how to adjust the handbrake cable - MG-Rover.org Forums
post #1 of 8 (permalink) Old 14-01-2011, 18:45 Thread Starter
when i pull the hand brake up the car still wants to roll backwards down the drive please help
twoer is offline
post #2 of 8 (permalink) Old 14-01-2011, 19:17
Car: ASTRA CABBY
hi
lift the center arm rest up and remove the cubby holder
inside the tunnel you will see the hand brake cables adjust the center adjuster to set the hand brake height
or adjust the 2 outer ones to adjust the 2 cables running to the calipers
if your hand brake leaver in the lowe position (off) but the light some times comes on then adjust the center adjuster
the leaver should only come up about 3 clicks
hope this helps mark
MGF MARK is offline
post #3 of 8 (permalink) Old 14-01-2011, 19:29
Car: MGTF 160
But don't do what I did and sit on your cigarette lighter while doing it!
spaceoctagon is offline
post #4 of 8 (permalink) Old 14-01-2011, 19:31
Car: ASTRA CABBY
ouch that flame !!!!!! lol
MGF MARK is offline
post #5 of 8 (permalink) Old 14-01-2011, 19:44
This might help How to change a handbrake cable.
It is how to change a cable, but shows the adjuster at the end.
post #6 of 8 (permalink) Old 14-01-2011, 22:51
Car: MGTF 135 80th Anniversary
Hi
Not being mechanically minded, but how can you tell whether your cable needs adjusting, or replacing?
My handbrake light comes on almost as soon as you pull the hanbrake handle up (almost a touch). And when the hanbrake is applied, it starts rolling backwards (if on an incline) until I really force the handbrake up to max clicks. Even then I make sure it's left in gear!
kylinski is offline
post #7 of 8 (permalink) Old 14-01-2011, 23:04
Car: MG ZS 120+ , MG ZR TD, MG TF 135 and MG3 Style.
this may be a seized rear caliper.
the handbrake light wouldn't go off in mine and it had trouble with hills.
took it into the garage and a rear caliper had seized.
i would get it looked at before you're needing pads and discs as well as calipers.
michaelb is offline
post #8 of 8 (permalink) Old 14-01-2011, 23:16
Yeah, I was gonna make it a garage job. Got some other 'niggles' need sorting at the same time.
kylinski is offline
Anyone know how to adjust a handbrake?!! Wild Bill MG ZR / Rover 25, 200 & Streetwise 13 01-09-2010 20:07
Handbrake adjust mirkwood MG ZT / Rover 75 (Sponsored by Rimmer Bros) 8 21-02-2009 22:38
how to adjust handbrake?? double-a-ron MG ZR / Rover 25, 200 & Streetwise 3 15-09-2008 18:40
Handbrake cable adjust bear MG ZS / Rover 45 & 400 2 18-06-2008 17:18
Can't adjust the handbrake david_geng MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 07-06-2008 18:55
