And another overheating issue - MG-Rover.org Forums
  • 1 Post By Julian Foulger
post #1 of 6 (permalink) Old 19-04-2017, 15:56 Thread Starter
Good afternoon everyone, I need the brains of the MG heroes here on the forum. The amount of issues this MG TF 135 sprint has given me is beginning to make my sanity look questionable. The issue I am having now is an overheating issue when idling. I first noticed it when I was on a long run on the motorway and when I come to a complete stop, after about 15 minutes of idling, the temp gauge started to rise. I plugged him in to my OBD2 reader and no fault codes. I am not experiencing any coolant lose, if anything I am experiencing coolant rise! I have attached a picture, this certainly isn't normal is it!? When he's cold he is sitting bang on the max line. I did a 500 mile round trip over the bank holiday with no problems... As long as he's moving and doesn't idle longer than 5 - 10 minutes, he behaves fine. The front fan is kicking in religiously at around 220f. At this point in time I suspect an airlock... Any help would be greatly appreciated! Many thanks
MrKitty is offline
post #2 of 6 (permalink) Old 19-04-2017, 16:21
johnan's Avatar
I would have thought idling for 15 minutes would cause a temperature increase if there is no flow through the radiator until the fan cuts in?
Is the problem the fan does not control the temperature after it cuts in initially...it should switch on and off as required to control the temperature.
If the fan can't bring the temperature down, the rad could be partially blocked internally, among other things.
johnan is offline
post #3 of 6 (permalink) Old 19-04-2017, 19:00 Thread Starter
Thanks for your reply, funny you should say that I took it to an apparent mg specialist garage, which I shall not name, and said to them exactly that - I don't think my rad is good. They gave the classic 'it's yer 'edgasket mate', which was somewhat surprising as I used them for work in the past and they proved to be pretty good. The irony is these guys changed my underfloor coolant pipes about 4 months ago and didn't bleed the system from all three points. They only bled from two because apparently one is a 'pain in the arse' to get to.
By the way yes that's exactly it - the fan cuts in but doesn't seem to be able to bring the temperature down.
MrKitty is offline
post #4 of 6 (permalink) Old 20-04-2017, 09:40
johnan's Avatar
If the system has not been properly bled then that would be the first thing I would do, or get done.
As yet I have not done it myself but I am sure there are plenty of forum members who can give detailed advice on doing it.
There are other indicators of HGF like oil emulsification or deposits in the coolant tank, or persistent coolant loss. It is too easy for garages to blame all ills on gasket failure, although that is always a possibility.
johnan is offline
post #5 of 6 (permalink) Old 20-04-2017, 11:50
'Pain in the arse to get to'? Yes, one has to take off the engine cover to get to one of the three but such is life. For a MG specialist not to be bothered is a disgrace. What else cannot they be bothered doing properly...? Stop using them is my advice!
IanMc likes this.
Julian Foulger is offline
post #6 of 6 (permalink) Old 20-04-2017, 12:15
Have you confirmed the rad fan actually does cut in? I've had such an overheating problem with fans not working (could be fan, wiring or switch). Obviously, also check bleeding has been done properly as well.
overheating issue Bertl MGF and MGTF (Sponsored by MGFnTFBITZ) 25 11-04-2014 18:51
Overheating Issue! Minty86 MGF and MGTF (Sponsored by MGFnTFBITZ) 6 05-03-2014 09:35
Overheating issue jaythompson MG ZR / Rover 25, 200 & Streetwise 3 02-02-2014 17:27
Overheating issue :( Penrhyn Plodder MG ZR / Rover 25, 200 & Streetwise 4 08-05-2013 17:21
Overheating Issue boothy72 MG ZS / Rover 45 & 400 3 18-06-2009 16:28
