Fitting new springs and dampers - How to - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
post #1 of 44 (permalink) Old 07-08-2011, 00:56 Thread Starter
Well, I have just replaced my suspension for the Mike Satur blue kit.
The problem I had was a knocking from the front due to a worn shocker bush. I could have changed the bush but the shockers were looking a bit rusty.
Whether you are changing your suspension due to a faulty part or just because you want to upgrade to better or adjustable suspension, here is how I did mine.
Start by clearing out the under bonnet area.
Unbolt the horn and move it clear of the suspension top nut and move the ABS connector out of the way.
Also, unbolt the under bonnet fuse box moving it clear of the nearside top nut. Also unclip and move the ABS connector.
Using a wire brush or wire drill attachment, clean the top nut threads as much as possible to remove any rust etc. This will help when you remove the top nuts.
And spray with penetrating oil.
Next, loosen the wheel nuts and jack up the front of the car until the wheels are clear of the ground. Secure with axle stands and remove the wheels.
Now clean the threads of the bottom bolt
And apply penetrating oil.
Returning back to the under bonnet area, place a 17mm spanner on the top nut and hammer a 5mm Allen key into the top of the suspension strut. Most standard shock absorbers will have an Allen recess in the top, some may have a square top, in which case you need to use another spanner to hold it.
Loosen the top nut, but do not remove at this point.
Hammer a 15mm socket onto the lower bolt
And using a breaker bar and a length of tubing, if you have it, slowly tighten the bolt until you feel it move slightly. Yes, that’s right, tighten it. This breaks the bond with the thread and allows you to loosen the bolt. I have used this method for as long as I can remember and it works 99% of the time.
Once the bolt moves slightly you can use the breaker bar and tube to loosen the bolt. When the bolt is loose enough you can use a ratchet to further undo the bolt.
Do not fully remove the bolt yet.
Remove the top nut and washer. Do not lose the washer as they are difficult to get.
Now fully remove the bottom bolt
And knock the bottom of the shocker sideways to free it from the upper suspension arm.
Beware that the suspension unit may drop now and is quite heavy for its size.
If it doesn’t drop then you may need to tap the top of the unit with a hammer.
Drop the unit down and when the top of the suspension unit clears the tower, pull it out towards you and lift the unit clear.
Repeat at the other side of the car
I had to use the old trick of linking 2 spanners to get enough leverage to remove the nearside top nut.
Once both front units are removed you can start to strip them down as there are components that you need to remove and fit to your new struts.
Remove the large rubber cover off the top of the spring.
Now fit your spring compressors and wind them on to compress the spring. This will take the tension off the retaining nut.
Using the 5mm Allen key and a 14mm spanner, loosen and remove the retaining nut. Do not do this without compressing the spring first as this could cause injury.
Keep the components that you remove in the order you remove them and the correct way up as this will help when fitting them to the new suspension.
Now remove the spacer and rubber bush.
The washer
Cupped washer and spring retainer. Make a note of which way up the cupped washer sits for replacement.
Slowly release the tension off the springs a little at a time from each compressor in turn
until you can remove the compressors safely.
Slide the spring off the shock absorber unit
And you will see the dust cover. Slide the dust cover off, complete with the metal cup that has probably become one with the plastic dust cover. Also remove the rubber bump stop by sliding it up the shaft, remembering which way up it sits.
Now pick up a new suspension unit
And remove the spring
Slide the rubber bump stop onto the threaded shaft, tapered end towards the main body
And then, after cleaning, slide the dust cover and metal cup over the bump stop.
Now grab the new spring and fit the spring compressors. One tip I have learned from doing this, is leave the plastic wrapping on the spring (not shown in this shot) when fitting the compressors. This will protect the spring as the compressors tend to dig in and can remove a bit of the blue protective coating. If you do leave the wrapping on, then pull enough off the top and bottom so that it won’t be trapped between the spring and damper when you come to remove it.
Once the spring has been compressed enough, fit the spring retainer over the top
And fit the cupped washer, making sure you fit it the correct way up.
Next fit the washer piece on top of the cupped washer
The next part is one of two identical rubber bushes. I bought new bushes and I bought uprated poly bushes from Rimmer Brothers http://www.rimmerbros.co.uk/Item--i-RNF100090LPOLY . You need two of these per shock absorber, so if you are doing the whole car then you will need 8 in total.
Fit the rubber/poly bush with the tapered end down over
Now fit the metal spacer tube, which should slide into the bush that you have just fitted.
And fit the retaining nut. If you can, torque to 25Nm
Now you can remove the spring compressors and refit the large rubber cover on the top of the spring. Your new unit is ready.
Do the same with the other front unit so you now have a nice shiny looking pair (Oooer missus)
While the shock absorbers and springs were out I also used the space to treat the rust with some stone chip resistant paint.
Before
After
Now comes the fitting bit.
Carefully lower the bottom of the unit down behind the hub
And feed the top of the unit into the suspension turret
So that the top of the unit feeds through the hole into the under bonnet area.
Fit the rubber/poly bush over the top, with the tapered side down over
Fit the top washer and top nut. Tighten a couple of threads by hand to take the weight of the unit.
Now apply some copper grease to the NEW lower bolt
Line up the bottom of the damper to the suspension arm, ensuring that the adjuster screw is pointing outwards (otherwise you won’t be able to adjust it once fitted), and insert the new bolt.
post #2 of 44 (permalink) Old 07-08-2011, 00:57 Thread Starter
You may need to use a jack to slightly raise the hub so that the hole lines up with the hole in the damper.
Gently tighten the bolt, ensuring that it is going in square and not cross threading.
Now carefully raise the car and move the axle stand under the hub (Not the disc). Gently lower the jack until the suspension is fully compressed on the axle stand. You should always torque up suspension components when the suspension is taking the weight of the car.
Set your torque wrench to 100Nm
And torque the lower bolt to 100Nm
Now torque the top nut to 45nm
However. You might find that the strut starts turning before you get the full torque. There is no way to hold it and use a standard torque wrench, so you will have to use a spanner on the top of the thread and use a spanner to tighten the nut to your best guess.
You might want to set the rebound on the shock absorber before fitting the wheel. The consensus is around 12 clicks on the fronts and 17 clicks on the rear. However, this is just a starting point and you need to set it up to your own tastes.
Using a screwdriver, wind the screw fully anti clockwise. Now turn the screw the required number of clicks clockwise.
Now refit the wheel and lower the car on that side.
Fit the other unit using the same procedure.
Now refit the horn and the fuse box. Also make sure you clip the ABS connectors back in place.
We now move onto the rear units.
Things get a little bit more complicated here due to access issues.
Open the boot and you won’t see the tops of the suspension, mainly because they are hidden below the coolant expansion tank (offside) and the ECU (nearside).
Firstly, remove the top hose from the expansion tank and tuck it away safely.
Remove the two bolts holding the expansion tank in place and pull up to release the tank. Move it inward to a safe place but try to keep it level so as not to lose any coolant.
You should now be able to see the top of the offside suspension.
Now move to the nearside. Before carrying on, disconnect the negative connection on the battery.
Remove the top left and right 8mm bolts holding the ECU bracket to the boot wall.
Pull the ECU and bracket upwards to release the bottom from the rubber grommet, shown in the centre of the next pic.
Tilt the bracket inwards towards the engine and you will see 2 connectors clipped to the inside of the bracket. Unclip them so that they fall free.
Also, unclip the two main ECU connectors. The connectors have a pull out clip at the top of the top connector and on the bottom of the bottom connector. Grab these and pull and they slide out and release the plug.
You can now remove the ECU and bracket. Store in a safe place, your car doesn’t even know it is a car without this bit.
Also, disconnect and move the ABS sensor connectors on both sides.
Use the wire brush and release oil trick
Although this didn’t work for me and I ended up rounding the 5mm Allen socket off.
So I tried a nut splitter.
And gave up due to lack of access, and ended up drilling and splitting the top nuts with a chisel.
Be careful when using wire brush attachments and drills in the engine area as it would be very easy to damage a cable or coolant hose.
Again, jack up the car and support on axle stands.
The main difference with the rear units is that you cannot remove them while the anti roll bar is in the way.
First, remove the 4 x 10mm bolts from the exhaust heat shield. This will allow you to move it to get access to the roll bar mounts.
Undo the 2 x 13mm nuts that hold the mounts onto the body. You may need the wire brush and release oil again.
Undo the anti roll bar links on each rear hub.
This will now allow you to move the roll bar out of the way when removing the shock absorbers.
Do the wire brush, releasing oil and tightening/loosening thing on the lower bolt.
And remove the units in the same way as you removed the fronts.
The only difference is that the rubber cup that fits on the top of the spring has a locating pin which goes to the rear of the car, in a hole on the suspension turret. Remember this. You can see it poking through in the next pic, below the top nut
You can also see it on this rebuilt unit ready to go back in.
Stripping down and rebuilding the units is the same as the front suspension.
Now refit the new units.
With the locating pin in the rear locating hole, fit the rubber/poly bush, washer and hand tighten nut to take the weight.
As before, line up the bottom of the strut with the suspension arm, remembering to use the jack to lift the hub aligning the holes, and insert the new copper greased lower bolt. Remember that the adjuster faces outwards.
Again, raise the car, put the axle stands under both of the hubs and lower the car until the hubs are taking the full weight.
Torque up the bottom bolt and top nut as per the front units.
Refit the roll bar links and bolt the anti roll bar brackets to the bodywork under the heat shield and torque to the correct settings. 35Nm for the links and 22Nm for the anti roll bar clamp bracket.
Refit the heat shield.
Now refit the ECU and Coolant tank, remembering to reconnect any ABS connectors.
Reconnect the battery.
Refit the wheels and lower the car.
Your new suspension is now fitted.
The rebound can be adjusted to suit your taste, so take it for a test drive and fiddle with the settings until you achieve the best ride, just remember that both sides need to be the same. Front and rear can be different and is usually set up with a higher setting to the rear.
If you invest in a long screwdriver you will be able to adjust the settings without removing the wheels as you can see the adjuster through the spokes.
Enjoy your new springs.
post #3 of 44 (permalink) Old 07-08-2011, 03:12
Car: A happy ex-MG TF owner
Excellent How-To. Well done mate...
AlanTR is offline
post #4 of 44 (permalink) Old 07-08-2011, 07:48
Car: MG TF 160 called Klara, 1 of only 4 160s in Bacchus
Send a message via MSN to phil-hex
you horrible man , do you realise how many people will read this and now be trying to sell a kidney or child (the better option ) to buy new suspension after finding out how straight forward it actually is to replace it ...........
anyone want to buy a large child
a fantastically well written 'how to' Clive keep them coming !!!
DocMark likes this.
phil-hex is offline
post #5 of 44 (permalink) Old 07-08-2011, 08:04
Car: 1967 Triumph GT6 Mk1
Send a message via MSN to MikeKnight
Good job.
I re-used my bottom bolts and it seems fine, though new is always better.
MikeKnight is offline
post #6 of 44 (permalink) Old 07-08-2011, 08:10
Excellent hoe to Clive
Mike, its advised to use new bottom bolts as the one you are removing has been in high tension and high shear loads. Whilst you may get away with re-using it, there have been reports of the re-used bolts shearing, rare, but it has happened
post #7 of 44 (permalink) Old 07-08-2011, 08:41
Car: MG TF 160 Sprint
A BRILLIANT How To. With especially good and clear pics. Well done, a job I would have shied away from completely now considered only due to this!
Well Done mate!
P.S.
I hope you get the ride you hoped for out of those new shocks & springs, maybe you can let us know what settings you find best for yours.
dzieba is offline
post #8 of 44 (permalink) Old 07-08-2011, 09:04
Ah, I see.
I'll be doing my polybushes within a year so will probably change them then, as I planned.
post #9 of 44 (permalink) Old 07-08-2011, 09:54
Car: TF160 + Freelander
Fantastic how to
Fast Jan is offline
post #10 of 44 (permalink) Old 07-08-2011, 10:47
Car: Vx Vectra C
Send a message via MSN to Rosco88
Clive....
Bostin' How-To as usual.....
Definately gonna help me!!
Novice Question though.... In undoing the coolant tank.....will this do any damage.....
I'm not asking..... it's for a...errrrr....friend
Rosco88 is offline
post #11 of 44 (permalink) Old 07-08-2011, 10:48
Car: MGF (Rough Luck) 1.9 supercharged K-series VVC
Those back ones always seem to get stuck,....lol much respect on the nut splitting an drilling.......I manage to get a grinder in
Hmmm Clive just wondering how many more How To's before you've replaced the whole car great work again though, it amazes me how you remember the pics
Jon Norris is offline
post #12 of 44 (permalink) Old 07-08-2011, 11:18 Thread Starter
Originally Posted by Rosco88 View Post
Clive....
No, all your doing is moving it, you're still maintaining the coolant level rather than emptying it. The top hose you remove is a coolant return to the tank so it isn't detrimental if you get air in there. Just make sure that you aren't rough with it and dislodege or damage one of the other hoses, but it would take some doing.
If you have a sensor remember that there is a plug and wiring on the bottom of the tank too.
I'm wondering too.
Some people like to take holiday snaps. Me, I like to take snaps of my car in various stages of disassembly.
post #13 of 44 (permalink) Old 07-08-2011, 13:02
Great job Clive.
BTW I see you have bigger rear brakes. I assume they are the original calipers mounted over larger diameter discs.
What are they/where from?
Thanks.
TipperMG is offline
post #14 of 44 (permalink) Old 07-08-2011, 13:12
Originally Posted by TipperMG View Post
Great job Clive.
Thanks.
Clive's conversion - 280mm rear disc upgrade.
post #15 of 44 (permalink) Old 07-08-2011, 13:48
Ah, I see.
So is anyone still selling this conversion or the separate parts for it, ie 280mm discs and caliper brackets?
TipperMG is offline
post #16 of 44 (permalink) Old 07-08-2011, 14:43 Thread Starter
Ah, I see.
I'm going back to standard before the new MOT kicks in.
post #17 of 44 (permalink) Old 07-08-2011, 14:53
Car: MG TF 02 plate Stepspeed 120 Trophy Blue, 2.5 V6 Rover 75 BRG Connoisseur SE
Could I ask why Clive?
Sez he after bookmarking rear brake upgrade thread for future reverence.
TouchStone is offline
post #18 of 44 (permalink) Old 07-08-2011, 15:20 Thread Starter
Apparently the new MOT can fail you on modifications to brake systems, which could include this type of kit.
I am still waiting for the uprated calipers that have been talked about for a while.
post #19 of 44 (permalink) Old 07-08-2011, 16:06
Ok, ta very.
I shall bin that idea then.
post #20 of 44 (permalink) Old 07-08-2011, 16:29 Thread Starter
I have just changed a few pics in the post but it doesn't alter the how to.
I had double posted some pics, but if you look at the time I submitted the post you will understand why.
60mm springs and dampers? -tom- MG ZR / Rover 25, 200 & Streetwise 4 30-09-2008 09:43
XPower Springs-What Dampers? GazSuttonUK MGF and MGTF (Sponsored by MGFnTFBITZ) 4 12-08-2007 18:06
Zr springs or springs and dampers lukeism Wanted 3 04-11-2005 11:10
[B]zr springs and dampers[/B] chris221302 MG ZR / Rover 25, 200 & Streetwise 1 12-05-2004 21:39
600 lowering springs or dampers + springs putty_thing Wanted 0 18-04-2004 22:40
