How do u trace a bad earth ? - MG-Rover.org Forums
post #1 of 2 (permalink) Old 22-09-2009, 12:54 Thread Starter
ive been told my stereo is being caused by a bad earth so how do I fix this ?
iainchad is offline
post #2 of 2 (permalink) Old 22-09-2009, 14:50
Car: MG Motor 2011 TF135
Would help if you said what the problem is - steroes are not caused by earth leads.
Basically, you have to track down which of the many earth points is actually causing the problem. A multi meter and/or a continuity tester will help.
Then I got called by SWMBO to go out for a while.
Obvious starting points are the battery earth lead connection - always worth taking it off, cleaning and reattaching. Then the radio will have a live (power) lead and an earth lead - again check the earth lead. Is the aerial lead making a good contact where it bolts in to rear wing. Is the aerial lead plugged fully in to the rear of the radio.
Are you getting interference on reception that speeds up when the engine speed is increased ? Possible cause is a breakdown in the ignition supressors.
May be worth going back to who ever suggested an earth problem and asking them for a bit for detail.
Sprinter is offline
engine stall, revs dip, bad earth? michaella18 MG ZR / Rover 25, 200 & Streetwise 9 23-12-2008 10:08
battery giving up or bad earth? H3lter Diesel Forum! 4 18-12-2008 19:27
Error Messages (Bad Earth) Johndotcom MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 09-10-2006 22:08
bad earth? leebloomers In-Car Audio, Entertainment, Sat Nav etc... 3 09-01-2006 11:33
rover 800 possible bad earth Vitessesqauddie Rover 800 3 09-06-2005 20:31
