How to remove your door card. - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
post #1 of 21 (permalink) Old 22-01-2010, 15:52 Thread Starter
There are several jobs that need the door card removing.
It might be to fix the door lock, window mechanism, adjust the window stops, changing door speakers etc etc.
The first thing to do is remove the 2 cross headed screws at the rear edge of the door panel. Remember to put them somewhere where you won’t lose them.
Now remove the top front screw.
Remove the 2 screws that hold the door pull in place.
And pull out the finisher.
Now remove the single screw behind the door handle.
Pull the finisher forward
Turn the finisher through 90 degrees and remove it.
Now you need to release the clips along the bottom of the door card.
You can use a screwdriver to lever it, or buy a proper trim removal set.
Use the tool to “pop” the clips out.
And pull the bottom of the door card away from the door.
Next you need to pull the small rubber seal out of the way and manoeuvre the card to clear the door locking pin.
Pull the card up to clear the pin.
Now slide the card backwards to clear the mirror/wind cheater.
And remove the door card.
Remember, if you have a tweeter fitted then you will need to unplug the speaker cable.
Your door card is now removed.
Refitting is the reverse of removing.
post #2 of 21 (permalink) Old 22-01-2010, 15:57
Craigie TF's Avatar
What jobs were you doing?
Craigie TF is offline
post #3 of 21 (permalink) Old 22-01-2010, 15:59 Thread Starter
How to adjust door window seals.
post #4 of 21 (permalink) Old 22-01-2010, 16:23
Am I the only one on here that just gives the doorcard a good tug to get it off instead of using the fancy lifters.....?
Michiel.B is offline
post #5 of 21 (permalink) Old 22-01-2010, 16:39
Good work Clive, I love the pillow right below the door
Herbie is offline
post #6 of 21 (permalink) Old 22-01-2010, 17:17 Thread Starter
That's the dogs bed. The ground was wet, so I had to put something down to kneel on.
post #7 of 21 (permalink) Old 22-01-2010, 18:08
so what is the dog supposed to sleep on now eh
post #8 of 21 (permalink) Old 22-01-2010, 18:26 Thread Starter
It was either that or kneel on the dog.
post #9 of 21 (permalink) Old 02-04-2011, 18:28
Car: MG TF, X-Power Grey
Super awesome how to, thanks for taking the time and showing how to do this.
I am taking the TF door apart tomorrow, as the passenger side window came loose, and something is wrong with the mechanism. Frankly I am afraid of anything with plastics and these little "clicky" fits, they are too easy to break.
Anyways, big help!!!!
ascas is offline
post #10 of 21 (permalink) Old 02-04-2011, 19:13
Car: MGF SE Wedgewood and old english white tiny
wow Clive i was going to take my passenger door card off today but chickened out this will be a great help. I must find the source of some nasty rattling in there and wasnt sure how to take it all apart
cheers
joe
Mods can you add this to the how to lists
rep added
dusty mgf is offline
post #11 of 21 (permalink) Old 02-04-2011, 19:54
I just tug it off......
my door card is missing many screws after doing my speakers......
part of my lazy git weight saving project
Iain160Trophy is offline
post #12 of 21 (permalink) Old 02-04-2011, 20:46 Thread Starter
cheers
joe
You might want to check the lower window rail adjusting screws and locknuts. If they are loose then the whole lot will rattle.
In fact, it might be worth checking all the bolts and nuts circled in this how to:
post #13 of 21 (permalink) Old 02-04-2011, 20:46 Thread Starter
Glad to help.
post #14 of 21 (permalink) Old 02-04-2011, 21:13
Car: MGF 1.8i, Rover 45 V6 Connoisseur, Rover 25 1.4i GLi
Thank you CJJ after the radiator, s/s pipes and MOT done, I'll be sorting out the window, excellent advice as always. Top Man.
Mgf120 is offline
post #15 of 21 (permalink) Old 02-04-2011, 21:38
Car: MG TF Sprint SE 2003
I would just like to add one small comment to CJJs, How To.
When refiting the door card. Fit the Door Pull finisher before you fit the Door Handle finisher. Then if you accidently drop the Door Handle retaining screw it will fall into the Door Pull finisher and not into the door; resulting in you having to remove the door card again to retrieve the screw.
I speak from experiance :-)
Louie07 is offline
post #16 of 21 (permalink) Old 02-04-2011, 22:27
Car: MG TF 135 Sprint
I'm joining in to say thanks for this in fact I find all of your How to's really simply written and troumendeously helpful.
I think it's safe to say that I would not attempt some of the stuff if there wasn't for guides like these ......soooooo big big thumbs up (that's the biggest one I can find )
MG_TF_2004 is offline
post #17 of 21 (permalink) Old 02-04-2011, 22:33
Car: 1997 MGF 1.8i VVC, 1976 Mk4 Midget
Send a message via MSN to dressur
I am of the "Remove screws - then give it a bloody good tug" brigade too! Nice to know how to do it properly though.
Two things to add - I put all the screws in the doorpull finisher - haven't lost one yet, and my door cards are on and off like a Z list celebs knickers.
Also - it's much easier to get the doorcard back in if the window is fully down
dressur is offline
post #18 of 21 (permalink) Old 02-04-2011, 22:49 Thread Starter
Guys...Your making me blush.
post #19 of 21 (permalink) Old 03-04-2011, 09:06
Car: ASTRA CABBY
nice one clive
now why didnt i think of doing this
took the covers off so many times its second nature
strange how we take things for granted
MGF MARK is offline
post #20 of 21 (permalink) Old 22-10-2015, 20:13
sundanceuk's Avatar
Car: MG TF 160
just the job
need to replace the window reg tomorrow...his is just the ticket..thanks
sundanceuk is offline
How to remove your door card. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 4 09-11-2009 20:50
how to remove credit card pymts off Live hardmonkeys XBox / 360 / One Gaming 8 12-01-2009 19:47
Rover 220 Bouble, do i need to remove door card to get to front speakers? chunk In-Car Audio, Entertainment, Sat Nav etc... 6 03-05-2006 10:12
How do I remove my door card? - R25 tahiti25 MG ZR / Rover 25, 200 & Streetwise 9 27-03-2004 13:53
How do you remove a 25's door card? Windy Miller In-Car Audio, Entertainment, Sat Nav etc... 3 19-04-2003 20:16
