Back to basics How To-No. 1: Replacing headlamp bulb (MGF) - MG-Rover.org Forums
post #1 of 7 (permalink) Old 25-01-2009, 16:26 Thread Starter
Car: MGF MK2 1.8i,BMW 330i
Many how tos on here are for mechanically minded folks, and some people simply dont want to do anyhting complicated themselves. However I am still amazed that people still pay their hard earned kids inheritance to the monkeys in Halfrauds to fit a bulb, or wiper blades etc.
So this is how to change a headlamp bulb on an MGF.
Time to complete: about 2 -3 minites per bulb, if that.
Difficulty: 0 (its just not difficult)
Now I have trophy headlamps, and either that means they ahve different bulbs from standard, or it just means Halfrods catalogues are completely wrong, becuase the recommend the wrong bulb for me!!
Anway for my car, its H1 (448).
OK, so you need to open bonnet (pull handle in the top right hand corner of your boot).
This is what the headlamp looks like. To the right, the large white textured glass lens is the dipped beam. To the right, is the full beam, and the small white LED bulb is the side light (yours will most likely be a proper bulb)
Behind the lamp, is a black plastic circular protector. This screws off (to the right), but may need a little persuasion to pull it off (had to push mine with a screwdriver as it had stuck)
Once this is removed, you will see some wires. Yellow, attached to bulb, and the black attaches to the housing.
Remove these wires and you will see a metal clip with "rabbit ears" at the top. Push the ears apart and the clip can be removed. The bulb can now be pulled out and reaplced with a new one (it only goes in one way due to the uneven shape of the bulb base).
DO NOT touch the glass of the new bulbs with fingers as grease will transfer to bulb. It is easy to do with just holding the base.
Replace clip and do all in reverse.
The full beam bulb and sidelight bulbs are behind the second black protector. Full beam lamps are removed and fitted in the same way as dipped.
Sidelight bulbs simply pull out and push in. Side lights are 501 bulbs (or you can use LED 501 style).
Broon is offline
post #2 of 7 (permalink) Old 25-01-2009, 16:35
Car: MG TF 160
I can see this being useful for a lot of people! well done! now we just need a TF one! Bulbs are similar to replace but the side lights are a little fun!
Reaper is offline
post #3 of 7 (permalink) Old 25-01-2009, 16:36 Thread Starter
Yeah, I dont know about the TF ones, but someone can add it here, or start Back to Basics number 2!
Broon is offline
post #4 of 7 (permalink) Old 25-01-2009, 16:59
Good post Broon
MGFmad is offline
post #5 of 7 (permalink) Old 20-05-2010, 14:12
Very useful, thanx
Klaus67 is offline
post #6 of 7 (permalink) Old 20-05-2010, 14:40 Thread Starter
Originally Posted by Klaus67 View Post
Very useful, thanx
Hopefully better now I have fixed the links for the images
Broon is offline
post #7 of 7 (permalink) Old 20-05-2010, 15:35
Car: mgf 1.8 vvc, volvo s40.
i might post a back to basics how to for the female members.....green or black handles in the petrol station....
lol...
xmgf is offline
Back to basics (plzzzzzzzz).... Seyley In-Car Audio, Entertainment, Sat Nav etc... 13 13-08-2007 12:28
Headlamp Bulb ? sie1uk MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 27-01-2007 02:31
Headlamp Bulb Dicky MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 05-05-2006 10:41
MGF headlamp- which type of bulb? Broon MGF and MGTF (Sponsored by MGFnTFBITZ) 2 06-12-2002 19:13
BACK TO BASICS David Lee Newsham MG / Rover Related Chat - up to 2005 8 27-02-2002 06:51
