG Rover vehicles on the road
as possible
The steps are as follows
1. - Vehicle is taken to nominated repairer who generates an estimate
2. The Insurance Company/Vehicle Owner receives the estimate from the Repairer. If the vehicle is deemed uneconomical to repair, then it’s a ‘Close Call’.
3. The Repairer contacts the Close Call’ team. [0870 609 2357]. The Repairer submits a copy of the estimate and a request form to the ‘Close Call’ team with Pre-Accident Value of the vehicle and parts saving required.
4. The ‘Close Call’ team review and return revised pricing to the Repairer. The ‘Close Call’ team will keep the vehicle on the road where possible. Turnaround time by the 'Close Call’ team will be 24 hours.
5. The Insurer/ Vehicle Owner decides whether the vehicle is now economical to repair. The Repairer contacts the ‘Close Call’ team with their decision.
6. The ‘Close Call’ team processes the parts order, with agreed pricing. Parts are delivered to the nominated Repairer
Pendle Lass is offline
post #9 of 13 (permalink) Old 29-01-2013, 20:10 Thread Starter
January 2013 Recall notice for all 2008 and on TF's
See this thread
post #10 of 13 (permalink) Old 29-01-2013, 20:10 Thread Starter
See this thread
(Image of letter posted by CJJ)
post #11 of 13 (permalink) Old 28-01-2015, 21:17
batoutofhull's Avatar
Its handy to have bits of information about your TF to hand when out in the car. Here is a simple quick reference label to print out. Put it on your sun visor or paste it to your door jamb.
There is a word version so you can add more info. if you want and a pdf.
It saves me fishing around for tyre sizes, tyre pressures, etc. and also reminds other drivers ( no names mentioned ) 'Son' & 'Father in Law' of a few details.
Have a look and feel free to change it.
batoutofhull is offline
post #12 of 13 (permalink) Old 25-05-2015, 17:06
Car: MGTF 160
Admin note: The following two posts were an answer to a question posed by CJJ, "Is there a definitive list of which wheels fit over AP 4 pot brakes?" See the original thread
Trophy wheels
11 spokes
Swedish wheels rare
ultralites ultra rare
v spokes
team dynamics pro race
twist of pepper
spaceoctagon is offline
post #13 of 13 (permalink) Old 25-05-2015, 18:02
Car: 04 Rover 75 Connie Tourer in XPower Grey, 04 MGZT+ 1.8 Turbo in Trophy Yellow.
And the Mike Satur 17" trophy style.
Mikeadman likes this.
673NN is offline
Closed Thread
Tags
f/tf how to, how to
Looking to buy an MG TF...any hints, tips, warning signs to look for? dancing_bex MGF and MGTF (Sponsored by MGFnTFBITZ) 14 10-01-2016 17:49
any hints or tips on how to remove the antiroll bar craig8661 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 10-01-2011 16:54
tips/hints bamby Metro / Rover 100 3 28-03-2007 14:03
Some PC Hints & Tips etc Tatts PC Gen Chat & Help 3 01-09-2005 19:45
Hints and tips on treating the roof please Bill Brooks MGF and MGTF (Sponsored by MGFnTFBITZ) 17 14-04-2004 16:43
