Best Earth Point? - MG-Rover.org Forums
post #1 of 16 (permalink) Old 29-10-2010, 10:33 Thread Starter
Send a message via MSN to coleman758
Best Earth Point?
I have just got a new amp for my sound system, Its going behind the passenger seat. Were would you say the best earth point would be?
coleman758 is offline
post #2 of 16 (permalink) Old 29-10-2010, 10:42
Car: MGF 1.8MPi
Send a message via Skype™ to jordimussol
Passenger seat railing screws. No need to drill any new holes and it's just there.
jordimussol is offline
post #3 of 16 (permalink) Old 29-10-2010, 14:04
Car: MGF 1.8 VVC/ Peugeot 106 Rallye / Ford Focus TDCi Sport
I think Liverpool is one of the best Earth points...
r1chs is offline
post #4 of 16 (permalink) Old 29-10-2010, 15:12
Banned
I would very seriously consider upgrading the front battery earth to body cable, it is very small as it is. It is a big bottleneck in the current return path and will strangle the output from the amp.
Anything other than a small RMS amp will need this doing, plus the positive feed from the battery to alternator and the engine to body earth cable will need upgrading. An alternator from the 25 derv and a bigger battery would be a good thing too as all the standard wiring and charging circuit components are not enough for keeping a decent output amp fed with all it needs.
andycolm is offline
post #5 of 16 (permalink) Old 29-10-2010, 15:17
Depending on how big the amp is then yes a definite +1 on the above. You might also consider a few big 1 farad caps - they give you a sporting chance of the instantaneous current delivery you need for nice punchy bass.
g7nbp is offline
post #6 of 16 (permalink) Old 29-10-2010, 15:20 Thread Starter
its 1200watt four channel
post #7 of 16 (permalink) Old 29-10-2010, 15:26
PMP or RMS?
Either way I would go with bigger battery. (Most of the Serious ICE boys go for a dedicated battery and a split charge system).
Best tip is try it and see - if your headlights dim in time to the beat you need a bigger battery and probably a few chunky capacitors to help you through the lumps! (and matching alternator if you put a bigger battery on of course)
g7nbp is offline
post #8 of 16 (permalink) Old 29-10-2010, 16:14
Banned
Its going to be peak. Upgrade your wiring first, then alternator maybe.
A power cap s the worst thing you can put into your power supply, it actually puts more strain on the charging system with the extra drain needed to recharge the cap whilst doing nothing for the amp supply. A bigger battery could be needed, but definatly upgrade your wiring.
The easiest test is count the amps the fuses on the amp add up to, then consider your altenator is probably around a 45amp output in total, take away what your lights use, what your wipers use, and what your engine electronics use... There's very little spare. When your lights dim it's the alternator and battery failing to keep up with demand, this leads to voltage drop which send the amp into clipping whic can blow amps and speakers.
andycolm is offline
post #9 of 16 (permalink) Old 29-10-2010, 16:27
Car: TT MGF #0002
Hmm, all interesting to read. Never had any battery or alternator problems on my F with the amp, sub and nitrous bottle heater running all the time...
gotenks1321 is offline
post #10 of 16 (permalink) Old 29-10-2010, 16:29
Car: TF 135 Sprint
Send a message via MSN to sniperpenguin Send a message via Skype™ to sniperpenguin
This may seem an odd Q, but how do you upgrade an alternator? Never seen an uprated version of the standard OEM spec, even on aftermarket....
sniperpenguin is offline
post #11 of 16 (permalink) Old 29-10-2010, 16:38
Car: MGF VVC, MGFT (turbo), MG ZS, Rover 620Ti and Rover 45
The "BEST" earthing point will be the negative terminal of the battery, otherwise any good fixing screw that's not rusted on the chassis
Cossy Abuser is offline
post #12 of 16 (permalink) Old 29-10-2010, 16:41
Andy - No disrespect but I disagree. Yes the cap bank takes extra energy during its non-peak charging cycle, but allows delivery of high current without voltage dips on peak demand - far more so than a battery which is 8 foot away via sub-optimal wiring.
Depending on what type of music is being played the demand ratio usually favors the slow charge, occasional peak discharge scenario that a suitable capacitor bank provides.
If anything adding a cap bank provides protection from damage likely to be encountered from "clipping unders"
I could trot out the maths - but there is a frequently quoted article that saves me the time : http://www.caraudiohelp.com/newslett...citor_myth.htm
g7nbp is offline
post #13 of 16 (permalink) Old 29-10-2010, 16:44
I still don't understand why people want mega watts of music, There's enough power in the standard radio isn't there. If you spend money on amps, speakers, capacitors, head units................. you could make the car go faster or handle better
Just me ranting as I am getting old and starting to listen to Radio 2 hahahahaha
post #14 of 16 (permalink) Old 29-10-2010, 16:48 Thread Starter
I'm the opposite, because of cost on insurance I can't go stupid but I enjoy music! It's not for the loudness more so for the quality
post #15 of 16 (permalink) Old 29-10-2010, 16:57
Car: TT MGF #0002
I like to be able to still listen to mine when i'm driving down the motorway with the roof down. Then again I've spent a lot more on engine, suspension and brakes than I have on audio anyway
post #16 of 16 (permalink) Old 29-10-2010, 17:12
Banned
Just when you thought tyre threads on here were controvertial
I sit on the side that says you would be far better off with a second battery for the money as they are far more effective than caps.
FAQ for car audio power supply questions http://www.talkaudio.co.uk/ipb/index...-power-supply/
andycolm is offline
Converting a single point to a multi point injection? foxracing1989 'R8' Rovers (aka Wedges!!) 2 28-06-2010 19:44
electrics earth point mrbishi75 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 08-11-2009 10:59
Earth point under seat? AliB MG ZR / Rover 25, 200 & Streetwise 8 16-05-2008 23:47
Earth Point on Mk3 200 rsymes97 MG ZR / Rover 25, 200 & Streetwise 1 04-06-2004 19:17
multi point or single point injection 8valver MG ZR / Rover 25, 200 & Streetwise 16 25-01-2003 18:47
