How to remove your instrument panel - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
post #1 of 28 (permalink) Old 21-09-2007, 22:55 Thread Starter
I needed to remove my instrument panel tonight to fix a crack in the dashboard surround so thought it best to take some photos of how to remove the instruments - handy if you want to replace any dash bulbs or install chrome dial rings etc.
First thing to do is disconnect the battery, negative first followed by the positive connection then wait 10 minutes. This discharges the airbag circuit and prevents it from being activated.
Next open the fuse box cover under the steering column and remove the 3 screws from the steering column cover.
Next unclip the 2 halves of the column cover and remove.
Now remove the 2 bottom screws and 2 top screws that hold the instrument suround panel in place
lift the surround away after disconnecting the instrument light dimmer, later models will have the door mirror adjust switch to disconnect as well -
Now remove the 4 screws that hold the instrument cluster in place
On Mk 1 models, disconnect the cable speedometer drive, I found it best to put my arm up from the fuse box area as shown below.
to release the cable, press on the plastic peg as shown and pull the cable out of the housing.
Before removing the cluster, you need to unplug the various connectors shown, later models will have an additional electronic speedo connection.
Now remove the instrument cluster, I found it easiest to remove from the right as shown. Be carefull that it does not catch on the electrical connections on top of the steering wheel column.
Now you can replace the bulbs by twisting the bulb holders out of the cluster as numbered (1)
If you want to gain access to the front of the dials, proceed to unclip the wire from the lighting pod at points (2) then unscrew to remove clips (3) and lift the lighting pod (4) away.
To remove the instrument 'glass' unclip the 2 clips (5)
Then turn the instruments over to release a further 2 clips (5), the glass now lifts off.
As usual, reverse procedure to refit.
The speedo drive cable needs to be lined up properly to click in place, just turn the cable with your fingers or pliers to get it in alignment with the square drive on the back of the speedo.
MGFmad is offline
post #2 of 28 (permalink) Old 22-09-2007, 07:19
excellent post
post #3 of 28 (permalink) Old 22-09-2007, 15:01
Car: TF160 + Freelander
Couldn't agree more Pete. Brilliant post with great pics
And very handy timing too seeing as i should be getting my dash rings soon
Fast Jan is offline
post #4 of 28 (permalink) Old 22-09-2007, 15:14
Very intresting read, this should be moved to "how to"
Stu
VW Camper is offline
post #5 of 28 (permalink) Old 22-09-2007, 15:16
But don't move it yet!! Let a few more F/TF-ers read it first as many don't look outside of this forum and it would a real shame to 'lose' it to "how to" just yet!!
Fast Jan is offline
post #6 of 28 (permalink) Old 22-09-2007, 15:18
Sorry, I'll go and stand in the corner
Stu
post #7 of 28 (permalink) Old 22-09-2007, 15:19
Yes i think that might be best
Fast Jan is offline
post #8 of 28 (permalink) Old 02-10-2007, 09:44
Instrument panel lights MGF
Can anyone tell me how the instrument panel, including the clock, oil guage and heater controls are actually lit? All my panel lights have suddenly failed yet the exterior lights and courtesy lights are fine. I'm guessing this is both fiddly and expensive to remedy. Thank you from a new member needing help!
martysangel is offline
post #9 of 28 (permalink) Old 02-10-2007, 09:57
check fuse F12 -> http://www.mgf-tf-central.co.uk/_images/pas-fuse-1.jpg
post #10 of 28 (permalink) Old 02-10-2007, 13:27
Car: City Rover
anyone know if the white fascia on the instrument panel is replaceable as mine has a slight discolouration to it no idea why been like that since i bought car
cheers
bowser
bowser is offline
post #11 of 28 (permalink) Old 02-10-2007, 14:09
Very nice write-up MGFmad
.....And very handy timing too seeing as i should be getting my dash rings soon
Yes, on thursday
xxx
Herbie is offline
post #12 of 28 (permalink) Old 02-10-2007, 14:28 Thread Starter
cheers
bowser
You can get the instruments out of the housing but you would need to remove the needles to get the printed fascias out - I don't know how easy this would be. Second hand instruments are often for sale on ebay for reasonable money, if you have an electronic speedo with the digital readout, I would guess that someone who does diagnostics would be able to set the mileage on the replacement to what yours is currently at (but check first) if like me you have the analogue speedo, a replacement would always show incorrect mileage - not ideal when you come to sell, even with a genuine explaination.
MGFmad is offline
post #13 of 28 (permalink) Old 02-10-2007, 15:13
Car: City Rover
cheers ive seen some on fleabay but wasnt aware you could re calibrate them
bowser
bowser is offline
post #14 of 28 (permalink) Old 30-07-2008, 21:50
Cool time clock on instrument panel
I want to change my clock for one that works is it easy to get it out? i'll have a go at most things that aren't oily
joseyjo is offline
post #15 of 28 (permalink) Old 30-07-2008, 22:01
Car: MG TF 160
Looks great glad someone has done this! However you dont need to remove all the housing arround the stearing wheel to get to the dials, i just did this yesterday to fit a low fuel warning light from 'Technozen' (member on the forum lives on the 200/25/ZR side) just remove the 4 screews on the dial surround and then lift out, remove 4 more screews and undo the 3 plugs and your away....
Plus if anyone is interested Technozen also does a replacement resistor kit to solve any fan issues. I fitted this also yesterday and now speed one works again!
I'll take a pic of the fuel warning light when i start running low of fuel.
Reaper is offline
post #16 of 28 (permalink) Old 31-07-2008, 11:46
Agreed, it's tighter with the steering column cowl in place, but still possible.
Top posting though. Got all nostalgic for the last time i did a write up on this.
Scarlet Fever is offline
post #17 of 28 (permalink) Old 31-07-2008, 15:03
Is there a window symbol for the warning light on the f?
darenh is offline
post #18 of 28 (permalink) Old 31-07-2008, 16:38
Car: MG TF 160
Dont know i drilled a 2mm hold in the gauge.
Reaper is offline
post #19 of 28 (permalink) Old 31-07-2008, 19:31
Car: Captain Jack & Volvo c70 (343bhp)
Send a message via MSN to marcus mgf
is it neccesary to disconnect the airbag before removing the cowling to get too the bulbs?
marcus mgf is offline
post #20 of 28 (permalink) Old 31-07-2008, 19:47
Not mandatory but I'd recommend to disconnect your battery and leave it for about 10 - 20 mins to get the systems discharged.
Herbie is offline
instrument panel lights mblakeley MGF and MGTF (Sponsored by MGFnTFBITZ) 20 15-08-2008 17:11
Upgrading the instrument panel Musketeer MG ZT / Rover 75 (Sponsored by Rimmer Bros) 22 05-08-2008 19:56
instrument panel daz.p Others 2 08-12-2004 21:33
45 instrument panel James Riley MG/R Modification & Tuning 1 20-08-2004 18:27
Instrument Panel johnnys149 Others 8 24-07-2002 20:36
