Elusive misfire - MG-Rover.org Forums
post #1 of 5 (permalink) Old 27-07-2011, 16:46 Thread Starter
Question Elusive misfire
Took the car out for a short run after getting the gearbox sorted, and had another brief spell of misfiring. I've had this for years, and it occurs very infrequently, maybe only once or twice a year. I go to accelerate and it starts going brrrrr---brrrrrr---brrrrr like a series of intermittent cut-outs. I back off the throttle and hold speed on a gentle throttle for a spell, and it goes away. Fortunately it's never happened as I was attempting a brisk overtake - could be interesting=
Just back from a nice long run through the wilds of Ayrshire with wall-to-wall sunshine and about 24C (top down all the way, please note) and it didn't miss a single spark.
Over the years it's had new spark plugs, new distributor cap and rotor, new good HT leads and a new coil, and it still has this hiccupping fit when I least expect it.
Any ideas?
michaelcngm is offline
post #2 of 5 (permalink) Old 27-07-2011, 16:50
If the fuel flow is compromised, that could also cause a misfire.
Try replacing the fuel filter as the cheapest option moving onto maybe the fuel pump if fuel delivery is the problem.
colinjmatt is offline
post #3 of 5 (permalink) Old 27-07-2011, 16:50
Hey!!!
I don't know if this would help but when I had my tf she kept doing this for a while, it drove me mad! Sometimes it would even cut out! Normally in second gear x I don't know if this would help but someone told me and it worked x turn the ignition into position 2 and pump the accelerator 3 times then turn back to 0 then start the car up x
It really worked for me but again I'm not sure if it's exactly the same prob so see what everyone says x
Kem1 is offline
post #4 of 5 (permalink) Old 27-07-2011, 16:58
had a missfdire on my ZS that simply wouldnt go away, replaced plugs, coil packs, ignition leads and fuel filter, turns out in the end to be a loose connection to the ECU, gave it a wiggle and a push, has not missed a beat since
always worth a try, tis free and only takes 2 minutes, could save you alot of hassle
Furryroo is offline
post #5 of 5 (permalink) Old 27-07-2011, 16:59 Thread Starter
I've not tried the fuel side, but it's so infrequent I can't visualise what fuel fault would do it unless the pump goes on strike briefly. But why wouldn't it do it much more often? I sometimes wonder if it's external radio interference - my wireless bike computer usually finishes with max speed on the trip of 60+mph and my pulse meter can register 240 as a max, neither of which are remotely possible. I've not been able to check whether the misfire occurs at any particular location though.
Misfire Peter Carter MG ZR / Rover 25, 200 & Streetwise 2 12-07-2010 17:37
Misfire gabriel07 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 24-02-2009 17:16
The elusive Fuse 23... Mimik MG ZS / Rover 45 & 400 3 16-12-2008 12:22
Misfire nigel207 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 29-10-2007 12:47
