CRITICAL UPDATE on TF Led Interior LED Lighting - MG-Rover.org Forums
post #1 of 35 (permalink) Old 09-02-2011, 18:33 Thread Starter
Car: ASTRA CABBY
Exclamation CRITICAL UPDATE on TF Led Interior LED Lighting
HI ALL
with ref to TF Led Interior LED Lighting
i purchased a TF clock and oil temp gauge for my f to do blue led back light
any way read the attached how to and made a discovery that you don't need to put any resistors on the clock or oil gauge as they already have them on (i just traced the circuit with a DMM)
if you use LED'S with 30mA max current then you will be fine
so here is the proof
the 475 ohm resistor on the pcb for the original LEDs (clock)
LEDs fitted 3mm 30mA 30deg angle 3000mlcd
LEDs working on 13.5v supply
here is the oil gauge resistor
here is the LEDs fitted (same as the clock) and polarity of the LEDs
so there you have it just solder the LEDs the correct way round so no more fiddly fitting the resistor
hope this helps
mark
MGF MARK is offline
post #2 of 35 (permalink) Old 09-02-2011, 18:35
Unless of course you find the leds are too bright, and then you pop a resistor on
jrproudfoot is offline
post #3 of 35 (permalink) Old 09-02-2011, 18:36
Car: MG TF 160 - Pearl Black
Nice - I knew you would figure it out mate!
You need to edit your picture links so the [img] after each one is [/img] (there's a sneaky foward slash in there!)
Will reply to your PM after dinner too matey.
Kameleon is offline
post #4 of 35 (permalink) Old 09-02-2011, 18:44
Mark, did you get the spare instrument cluster you were after????
Pendle Lass is offline
post #5 of 35 (permalink) Old 09-02-2011, 18:48 Thread Starter
Car: ASTRA CABBY
hi
i found that the slightly brighter leds give a more clear colur
ill send you the part number
i work with leds ect all day so have a wide selscton to play with
you can also get lower brightness with 30mA rated ones
ill go and get a photo of the oil gauge in the dark
MGF MARK is offline
post #6 of 35 (permalink) Old 09-02-2011, 18:50 Thread Starter
Car: ASTRA CABBY
not yet ran out of cash on other projects
perhaps next month
looking to do an extra lcd display with clock and temp (inside the car outside and engine bay temp)
MGF MARK is offline
post #7 of 35 (permalink) Old 09-02-2011, 19:11 Thread Starter
Car: ASTRA CABBY
hi this is what it looks like in the dark
MGF MARK is offline
post #8 of 35 (permalink) Old 09-02-2011, 19:20
looking good, remind me to get you to do mine in red lol
pwatts1977 is offline
post #9 of 35 (permalink) Old 09-02-2011, 19:24 Thread Starter
Car: ASTRA CABBY
i have the same LEDS in red
but you need TF clocks to do it so yep ill do them for you no probs
the old F clocks will not give an even light over the face
i have tryed several ways of doing the f clocks to save buying the TF clocks
i paid 14.00 inc post for these
MGF MARK is offline
post #10 of 35 (permalink) Old 09-02-2011, 19:26
... and I have found that the red needle can be a little difficult to see so I have removed some of the red paint from the tip to allow the blue light to show up a bit more.
Still not great but an improvement
djp66 is offline
post #11 of 35 (permalink) Old 09-02-2011, 19:34
perhaps next month
give me a shout I have one I dont think I need, all I want to do is back light with LED and think its pretty straightward, no needles on the instruments though as I have removed them for possible future needs
If you do manage to change the lighting of the mileage bit thought, thats the cost of the cluster ...........
post #12 of 35 (permalink) Old 09-02-2011, 19:43
if i have a mk2 mgf does that have the same clocks as the tf
post #13 of 35 (permalink) Old 09-02-2011, 19:54 Thread Starter
Car: ASTRA CABBY
hi nope you are in the same boat i was in you will need to get some clocks
if you do get them post to me and ill do them asap
MGF MARK is offline
post #14 of 35 (permalink) Old 09-02-2011, 20:03
Car: 99 MGF & Alfa Spider LE
Hi folks!
Can I just say that I am amazed that the ntlworld webpages are still live - I left NTL/Virgin ages ago!
I've not been around much for various reasons, but wanted to point out that I think PeteVick has a copy of my webpages on the central pages.
I'm chuffed my old guides are still sort of useful.
Bob is in for a new clutch - ouch. He is green LED at the moment, Loaky has my blueness!
Well done Mark on a great thread.
Iain R.
iaross is offline
post #15 of 35 (permalink) Old 09-02-2011, 20:50
Hi Iain, how's it going matey ??. I have indeedy got a copy of your web - http://www.mgf-tf-central.co.uk/iainross/index.html
post #16 of 35 (permalink) Old 10-02-2011, 19:23 Thread Starter
Car: ASTRA CABBY
thanks Ian R for the kind words
just continuing what was started
also adding some extras like washer bottle liquid level and washer bottle heater so no frozen washers in winter
MGF MARK is offline
post #17 of 35 (permalink) Old 10-02-2011, 20:22
Car: MGF VVC
Iain R.
Don't forget about me mate
Stampy is offline
post #18 of 35 (permalink) Old 10-02-2011, 20:25 Thread Starter
Car: ASTRA CABBY
sorry
MGF MARK is offline
post #19 of 35 (permalink) Old 11-02-2011, 11:41
Hiya :o) hope you are well - I posted a new thread to save hijacking this one.
iaross is offline
post #20 of 35 (permalink) Old 11-02-2011, 19:08 Thread Starter
Car: ASTRA CABBY
hi
had a thought
as the blue leds dont show the pointers you could put a red led in the middle to give the pointer a different color
ill try this on sunday and post new thread
MGF MARK is offline
TF Led Interior LED Lighting jrproudfoot MGF and MGTF (Sponsored by MGFnTFBITZ) 51 20-05-2013 11:49
Mg tf interior mirror with led map lights!! 218VVC For Sale 7 15-06-2010 20:30
Led boot lighting Dave MG ZR / Rover 25, 200 & Streetwise 49 21-03-2010 22:42
LED Boot Lighting Randyjim MG/R Modification & Tuning 14 14-03-2010 19:37
Fitting Interior LED and lighting Chris Co MG/R Modification & Tuning 38 16-03-2005 18:25
