Big Rear Brakes - MG-Rover.org Forums
post #1 of 13 (permalink) Old 10-07-2007, 08:22 Thread Starter
Car: MGF Trophy 160, MG ZS180
Big Rear Brakes
Vehicle Handling Solutions have just released their 266mm rear disk mod. Its been in development for a while but I believe they had problems sourcing the disks. It uses the existing calliper with a new disk and calliper support bracket.
At Castle Coombe, Dave was sporting the first set out of their workshops. Haven't spoken to him to find how he felt about them by the end of the track day but the big disks at the back sure looked good
Tim. is offline
post #2 of 13 (permalink) Old 10-07-2007, 08:54
First impressions are good Tim, I spoke to Dave about them after and he said he certainly noticed the difference..
For general road use its probably not worth it as you really won't see the benefit but for extreme track use, its now on my to do list.
Stu
PS Cracking day yesterday, I've even got a little sunburnt
my old flame is offline
post #3 of 13 (permalink) Old 10-07-2007, 12:14
Car: MGF VVC
Any ideas of costs?
Is it just a caliper/carrier/disc upgrade - or more substantial?
Stampy is offline
post #4 of 13 (permalink) Old 10-07-2007, 12:17
how hard are the disks to source i.e. are they a standard fit to car x or are they custom size. If custom replacing them could become expensive...
TF160SA is offline
post #5 of 13 (permalink) Old 10-07-2007, 12:20 Thread Starter
Not cheap but how many of theses limited volume mods are.
NEW for 2007 - our MGF and MGTF big rear brake kit provides a pair of 266mm discs, brackets and fixings to allow the use of your standard calipers, thereby retaining the handbrake. Greater performance and better thermal capacity with style! Complete kit 340+VAT (Replacement discs 80+VAT/pair)
Yes, just a disk and carrier upgrade allowing the pads to work at a larger radius for more torque and better cooling.
Tim. is offline
post #6 of 13 (permalink) Old 10-07-2007, 12:36
you'r not kidding thats a 260 pound bracket and fixing!! but i'd still do it...
TF160SA is offline
post #7 of 13 (permalink) Old 10-07-2007, 12:51 Thread Starter
LOL, yes a 260 bracket if you look at it that way - well actually two 130 brackets I suppose
Correct the disks are single source. I suppose, in a way, its good of them to have apparently put the development cost onto the one off purchase bracket rather than load the replacement disks.
Tim. is offline
post #8 of 13 (permalink) Old 10-07-2007, 13:27
I wonder how this will affect the ABS?
TF160SA is offline
post #9 of 13 (permalink) Old 10-07-2007, 13:33 Thread Starter
It shouldn't affect the ABS, there are sensors on all 4 wheels.
As the rear brakes are the same irrispective of front brake setup. Seems a logical plan for those with APs and grooved front disks to restore a bit of the originally designed balance.
TBH most of the braking effort is from the front wheels anyway because of the weight shift.
Tim. is offline
post #10 of 13 (permalink) Old 10-07-2007, 20:25
Will it not affect brake bias at all? I always understood big rear brakes to be a no-no for this reason
LuCkY is offline
post #11 of 13 (permalink) Old 10-07-2007, 21:07
Car: 320d SE Touring
Yep. Definately agee you don't wanna be putting these on your rears with standard fronts..
Just to make that clear..... that is NOT a good idea!
NandoDave is offline
post #12 of 13 (permalink) Old 10-07-2007, 22:08 Thread Starter
Yes, indeed, thanks for spelling that out. Maybe my post didn't emphasize that enough. Even then it will affect any trail braking you might want to be doing.
Tim. is offline
post #13 of 13 (permalink) Old 10-07-2007, 22:15
Car: MG ZT 260 SE V8
You'd have to be a bit daft to upgrade the rears before the fronts though anyway
James C is offline
Big Brakes Joemasini Diesel Forum! 5 04-04-2008 18:15
Big brakes, front and rear! ThumpJunkie Wanted 21 29-07-2006 16:57
big brakes JFV MG ZR / Rover 25, 200 & Streetwise 4 10-06-2006 00:07
big brakes john1234 MGF and MGTF (Sponsored by MGFnTFBITZ) 10 29-11-2005 18:41
Big brakes? Roverdose MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 30-06-2004 08:02
