How to change the lock barrel on your fuel filler cap. - MG-Rover.org Forums
post #1 of 5 (permalink) Old 28-06-2010, 20:25 Thread Starter
Not sure whether this has been covered before, bt this is how I changed my lock barrel over onto a newer filler cap.
One problem with the F/TFs is that the fuel filler cap tends to fade and corrode over time.
There are several options including painting them etc, but I just bought a good second hand one.
The problem with this is that the replacement fuel cap will have the wrong key which means 2 keys on your key ring. You can however swap your lock barrel onto the new fuel filler cap.
If you remove the cap and look on the inside you will see a blue plastic shroud.
You need to remove this as it holds the key barrel in place.
If you look at the end of the blue shroud you will see that there are 4 quadrants which clip under a raised section on the end of the lock barrel.
You need to bend these quadrants back far enough that they release their
hold on the barrel.
An then pull the shroud away from the filler cap.
You will then see a rubber o-ring which needs to be removed.
Once the o-ring has been removed, hold the cap and push on the cream coloured part of the lock barrel so that you push the barrel through the cap and out towards the key end. The o-ring is still in place in the picture but should be removed.
And the barrel is removed.
Now remove your barrel in the same way and push it back though the new filler cap.
Donít forget to fit the o-ring back onto the end of the barrel
Reform the quadrants on the blue plastic shroud so that they are roughly the same shape and position before you levered them and then push the shroud onto the end of the barrel until it clicks into place. You can only fit it on in one of 2 ways, make sure that you have it inn the right position before pushing it home. You can test this by turning the key and making sure it operates properly.
You have now changed the lock and can fit the new filler cap to your car.
post #2 of 5 (permalink) Old 28-06-2010, 20:52
Hobbyist
Car: MG TF 160, ZR 2.0 Diesel
Another good "how to" Clive, just one thing, my plastic shroud is black so i'm finding it difficult to follow your instructions!!!!!! can you re-post changing the blue for black please.
COPPERKNOB is offline
post #3 of 5 (permalink) Old 28-06-2010, 21:46 Thread Starter
You have the black one? I thought they were all recalled due to the cars exploding
post #4 of 5 (permalink) Old 28-06-2010, 22:48
Car: MR2 -SUPERCHARGED MINI - 1275 MINI
Great How to Clive! And for those of us (like me!) who would be stupid enough to remove the key from the barrel before taking it apart, for what ever reason.....DONT!!!....because the little barrel bits are on springs and will fly off in all directions!!
zipimini is offline
post #5 of 5 (permalink) Old 29-06-2010, 11:18
Car: MGTF 160
When I did mine all the lock bits sprung out everywhere!
spaceoctagon is offline
MGF Fuel Filler Cap boreas7 MGF and MGTF (Sponsored by MGFnTFBITZ) 14 26-10-2010 18:52
Help Me- Fuel filler cap key stuck sjoynes1985 MGF and MGTF (Sponsored by MGFnTFBITZ) 8 30-06-2009 20:40
fuel filler cap.. clockworx MGF and MGTF (Sponsored by MGFnTFBITZ) 5 22-12-2008 19:27
fuel filler cap hiss mattk Rover 600 3 30-03-2007 23:01
MGF fuel filler cap with keys!! zs105 For Sale 0 27-01-2006 11:48
