Compression Test - 1.8i 135 - MG-Rover.org Forums
  • 1 Post By dert
post #1 of 3 (permalink) Old 16-02-2017, 14:38 Thread Starter
Ok i've done a quick compression test on the engine to see if there's anything amiss.
The figures I got were as follows listed in BAR(max)
Cyl1: 13.5
Cly2: 13.5
Cyl3: 14.0
Cyl4: 12.5
The tolerance listed by Rover should be within 1.5 BAR of each other which is JUST about getting away with it.
Testing Cyl4 with a bit of 5w30 oil I got the pressure to shoot up to 17BAR so I suspect it is just general wear on the rings and liners causing blow by.
Do these figures match up with what other people have come across or does anyone WITH ACTUAL KNOWLEDGE AND EXPERIENCE have any insight to anything I should be aware of.
There hasn't been any symptoms of HGF since driving this car in the last 1000 miles besides a separate overheating issue that is now resolved.
I'm just wary of what the heat might have done to Cyl4 as it's often the weakest one on the gasket.
Stargatemunky is offline
post #2 of 3 (permalink) Old 16-02-2017, 20:07
not done a compression test yet as still need to replace timing belt on my one that stripped teeth, but did come across this video
Stargatemunky likes this.
dert is offline
post #3 of 3 (permalink) Old 16-02-2017, 20:47 Thread Starter
That's the same exact compression gauge i've been using!
Compression Test MR (Z)T MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 02-04-2011 11:59
compression test! Ti CLARK Rover 600 3 25-03-2010 22:10
Compression Test Axelrodi MG ZR / Rover 25, 200 & Streetwise 17 27-11-2009 11:49
Compression test MGFadam MGF and MGTF (Sponsored by MGFnTFBITZ) 11 29-01-2009 22:20
Compression Test andywhitehurst Others 6 28-04-2005 14:59
