Gearbox Oil Fill how to - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
post #1 of 69 (permalink) Old 23-05-2009, 22:41 Thread Starter
The gearbox oil should be checked for level occasionally, especially if you have a leak. Otherwise it should be changed evey 105,000 miles or 7 years.
I have just filled mine up as I have just fitted a new gearbox and drained it to fit a magnetic drain plug.
The oil I used was Castrol SMX-S.
Filling from empty takes around the 2.4 litre mark, so you will need 3 x 1 litre bottles.
The bottles usually have a filler tube built in. In this case you simply break the seal and pull the centre cap outwards.
The filler hole is also where you check for the level. It is above the drain plug and to the right, looking from the nearside.
You can see them on this pic of my old gearbox with the driveshaft removed.
If you are checking the level, then it should be just below the threaded hole with the filler plug removed.
Unfortunately, in real life, the filler is a pain in the but to get to.
Remove the filler plug from underneath the engine bay (17mm socket). You will need the car up on axle stands or ramps to do this, but the car must be level when checking or filling the oil. If any oil comes out then the level is OK (should only be a slight weep).
I found the easiest way to fill the gearbox was to remove the engine inspection cover and the airbox. I also used a length of tube, one end pushed into the filler
You can also see the drain plug on the above photo, it is the shiny one as it is an aftermarket magnetic plug fitted on mine. If you are changing the oil then you will need to remove this and drain the oil into a suitable container, refitting the plug afterwards.
The other end of the tube is accessable through the top of the engine bay. Simply fill the geabox from here.
Now, just keep filling the gearbox until the oil starts flowing out of the filler hole.
Once the oil has stopped dribbling out, refit the filler plug and the gearbox is done.
Now refit the airbox and engine cover.
post #2 of 69 (permalink) Old 23-05-2009, 22:47
Thumbs up
Cheers, another great guide!
Looks like your almost up and running?!
Iain160Trophy is offline
post #3 of 69 (permalink) Old 23-05-2009, 22:48 Thread Starter
All fluids are present and correct, and holding level, which is always good.
post #4 of 69 (permalink) Old 23-05-2009, 22:51
you started it yet?
post #5 of 69 (permalink) Old 23-05-2009, 22:54 Thread Starter
Clutch problems at the minute as I cannot get any pressure. Need to pressure bleed it tomorrow. I don't want to start it without a clutch as it may be in gear and it is up on ramps. Could get messy.
post #6 of 69 (permalink) Old 23-05-2009, 23:02
hope it goes well for you! your car will be top notch when you finish
although shares in hammerite might drop
post #7 of 69 (permalink) Old 24-05-2009, 08:25 Thread Starter
Don't know about top notch, but working would be nice.
The great god of Hammerite will always be there for us
post #8 of 69 (permalink) Old 24-05-2009, 08:44
Talking of hammerite, I have a project later on today!
post #9 of 69 (permalink) Old 24-05-2009, 09:49 Thread Starter
Are you going to hand paint the BMW?
post #10 of 69 (permalink) Old 24-05-2009, 12:28
Car: TF160 + Freelander
An alternative method of filling without having to go through the inspection hatch is to use a large hypodermic like this one -
with a tube attached - the gearbox can then be filled from below using the filler plug hole.
Mine was checked and topped up yesterday (thanks Jerry ) - it took an astonishing 450ml to fill
Fast Jan is offline
post #11 of 69 (permalink) Old 24-05-2009, 12:31
Car: MGTF160
Very good how to CJJ
Great idea as well Jan, going to get me one of those from work this afternoon
DAVIDT6DCM is offline
post #12 of 69 (permalink) Old 24-05-2009, 12:35
I'd like to take the credit for the idea, but it's far to sensible to be one of mine
Another perk of the job eh Dave?!
Fast Jan is offline
post #13 of 69 (permalink) Old 24-05-2009, 18:59 Thread Starter
Good call with the syringe Jan, but I had the cover off and had to put nearly 2.5L of the stuff in. Anyway, I ain't got any epideemic nerdles.
post #14 of 69 (permalink) Old 24-05-2009, 19:19
http://www.mgf-tf-central.co.uk/ht-r....shtml#gearbox
Originally Posted by Fast Jan View Post
An alternative method of filling without having to go through the inspection hatch is to use a large hypodermic like this one.....
and where might one purchase such a large item from ???
post #15 of 69 (permalink) Old 25-05-2009, 10:57
Fast Jan is offline
post #16 of 69 (permalink) Old 25-05-2009, 11:17
thanks Jan
post #17 of 69 (permalink) Old 25-05-2009, 11:29
They can also be bought from farms as this is where Jerry got his - they can be used for.... actually I don't think I wanna say what they can be used for on cows, just make sure you buy a new sealed one
Fast Jan is offline
post #18 of 69 (permalink) Old 02-06-2009, 12:54
Car: MG ZS 120+
Thanks for these photos. Very useful.
I changed my gearbox oil today. I bought 1m of tubing from B&Q and dropped it down from the gap in the boot. Another way to do this without removing the engine cover!
ourmark is offline
post #19 of 69 (permalink) Old 02-06-2009, 12:59
Send a message via MSN to PaulMGTF160
So how often doe the gear bow oil need changing?
PaulMGTF160 is offline
post #20 of 69 (permalink) Old 02-06-2009, 13:03
Car: MG TF160, Daytona 955 x2
is it only me?
I can imagine a lot of alternative substances to have in that
WindDrifter is offline
Tags
f/tf how to, gearbox oil change
Automatic Gearbox drain and fill capese21 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 31-12-2007 20:08
gearbox oil spadam MG ZR / Rover 25, 200 & Streetwise 1 15-10-2007 17:08
214si 16v Engine Oil, Gearbox Oil SplateKseries MG ZR / Rover 25, 200 & Streetwise 4 05-06-2007 17:39
Gearbox 620DI topped up with gearbox oil *Victor* Rover 600 4 13-08-2004 18:58
Fill to level on gearbox? MikeO Others 12 15-03-2004 13:37
