front subframe and mounts tf - MG-Rover.org Forums
post #1 of 3 (permalink) Old 14-03-2013, 15:36 Thread Starter
i take it the front subframe has to be lowered a bit to do the wishbones same as the f
if so best place to disconnect the steering whole rack or just column to rack
and the mounting bolts could snap due to that funny rust stuff so a good spray 2-3 days before hand would be a good thing or is there another way
Ron
bugsb is offline
post #2 of 3 (permalink) Old 14-03-2013, 16:16
if only lowering the subframe to do the wishbone bushes then i'd undo the rack from the column from the single bolt at the base of the column inside the car. this way you wont need to worry about dropping the subframe a bit with the t.r.e's still all connected and the whole lot can move as one.
you can try giving the bolts a good spray, and also have new bolts to replace them with as the originals rot away inside the hole and lose alot of strength.
youll need m10 x 30 or 35 for the rear mounts, and m8 x 25 for the front mounts. try and get high tensile 12:9 bolts, ideally zinc plated.
colin_s is offline
post #3 of 3 (permalink) Old 14-03-2013, 16:45 Thread Starter
thanks i will get the bolts friday just in case it stops raining
Ron
bugsb is offline
Mg tf subframe mounts snowonfire Wanted 10 15-09-2012 23:33
Subframe mounts andywatson MGF and MGTF (Sponsored by MGFnTFBITZ) 3 29-08-2012 15:40
Subframe mounts gotenks1321 MGF and MGTF (Sponsored by MGFnTFBITZ) 3 10-11-2010 01:16
TF subframe mounts gotenks1321 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 16-06-2010 17:44
subframe mounts flyingbanana Wanted 3 01-12-2007 10:51
