6 stud exhaust on MGF VCC and deburring. - MG-Rover.org Forums
post #1 of 15 (permalink) Old 22-07-2010, 22:18 Thread Starter
Car: 143 vvc Mk1
Hello.
I have read this site for a while, and thought you may be interested in seeing some differences between the 6 and 4 stud exhaust, as well as just how bad the inner flange welding on these parts is.
I have a F VVC with plenty of modifications, and my exhaust needed replaced. I do not think that the majority of aftermarket parts are good value for money and I do not race so I decided to use stock components and modify them.
I chose a 6 stud TF manifold and downpipe, a replacement F cat and a F Bosal backbox, as I perceived it to have better quality construction and pipe bending than similar replacement parts.
The manifold was 18 delivered, 44 for the downpipe (with a lambda sensor in it!), 40 for the cat and 105 for the backbox.
I chose the 6 stud system as I wanted to see if it had longer primaries or a bigger pipe diameter. The conclusion I came to was that the primaries were around 6-9mm longer on the TF/6 stud manifold than the F/4stud. This was done by the fairly poor 'string and Blu tak' method, but did appear repeatable. The old 4 stud manifold had to be butchered to find this out (see photo album). The pipe inner diameters were the same. On this basis I went ahead.
The following are photos of the various stages.
This is the system, minus backbox
This is the size of the typical burr on the EX manifold inlet:
Here is the downpipe exit flange burr
This is the amount of burring at the EX manifold outlet (primaries are visible inside)
This is the EX manifold about to be matched to the gasket to the downpipe:
And here is the nasty bit - the sizes before....
and after...
That equates to a 15.9% increase in throat area. Obviously this does not mean the whole pipe is bigger, but the throat restriction is sizable.
I used a tungsten carbide cutter bit and an air driven cutter to do the work. The welds are quite hard.
Now on to the EX manifold inlet. These are the burrs:
Before....
and after....
That's a 18.9% increase at the throat area. Bearing in mind that this is a restriction right where the hot exhaust flow wants out from there must be a considerable pressure loss in the pipe right there.
The cutting made some parts too thin, so I beaded some weld around the outside, and then cut back the drips.
Now the downpipe. It's inlet needs to be matched to the gasket and the exit from the manifold.
This was the diameter as standard:
and after
That's a 9.2% increase in area, and shows the mismatch between manifold exit and downpipe inlet caused by the burrs (I did fettle the two sections to match almost exactly after those photos BTW).
The downpipe exit to the cat (of which I lost the photos) had a burred diameter of 48.79mm and was opened out to 51.10mm. This joint was heavily radiused as the pattern catalytic converter had a significantly larger diameter, so it was a case of trying to blend as best as possible. The cat also has a nasty step where the tube is pressed in, and I did consider machining the flange so it was at least flush, or running a bead of weld around it, but as I did not want to hurt the matrix I decided to to live with it.
With this all done it was exhaust removal time. I chose a large angle grinder to help.
and decided to simply remove the old 4 stud manifold from the top with the remainder of the downpipe on it
Here are the manifold differences:
You would say the primaries on the 4 stud are longer but I found the 6 stud to be longer, as mentioned above. You can see inside the 4 stud here:
The whole thing was ready to be put on after that:
I will write separately about the backbox surgery, the short version is I removed the baffles and crosspipes to reduce the backpressure and make a sportier noise.
My conclusion from this;
The car seems slightly better in low range and will comfortably trundle in 5th gear at 1500rpm and pull cleanly, if not strongly from there. Beforehand it would slug if I tried to do that.
The noise is nicer and sportier, but neither too loud or tiring.
The power above 4000rpm seems to have improved. I tried timed before and after 30-50mph 4th gear runs on the car with an overnight cold soak and a 15 minute warm up on the same roads. Before was 6.38 seconds (averaged over 3 runs), after was 6.16 (av. 3 runs). The book figure is 6.5, but I already have other tweaks on my car. I was toying with the idea of getting someone else to drive it to try to eliminate bias, but I did not have time.
I had no intention of paying for before and after rolling road runs at 50 a time, so this was the best I could do.
As I needed a replacement anyway I felt all of the effort was worth it.
Regards.
blackoctagon is offline
post #2 of 15 (permalink) Old 22-07-2010, 22:24
Top first post!
post #3 of 15 (permalink) Old 22-07-2010, 22:38 Thread Starter
Car: 143 vvc Mk1
Thank you.
I will post more on the 4 stud flange and my backbox modifications another day.
post #4 of 15 (permalink) Old 23-07-2010, 05:25
bloody brilliant and technical 1st post
post #5 of 15 (permalink) Old 23-07-2010, 07:43
Banned
Aye, very interesting indeed.... I did the same to my new manifold and downpipe, only not as thoroughly as you. Its on my list of things to do now I have got a spare 6 stud manifold to play with.
It does seem to improve pickup and driveability some.
andycolm is offline
post #6 of 15 (permalink) Old 23-07-2010, 19:28 Thread Starter
Car: 143 vvc Mk1
Here are the photos that I had missed out in the first post.
This covers the downpipe;
This shows the Downpipe exit before....
and after....
Only a few mm to be had this time, but it is still worth having, even though there will be an abrupt expansion loss into the cat.
And this last photo is how the whole manifold looked after cleaning up:
A new VVC manifold arrived today, so i'll be doing the same trick with it.
Last edited by blackoctagon; 23-07-2010 at 19:58. Reason: got pictures the wrong way around (!)
post #7 of 15 (permalink) Old 23-07-2010, 19:54
Trader Supporter
Car: MGF, Alfa MITO, Volvo C70 and Maserati 3200GT 365bhp
just see how much metal has to come out of those pipes/burrs
well done, good job
TT MK7 exhausts for MGF and TF sold out next batch ordered. .
Neil Surrey Lab is offline
post #8 of 15 (permalink) Old 13-03-2011, 09:18
Trader Supporter
I think that back box has to go though
post #9 of 15 (permalink) Old 13-03-2011, 11:36 Thread Starter
Car: 143 vvc Mk1
The thread that returned from the dead!
I'll happily accept a free sample backbox. Just tell me where to send the courier.
post #10 of 15 (permalink) Old 10-04-2011, 21:13
Car: TT MGF #0002
Sorry to revive this once again but where can I get the bits needed to tidy up the welds? Got a week off work so may as well get busy
gotenks1321 is offline
post #11 of 15 (permalink) Old 10-04-2011, 22:05 Thread Starter
Car: 143 vvc Mk1
Once again, zombie thread.
I got mine many moons ago.
Most of my burrs came from Bill's Tool Store in Glasgow - http://www.billstoolstore.co.uk/
A good brand like Garryson are worth going for.
I prefer tungsten carbide single flute, aluminium-cutter type burrs for almost all of my work (soft and hard), but for cost reasons and on steel a double type is the norm. These look fair:
http://cgi.ebay.co.uk/5-Piece-Tungst...item56437f28be
The question is; what do you have to cut with?
I use a 6mm collet Makita die grinder with a homemade variable speed controller.
post #12 of 15 (permalink) Old 10-04-2011, 22:13
Car: TT MGF #0002
All I have currently is a cheap dremel type tool but I'm looking at getting something a bit more heavy duty. How does this look? http://cgi.ebay.co.uk/die-grinder-/2...item4158840b17
post #13 of 15 (permalink) Old 10-04-2011, 22:17 Thread Starter
Car: 143 vvc Mk1
It looks fine.
Mine revs to around 20000 and was about 110, but that's usually overkill for most things.
Just make sure it has a 6mm collet, as that is the most common, at least for this kind of work.
There is this one as well:
http://cgi.ebay.co.uk/Metabo-GE700-d...item4aaa3dca0c
post #14 of 15 (permalink) Old 10-04-2011, 22:29
Car: TT MGF #0002
Thanks, shall keep an eye on that one too. Is it just a normal plug on the end? I know that some I've looked at in the past you have to modify or have an adapter for.
post #15 of 15 (permalink) Old 10-04-2011, 22:36 Thread Starter
Car: 143 vvc Mk1
That model could be either.
Those with the large three pin plug are professional ones that run on 110volts for factory or site use.
As a rule, if it says 240v it will be a normal 13amp type plug.
The big manufacturers such as Makita, Bosch, DeWalt etc tend to offer most models in both variants.
Exhaust manifold stud MR (Z)T MG ZT / Rover 75 (Sponsored by Rimmer Bros) 19 15-07-2010 11:35
Exhaust manifold stud Jerryboy MG ZR / Rover 25, 200 & Streetwise 0 14-06-2010 10:03
exhaust manifold nut and stud size andymitton MG ZR / Rover 25, 200 & Streetwise 2 27-02-2008 16:34
exhaust manifold stud and nut sizes andymitton MG ZS / Rover 45 & 400 1 27-02-2008 12:36
Deburring exhaust manifold Chidster MG ZR / Rover 25, 200 & Streetwise 16 19-01-2008 17:18
