cutting out - MG-Rover.org Forums
post #1 of 5 (permalink) Old 07-07-2010, 21:25 Thread Starter
cutting out
got the cutting out prob put new temp sensor on new step motor second hand fuel pump still no joy fuel relay next see if that stops running out of things to change lol
davecmgf is offline
post #2 of 5 (permalink) Old 07-07-2010, 22:45
Did you fit a new IACV (idle air control valve)?
Otherwise, assuming an early MPI model, distributor cap, leads, rotor arm etc.
When does it cut out and is there a pattern to when it happens?
MGFmad is offline
post #3 of 5 (permalink) Old 08-07-2010, 05:15
Car: 55' mgzs+ 120
If its cutting out as you approach junctions etc then I would look at the Idle Control Valve. If its while you are just driving along then it could be the crank sensor.
simonruss is offline
post #4 of 5 (permalink) Old 08-07-2010, 19:32 Thread Starter
iacv
fitted brand new iacv 70 cuts out when driving some times will not start then it will and can drive around for ages turn it off start it again runs for 10 secs then cuts out tried second hand fuel relay would not start at all new one i think
davecmgf is offline
post #5 of 5 (permalink) Old 08-07-2010, 19:39 Thread Starter
icv
crank sensor ok new icv 70 think it could be fuel relay
davecmgf is offline
Still cutting out Matron MG ZR / Rover 25, 200 & Streetwise 33 21-12-2008 11:34
Sub Cutting Off SEi_16v In-Car Audio, Entertainment, Sat Nav etc... 5 23-04-2007 10:16
Keeps Cutting Out ! Videoman MG ZS / Rover 45 & 400 28 27-07-2006 23:21
Keeps Cutting Out !! Videoman Others 0 22-02-2006 18:29
cutting out phil.a Others 5 21-02-2003 06:48
