boot lid grommet part number - MG-Rover.org Forums
post #1 of 10 (permalink) Old 13-04-2017, 17:54 Thread Starter
On later MGFs there were 4 grommets installed in holes in the boot lid 'frame' to stop water ingress to the boot. What is the part number of these grommets? I would like to add them to my N-reg F.
mowog73 is offline
post #2 of 10 (permalink) Old 13-04-2017, 18:10
Stuck in the 80's...
Just checked my Rimmer Bros parts catalogue - it doesn't show any rubber grommets?
Are you sure they were not just added by someone to cover some holes drilled in error?
IanMc is online now
post #3 of 10 (permalink) Old 13-04-2017, 18:24
Rimmer Bros. Page
MGF and MG TF Plugs and Grommets at www.rimmerbros.co.uk
follow this link and you will see all grommets etc.
you can then figure out what the part is that you are looking for.
Hope this helps.
moirasrevor is offline
post #4 of 10 (permalink) Old 13-04-2017, 18:44
Just so happen to have access to 4 I took out of a TF boot lid which someone I know was scrapping for my F. Unfortunately, there are no part numbers on any of them.
However; I have taken some pics of what they look like which are below. As long as you get some blanking grommets the size of the holes (20mm I think) you should be ok.
30mm outer diameter
25mm inner diameter (I think)
dert is offline
post #5 of 10 (permalink) Old 15-04-2017, 05:35
That's very interesting dert.
Just went and check my '95 F and sure enough there are 4 Off, 2 per side, dia. 20 mm holes in the reinforcing skin of the boot lid. I had never noticed those before.
I am a little uneasy at the prospect of filling those up though as they appear to allow water to drain away if becoming trapped inside the 'skin channels'. (As best I can see/judge, the outer two holes would drain down the side of the boot seal, down the back of the car. While the inner two holes would appear to let water drain into the engine bay from above.
Its very interesting to learn that these might have been fitted to the TF as standard though.
Can anyone verify this, or have previous owners just preferred the look of a filled hole over a seemingly useless hole?
As I said above, I cant see anything in the Rimmer parts catalogue for either the F or the TF.
IanMc is online now
post #6 of 10 (permalink) Old 15-04-2017, 09:53
It's not just the TF's they are fitted to, My 1999 models have them fitted as well. looks like it was just the early ones they were not fitted to as my 1996 F's haven't got them either.
dert is offline
post #7 of 10 (permalink) Old 15-04-2017, 10:07
Took some pics of boot lids,
the first two pics are both 1999 models (Anthracite and Mulberry), the third pic is my early 2003 TF which still has the same grommets as the F. The forth pic which is a late 2003 TF still has grommets but a different style....which until today I'd not noticed the difference.
dert is offline
post #8 of 10 (permalink) Old 15-04-2017, 10:33
Mmmm, strange one that.
Nice boot lid photos though lol
Just a thought, could it coincide with the addition of the high level brake light?
IanMc is online now
post #9 of 10 (permalink) Old 15-04-2017, 10:39
May well be a possibility
dert is offline
post #10 of 10 (permalink) Old 15-04-2017, 11:44
What about this one: Plug-blanking - Genuine MG Rover at www.rimmerbros.co.uk
Since Rimmers have it on stock you can phone them and ask to measure a diameter for you in acordance to dert's measures.
zs boot lid daryl1104 MG ZS / Rover 45 & 400 7 16-02-2014 03:28
Boot Lid geo29 MGF and MGTF (Sponsored by MGFnTFBITZ) 3 06-03-2013 11:43
F........ Boot Lid CP53 MGF and MGTF (Sponsored by MGFnTFBITZ) 8 15-02-2012 20:29
MK 2 Boot Lid RickZRTD MG ZR / Rover 25, 200 & Streetwise 36 09-04-2009 22:30
will this part fit, PART NUMBER ~ TRC102660N liamfleming MGF and MGTF (Sponsored by MGFnTFBITZ) 12 19-03-2008 22:06
