Air Con Con - MG-Rover.org Forums
  • 1 Post By culyun
post #1 of 20 (permalink) Old 17-01-2016, 17:05 Thread Starter
Car: MGF VVC
Exclamation Air Con Con
I have just picked up a second MGF,It is 1995/6.
It comes with Air Con and as such has a variety of buttons and switches on the dash panel.
Does any one have a description/instructions on how to operate the AC ?
Need to see if it works..
I.Am.Spartacus is offline
post #2 of 20 (permalink) Old 17-01-2016, 17:19
It is easy if it is OEM one. You push A/C button and operate round switch of blower to position you desire. A/C button will litand cold air should blow, unless air con is empty of gas.
post #3 of 20 (permalink) Old 17-01-2016, 17:44 Thread Starter
Car: MGF VVC
OK thanks for that,there are two switches on the panel one with a circle of three arrows and one with a circle of stars any idea which does what??
I.A.S
post #4 of 20 (permalink) Old 17-01-2016, 17:48
Car: MG ZS 120+ , MG ZR TD, MG TF 135 and MG3 Style.
I.A.S
that's the air recirculation. air con works best with this on.
I think it recirculates the air in the car rather than draw air in from outside.
michaelb is offline
post #5 of 20 (permalink) Old 17-01-2016, 18:01
I.A.S
Circle with three stars is A/C switch.
Circle with three arrows is, as said, air recirculation. It recirculates air inside cabin rather then using fresh air from outside cabin.
post #6 of 20 (permalink) Old 17-01-2016, 18:17 Thread Starter
Car: MGF VVC
Ok thanks for the replies.
Now I know what to do/look for
I.A.S
post #7 of 20 (permalink) Old 18-01-2016, 11:44
I.A.S
Umm...that's actually a snowflake on the switch, not a circle of stars. I've got lots of snowflakes in the front yard, I can send you one if you like?
mowog73 is offline
post #8 of 20 (permalink) Old 18-01-2016, 16:01 Thread Starter
Car: MGF VVC
Well that is a very kind offer,but I would hate to deprive you of them so for now you can hang on to them.....lol
post #9 of 20 (permalink) Old 18-01-2016, 19:12
from 19 for a regass from groupon
https://www.groupon.co.uk/browse/man...g&locale=en_GB
super_cds is offline
post #10 of 20 (permalink) Old 19-01-2016, 00:19
Talking
Maybe it's a Euro-Snowflake
RichinVancouver is offline
post #11 of 20 (permalink) Old 19-01-2016, 07:37
Car: 99 MGF & 03 MGTF 135
Wink Mgf ac
Were 95/96 MGF's fitted with AC? I've never seen one, not an OE fit anyway.
silvascoop is offline
post #12 of 20 (permalink) Old 19-01-2016, 08:18
the ones sent to japan did
post #13 of 20 (permalink) Old 19-01-2016, 09:49
Turn the fan on.
Push the snow-flake button in the lower left region of the console.
At idle you should see the tacho jump about 400 rpm briefly to compensate for the anticipated load of the AC compressor.
You may also be able to hear the operation of the AC relay. If you can hear the operation of the relay, it generally confirms that there is some refrigerant in circuit. If you don't hear the relay, it could mean there is no refrigerant or it may be that you simply didn't hear it.
culyun is offline
post #14 of 20 (permalink) Old 19-01-2016, 09:51
Oh, and on a winters day turn on the AC and the heater at the same time. This defogs the drivers window better than the heater alone..
DocMark likes this.
culyun is offline
post #15 of 20 (permalink) Old 19-01-2016, 20:48 Thread Starter
Car: MGF VVC
Thank you gentlemen for all you replies I now know what to do
I think....
post #16 of 20 (permalink) Old 20-01-2016, 19:29
Originally Posted by culyun View Post
......AC and the heater......
A/C stands for air conditioning, not air cooling.
post #17 of 20 (permalink) Old 20-01-2016, 21:42 Thread Starter
Car: MGF VVC
Well I have had the car running today and pressed the "Snowflake"but nothing happened, by that I mean the light on the switch did not come on so will need to investigate a little further.
post #18 of 20 (permalink) Old 21-01-2016, 10:11
@Talkingcars: Sure, but unless you're running the circuit backwards, you will be using the air-conditioning as a refrigerator and not a heat-pump.
culyun is offline
post #19 of 20 (permalink) Old 21-01-2016, 11:36
Car AC systems cannot normally run backwards. The valves in the compressor only work one way.
I think reference was made to the fact that the AC system will dry the incoming air as well as cool it, therefore the air going into the heater will be dry and out to the screen will be hot, dry air, perfect for demisting.
post #20 of 20 (permalink) Old 21-01-2016, 17:44
The way it conditions is to chill the air which condenses it and forces the moisture out.
There is no control in the refrigerant circuit to affect the temperature of the refrigerant.
The temperature is controlled by the volume of coolant flowing through the internal heater matrix.
Rear Wiper, air con, air circulation and Wing Mirror motors not working?! mike_foyle MG ZR / Rover 25, 200 & Streetwise 3 17-05-2013 11:59
parts for convert 620ti WITH air/con in NO air/con ?? sebzowa Rover 600 6 22-11-2011 07:46
rover 200 sdi air heaters, air con and rear heated window Adrian g MG ZR / Rover 25, 200 & Streetwise 4 01-05-2010 21:56
air con / non air con radiator davetrigz MG ZR / Rover 25, 200 & Streetwise 3 11-01-2010 13:02
620ti PAS Pump for air con and non air con andyblade Rover 600 1 16-02-2009 21:47
