Fitting hardtop - MG-Rover.org Forums
 3Likes
  • 1 Post By IanMc
  • 1 Post By Mgwanderer
  • 1 Post By barkingdog
post #1 of 14 (permalink) Old 09-10-2016, 11:28 Thread Starter
Fitting hardtop
I've just invested in a hardtop for my MK2 MGF. Just wondering about peoples thoughts to whether it's better to fit it with leaving the soft top in place.
Doesn't the gathered soft top obscure rear view mirror?
Also it doesn't look like a hard job to remove soft top, any pointers to the best way to do it and any possible problems I may occur!
hammond is offline
post #2 of 14 (permalink) Old 09-10-2016, 11:59
Car: MGF VVC MK2
The HT is made to fit over the ST.
The ST will be compressed by the rear part of the HT, and will not hindrance your vie in any way.
It's very easy to fit and will change you car immensly (for the good)
DeathFromAbove is offline
post #3 of 14 (permalink) Old 09-10-2016, 12:04 Thread Starter
Thanks for that. So do I leave the soft top secured down with the existing clips then? Sorry for the questions but don't want to keep lifting HT off and on on trial and error!
hammond is offline
post #4 of 14 (permalink) Old 09-10-2016, 12:09
Car: MGF VVC MK2
* Unzip the plastic window (if you got plastic) or just fold ST if you got glass window
* Leave all other fittings in place
* Remove the aereal, in case ... (my GF broke it while giving me NON requested help...)
* Put the hardtop in line with windshield mount
** Everyone use a different technique, depending on your size and strength.
I simply lift the HT, myself, and put it straight on the car
* Be sure, if you have, to have you heated window plug free from the undercarpet, or you'll need to remove the HT again.
* Close first front catches
* then side catches
* Connect heated windshield plug
* DRIVE
post #5 of 14 (permalink) Old 09-10-2016, 15:15
Stuck in the 80's...
Whats a hard top?
Bobert likes this.
IanMc is offline
post #6 of 14 (permalink) Old 10-10-2016, 06:55
I think its what they call a Saloon Car
Originally Posted by IanMc View Post
Whats a hard top?
IanMc likes this.
Mgwanderer is offline
post #7 of 14 (permalink) Old 10-10-2016, 06:59
Woof Woof
Only if it has a boot.
IanMc likes this.
barkingdog is offline
post #8 of 14 (permalink) Old 10-10-2016, 10:06
Easy 5 minute job to put on or take off (10 if you stop for a brew half way through). Can be done on your own but much easier / quicker / safer with two. Transforms the inside into a lovely snug place to be in the cold. Car looks surprisingly different with it fitted. With the right colour very pretty. In effect two cars for the price of one. Well worth it IMO.
Steve_G is offline
post #9 of 14 (permalink) Old 10-10-2016, 15:42 Thread Starter
Yep it was pretty easy to fit and with a nice new lining it does feel very snug.
I was under the impression the heated screen would work once plugged in but do I need the upgrade kit with relay etc?
Mine is a 2001 Freestyle MGF
hammond is offline
post #10 of 14 (permalink) Old 10-10-2016, 16:32
It has a boot!!!!! and lots of tiny places up front to hide your smalls
post #11 of 14 (permalink) Old 10-10-2016, 19:26
Car: MGF VVC MK2
I don't have anything small.
post #12 of 14 (permalink) Old 10-10-2016, 20:32
Whats a hard top?
My MGF has a boot......
post #13 of 14 (permalink) Old 10-10-2016, 20:38
You will need the switch and relay, all the wiring is in place.
post #14 of 14 (permalink) Old 10-10-2016, 21:26
Er...... Don't you mean Coupe?
Steve_G is offline
Hardtop fitting???????? melliott MGF and MGTF (Sponsored by MGFnTFBITZ) 11 05-02-2016 07:02
Hardtop fitting NewtoTF MGF and MGTF (Sponsored by MGFnTFBITZ) 6 12-01-2015 10:39
Hardtop fitting p38beast MGF and MGTF (Sponsored by MGFnTFBITZ) 11 24-10-2013 10:49
Fitting hardtop... Callum_T MGF and MGTF (Sponsored by MGFnTFBITZ) 19 17-10-2013 18:03
Hardtop Fitting vamoursly MGF and MGTF (Sponsored by MGFnTFBITZ) 14 21-06-2013 16:46
