advice needed water pump leak RAD WELD - MG-Rover.org Forums
post #1 of 51 (permalink) Old 08-02-2008, 13:03 Thread Starter
Send a message via MSN to DJMARK
my water pump has a leak could I add rad weld to help as a precautionary measure or does the cambelt & pump need to be done
just need to save some cash so a radweld it for a while might help
DJMARK is offline
post #2 of 51 (permalink) Old 08-02-2008, 13:04
Car: MG ZT 260 SE V8
Only put RadWeld in if you want to bugger your car up completly.
DON'T USE RADWELD IN THE K SERIES ENGINES!
James C is offline
post #3 of 51 (permalink) Old 08-02-2008, 13:10 Thread Starter
You The Man!!
DJMARK is offline
post #4 of 51 (permalink) Old 14-02-2008, 14:19
Yeah get the leak fixed correctly! Radweld is a k series killer.
Kenny P is offline
post #5 of 51 (permalink) Old 14-02-2008, 14:25
wot he said
MGMUSKY is offline
post #6 of 51 (permalink) Old 14-02-2008, 15:34
so should he use it or not? lol
silvershadowmgf is offline
post #7 of 51 (permalink) Old 14-02-2008, 15:51
I think James was advising against it lol.
Kenny P is offline
post #8 of 51 (permalink) Old 14-02-2008, 16:04
Car: MGF Trophy 160, MG ZS180
Radweld won't work on rotating joints anyway.
Tim. is offline
post #9 of 51 (permalink) Old 14-02-2008, 18:16
Exactly
but in other locations it will work as a get you home measure. Not sure what all the fuss is about with Radweld - the only engine you cannot use it on is the Rover 827.
MGFmad is offline
post #10 of 51 (permalink) Old 14-02-2008, 18:29
Originally Posted by MGFmad View Post
.....Not sure what all the fuss is about with Radweld.......
that would be the narrow water ways in the engine, just waiting for a coagulating agent
post #11 of 51 (permalink) Old 14-02-2008, 18:41
Send a message via MSN to billo
Exactly
well said my friend , i used rad weld cause i spotted a small leak on my radiator and NEVER had a problem since apart from kenny putting the ****ters up me , so i had it checked out by 3 different garages and they all said my coolant systm was fine SO
billo is offline
post #12 of 51 (permalink) Old 14-02-2008, 18:43
Yup nasty stuff. Just address the leak correctly if it needs a new rad get one on.
Kenny P is offline
post #13 of 51 (permalink) Old 14-02-2008, 18:55
All you need to no about radweld is here.
Kenny P is offline
post #14 of 51 (permalink) Old 14-02-2008, 19:07
use radweld its fab !!!!!!!!!!!!
billo is offline
post #15 of 51 (permalink) Old 14-02-2008, 19:09
I don't have any Radweld in the MGF as I have renewed most of the cooling system. But have used it on a couple of other cars with no side effects -
First was a long while back on a Pug 106 diesel that had very slight coolant loss but no sign of a leak, put some radweld in and it stopped the coolant loss - had this car for quite a while after with no problems.
In July 2005, our Discovery TD5 developed a slight coolant leak from the radiator while we were on holiday, I put some radweld in and it stopped the leak and kept a close eye on the temperature while driving home. In the following months I forgot about the radiator so never changed it and it nevr lost of drop of coolant - traded in last month.
I believe radweld works by expanding to fill a hole on contact with air so its not going to cause a problem inside the engines waterways.
It does have its place as a temporary fix and I would not advise doing what I did with the Disco as a long term solution, but its not the curse of the devil either!
MGFmad is offline
post #16 of 51 (permalink) Old 14-02-2008, 19:10
Excellent - we could be the founder members of the Radweld appreciation society
MGFmad is offline
post #17 of 51 (permalink) Old 14-02-2008, 19:14
Talking
YEAH LETS START A CLUB
billo is offline
post #18 of 51 (permalink) Old 14-02-2008, 19:15
.....but its not the curse of the devil either!
OOOOO yes it is
post #19 of 51 (permalink) Old 14-02-2008, 19:19
I see another crew comin' up: Hardcore Radweld Crew (HCRC)
Good luck guys hehehe
Herbie is offline
post #20 of 51 (permalink) Old 14-02-2008, 19:20
Red face
MAYBE ITS JUST CRAP ON TF'S !!!!!!!!!!!!!!!!!!!!!!
billo is offline
Leak from water pump lozz MG ZR / Rover 25, 200 & Streetwise 5 02-11-2008 16:15
Water Pump Leak 214 no 1 MG ZR / Rover 25, 200 & Streetwise 18 25-02-2008 19:10
Water pump leak. Rov420i MG ZS / Rover 45 & 400 4 18-07-2007 13:38
Water pump area leak???? Robs 2001 mgf MGF and MGTF (Sponsored by MGFnTFBITZ) 5 11-01-2007 22:36
Rad Weld ???? zaffa Others 7 09-06-2003 19:12
