Downpipe recommendations - MG-Rover.org Forums
post #1 of 21 (permalink) Old 31-03-2017, 07:47 Thread Starter
Car: MG ZR + MG TF160 + Fiat coupe 20VT "PLUS" + Ford galaxy
I have a TF160 with a 6 nut downpipe blowing on the flexi section, I know it will be an MOT fail next week.
What is the generally accepted way and where to buy one of these anyway?
I won't be asking quicktwits or any of those outlets.
Ebay have a "genuine" oe one for 100 and other generic makes are 80.
Are the ebay ones ok or is there a better make or brand people use and if so where?
many thanks
Mr-Tickle is offline
post #2 of 21 (permalink) Old 31-03-2017, 08:04
Car: 2002 MG TF 160
Why not invest in a proper 4-2-1 manifold from Mike Satur or Janspeed?
Sergi Bmw is offline
post #3 of 21 (permalink) Old 31-03-2017, 09:42
Last one I bought was off ebay and was the cheapest I could find, not had a problem with it and its been on a few years now
dert is online now
post #4 of 21 (permalink) Old 31-03-2017, 09:57 Thread Starter
Because its too expensive.
post #5 of 21 (permalink) Old 31-03-2017, 09:58 Thread Starter
OK, Ebay it is then. thanks
post #6 of 21 (permalink) Old 31-03-2017, 10:42
Car: TF160 2003
Did mine a year ago for the same reason- flexipipe broken. Replaced the back box at same time and retained the cat. Took nearly a full but satisfying day and all new joints and stainless-steel nuts/bolts/washers required. i had to cut and grind off nuts from back box/cat and carefully re-use the bracket that ties the car and back-box together. I brought an OEM back box and aftermarket down pipe. The fixings/nuts came off this ok and you need a decent spanner to remove the pre-cat lamda sensor. You will have to drill out the remnants of the bolts from the cat- ok if you have a pillar-drill as you must drill 'on center'
A year on and 6k miles- no problems.
Other modes of transport.
Range Rover Sport
Triumph Explorer
Yamaha R1
Honda 400/4
Mobylette V40
Mobylette Cady
PatM is online now
post #7 of 21 (permalink) Old 31-03-2017, 21:10
Have you seen the price of these?
post #8 of 21 (permalink) Old 31-03-2017, 21:59
sundanceuk's Avatar
Car: MG TF 160
I got mine for my 160 from MGFnTFbitz along with a TT Mk7 box think it was about 70 and its stainless steel. Had to replace it as the flexi had gone. TT Mk7 was 300
Sundance
sundanceuk is offline
post #9 of 21 (permalink) Old 31-03-2017, 22:42
If its just to pass an MOT, this one on eBay might be okay - flex looks in good condition, also includes a manifold, silencer and llambda (which you might not need) but for the price, it ain't bad for a quick fix.....
MGFT / MGF Exhaust inc Manifold, Down pipe etc, Ideal Spares, needs ? No Cat | eBay
Otherwise, if you want to spend more for new, there are better options. For a bit more, you could get a stainless steel Toyosports (eBay) which is what I did when my OEM stuff died........
steviejones133 is offline
post #10 of 21 (permalink) Old 01-04-2017, 15:17
Woof Woof
Why not see if you're local motor factors has or can get you one?
barkingdog is offline
post #11 of 21 (permalink) Old 03-04-2017, 07:09 Thread Starter
I have purchased the genuine OE one from ebay, a bit dearer that generic one plus a full gasket and bolt kit as I'm expecting it will be an angle grinder job to get the bolts off.
When my rear silencer fails as I expect it too sometime soon, I will be buying A TT exhaust
they sound awesome, but I'll keep the cat on (Changing it twice a year for an MOT is too much effort )
Many thanks.
IanMc likes this.
post #12 of 21 (permalink) Old 14-04-2017, 20:55
TT MK7 ....Wise choice, I have one and it sounds absolutely fantastic. I just fitted a decat pipe and it now pops and burbles on overrun, sounds superb!!! It's like driving a different car...Very civilised when pottering around, but when you boot it (especially in a tunnel) it sounds simply stunning, just like a sports car should sound!
esotericman1967 is offline
post #13 of 21 (permalink) Old 14-04-2017, 21:09
I also have a TT Mk7 silencer (coupled with my SS Toyo manifold and downpipe) and a normal cat - sound is very good and I think you've made a good decision. Some might say the TT is too loud - only if thrashed, I find. At full throttle, it really is a lovely sound......
post #14 of 21 (permalink) Old 14-04-2017, 22:17
Steve...Sounds great...I have Direnza manifold and downpipe, decat pipe, TT MK7/2, 52mm TB, Vortex cold air feed enclosed induction kit....Next month I'm going to fit a 25 shot wet system Nos...Can't wait 😁
post #15 of 21 (permalink) Old 15-04-2017, 17:38
Car: MGF VVC MK2
MS stuff is expensive, but is amazing.
DeathFromAbove is offline
post #16 of 21 (permalink) Old 16-04-2017, 22:39
Yep. I have the Mike Satur 4-2-1 manifold and the MS Daytona back box. More expensive than the TT, but some of us want quality over noise.
post #17 of 21 (permalink) Old 17-04-2017, 11:39
Get him!
post #18 of 21 (permalink) Old 17-04-2017, 15:59
Car: MGTF 135 2005
Me too and I agree entirely!
Mr Natural is offline
post #19 of 21 (permalink) Old 17-04-2017, 20:15
Price is not necessarily an indicator to quality, the TT is very much a quality made piece of kit. Better looking than the Daytona, too. Now, sound is very much down to the individual - up to you if you want to pay more for a quieter silencer but I don't think you can knock the TT in terms of quality for price. Different strokes for different folks, I guess.............
post #20 of 21 (permalink) Old 17-04-2017, 22:59
Now I have to disagree on that. There are quite a few complaints about the TT while not many about the Daytona.
It is down to personal taste, but generally, TT owners go on to explore other exhausts. Daytona owners tend to stick with what they have.
differences between mgf vvc manifold/downpipe and mgtf vvc manifold/downpipe ben zr td MGF and MGTF (Sponsored by MGFnTFBITZ) 7 07-03-2015 19:22
Manifold/downpipe recommendations BazR MG/R Modification & Tuning 9 19-08-2008 16:01
downpipe ramdonice Diesel Forum! 15 29-12-2007 19:14
Is 216si mk3 downpipe the same as a 214 mk3 downpipe? ashy MG ZR / Rover 25, 200 & Streetwise 4 10-02-2005 11:55
