Fitting front upper ball joint - How to. - Page 2 - MG-Rover.org Forums
post #21 of 50 (permalink) Old 29-05-2012, 16:52 Thread Starter
Keep my fingers crossed for ya.
post #22 of 50 (permalink) Old 16-06-2012, 13:49
Did mine today, thanks clive good how to
I even tightened to the correct torque which is unusual for me
getting the old one off was a struggle even using my dads air impact gun, i think someone had been a bit over happy with the thread lock
Iain160Trophy is offline
post #23 of 50 (permalink) Old 16-06-2012, 15:19 Thread Starter
No more creaking?
At least you will get a better trade in when you get your TF.
post #24 of 50 (permalink) Old 24-03-2014, 13:34
Car: MG TF 160
I'm replacing my ball joints but it looks like I need to buy an impact wrench, before I do is there enough room to get a cordless into the rear arches to use on the ball joint? I don't want to buy the new 610Nm 'Toy' only to find its too big.....
Reaper is offline
post #25 of 50 (permalink) Old 24-03-2014, 16:30
Car: MG TF 160
Went home, jacked up the car and put a regular cordless in to check the available space, and I'm happy the new one should fit. So I've ordered my new impact wrench and will wait in anticipation!
Reaper is offline
post #26 of 50 (permalink) Old 24-03-2014, 20:00 Thread Starter
Sorry mate, just seen this, been working on mine today.
Clearance shouldn't be an issue, just be careful when using it. If it is difficult to undo and you don't have a good grip on the impact driver it can spin out of your hand and could possibly dent the bodywork from the inside. I only know this because it nearly happened to me.
post #27 of 50 (permalink) Old 24-03-2014, 21:08
Car: MG TF 160
Thanks for the heads up, although I'd hope the one I ordered has a clutch to stop me spinning around with it.... Got me thinking now!
http://www.onlinepowertools.co.uk/pr...-0ah-batteries
I have a 3' breaker bar to try tomorrow, but failing that It will have to wait for the new toy. I had to cut down the ball joints thread with a grinder because they were too tall for the deep socket, so I have to do it now! Although there are enough threads to get it onto a trailer if needs be...!
Another great how too btw might have to create a book, not a Haynes manual but a CJJ... Far more useful!
Reaper is offline
post #28 of 50 (permalink) Old 24-03-2014, 21:19 Thread Starter
I don't know. 300+ for the impact driver and you can't afford one of these?
post #29 of 50 (permalink) Old 24-03-2014, 21:24
Car: MG TF 160
That's the one I bought! On the rear ball joints it's not deep enough
Reaper is offline
post #30 of 50 (permalink) Old 24-03-2014, 21:34 Thread Starter
I wonder if you can buy deeper ones.
post #31 of 50 (permalink) Old 25-03-2014, 12:12
Car: MG TF 160
Speaking to some garages it seem that they 'customise' the one that we have by wielding a small cut down knuckle bar or socket to it.
I did find a 6" deep 46mm socket.... however its for oil rigs.... and they didn't state the price.
Reaper is offline
post #32 of 50 (permalink) Old 25-03-2014, 12:39 Thread Starter
They might not sell you it in case you go round undoing oil rigs.
post #33 of 50 (permalink) Old 25-03-2014, 13:52
Car: Rover 623 GSI
How strange as that is the same as one I bought and used to change the O/S/R one on "Blue 33".
plezier is offline
post #34 of 50 (permalink) Old 25-03-2014, 14:19
Car: MG TF 160
On an F? If so the F has the same top ball joints front and back but the TF has the same as the F on the front but taller ones on the rear.
Reaper is offline
post #35 of 50 (permalink) Old 25-03-2014, 16:53
Car: MGF 1.8 VVC
I was considering buying one of these then remembered the effing big socket I bought to undo the rear hub on my Honda VFR. Same size! Yahoo!
scot748 is offline
post #36 of 50 (permalink) Old 25-03-2014, 17:30
Car: Rover 623 GSI
Maybe .................... I only have F's so cannot comment on the TF ball joints.
plezier is offline
post #37 of 50 (permalink) Old 30-04-2014, 12:21
Car: MG TF 160 Monogram, Rover BRM, Ford Capri 2.8 Special
Here you go Clive
http://www.ebay.co.uk/itm/291127274241
Out of interest are the two oblong locking plates not used? I'm guessing that they are for another vehicle application?
Beetlefan is offline
post #38 of 50 (permalink) Old 30-04-2014, 16:30
Car: MGF Trophy 160, MG ZS180
That's strange. I think I have the same socket as everyone else and mine fits over the ball pin. Surely the top joints are the same front and back TF or F. I've even machined the front off mine to get rid of the internal chamfer and get a fuller engagement with the rather thin nut on the ball joint. Its important to get the pin upright so that it just enters into the 1/2" square.
EDIT
Ah, just noticed, mine has 'Laser' written on it.
Tim. is offline
post #39 of 50 (permalink) Old 30-04-2014, 17:59 Thread Starter
Originally Posted by Beetlefan View Post
Here you go Clive
Thanks for that. I think the squares are used on other cars.
post #40 of 50 (permalink) Old 30-04-2014, 18:08
Car: Freelander only as TF sold !
For some reason the rear TF balljoint is taller with a plain section - see here
http://www.ebay.co.uk/itm/3906901355...84.m1423.l2649
Guess it a geometry thing but makes the joint more expensive for sure !
EDIT
Ian M is offline
Trouble removing the upper front ball joint on TF xsduk MGF and MGTF (Sponsored by MGFnTFBITZ) 20 03-11-2012 18:13
Upper front ball joint... XR219 Rover 600 9 24-04-2011 22:36
Front upper ball joint socket size??? jimhorton1982 Metro / Rover 100 3 28-06-2010 20:14
Upper ball joint Chris T MGF and MGTF (Sponsored by MGFnTFBITZ) 9 21-07-2007 16:20
upper ball joint dreaddan Others 5 17-05-2006 07:49
