HOWTO - Replacing your aerial mount :) - MG-Rover.org Forums
post #1 of 16 (permalink) Old 07-09-2009, 14:44 Thread Starter
Car: TF 135 Sprint
Send a message via MSN to sniperpenguin Send a message via Skype™ to sniperpenguin
Seeing as I recently had my aerial snapped by chav's , I had to perform the task of replacing the Aerial mount. I though it only fair I do a HOWTO, seeing as it save a little bit of grief for somebody.
First, I sourced a replacement unit from "CAR-MASTS-UK" on ebay - about 12 for the entire assembly
*REMOVAL*
The aerial mount has a top piece with flat edges. this will unscrew (lefty-loosey ) using a pair of pliers and come off, leaving you with 3 pieces
1. unscrewed top piece
2. Black plastic mount (visible on car)
3. Aerial internals
Below is a pic of the old component removed
To remove the interals, you will need to disconnect the coaxial cable, shown here (dont forget to reconnect when done! )
*REPLACEMENT*
Disassemble the new piece in the same way, and clean off any muck / grease around the bodywork. Take the replace ment mount (middle piece) and line up the notches before pressing it in firmly. It looked a little out of alignment to me, but it isnt.
The easiest way I found to re-insert the aerial mount is to hold the bodywork with your right-hand, having the mount between your 3rd / 4th fingers (I've removed the mount to make the pic clearer). Once roughly lined up, manually screw on the top piece (hand-tight is fine).
Once done, reconnect the cable and you are finshed with the replacememt. And all that remains is to fit an Anti-Chav Richmeond aerial supplied by a sympathetic wife!
sniperpenguin is offline
post #2 of 16 (permalink) Old 07-09-2009, 19:21
Banned
Car: MGTF 160 Sprint
Thanks for that Sniper!
Jeff.
mogatrons is offline
post #3 of 16 (permalink) Old 07-09-2009, 19:56
MoonManMike's Avatar
I wonder if anyone makes a stainless steel/chrome base mount for the aerial?
I've not found one yet!
MoonManMike is offline
post #4 of 16 (permalink) Old 07-09-2009, 20:20 Thread Starter
Car: TF 135 Sprint
MGF Centre will turn up with one shortly after a few trips to the scrappy....
Cost? = 80 probably
post #5 of 16 (permalink) Old 07-09-2009, 22:40
Banned
Excellent guide SP!
Quite clever to have an anti-theft one - do you mind me asking how it works?
MG_CHIC is offline
post #6 of 16 (permalink) Old 07-09-2009, 22:42
Originally Posted by MG_CHIC View Post
Excellent guide SP!
Small grub screw methinks! My local Halfords have them in the sale bins for a tenner I think at the moment for some reason!
adamelphick is offline
post #7 of 16 (permalink) Old 07-09-2009, 22:52
Banned
Dammit I just bought a new aerial but I'm quite tempted to get one of these tbh. Gotta pop to Halfords tomorrow so will check for them... thanks for the tip hun!
MG_CHIC is offline
post #8 of 16 (permalink) Old 08-09-2009, 11:20
Car: Toyota Camry Sportivo V6
Thanks for the How-To - always wondered how it came apart!
(now go and clean your boot channels!)
AussieTF160 is offline
post #9 of 16 (permalink) Old 08-09-2009, 12:31
Car: V6 SAAB 93 Vs Prius T4 - Carbon Neutral
Could have done with this a year ago when I dealt with all the rust around the aerial; took me a while to figure it out!
All you've got to do now is find the 'macro' focus on your camera
Tytalus is offline
post #10 of 16 (permalink) Old 08-09-2009, 13:01
Good how to - will give some rep.
...always thought about fitting an electric aerial, wonder if anyone has done it...
Scarlet Fever is offline
post #11 of 16 (permalink) Old 10-09-2015, 13:06
i am unable to remove the top piece of my aerial i have tried pliers and everything been turning it for ages but dont seam to be getting anywhere anyone have any advice for this issue ??
simon.ozzy is offline
post #12 of 16 (permalink) Old 10-09-2015, 13:52
Car: MGF 1.8 in solar red (wifes) I have a jag S type 2.7v6 diesel
It's stuck due to the alloy reacting with the brass stud connection.
Not much you can do except replace the base unit.
Same happens with pound shop alloy valve covers!!
Andythetyreman is offline
post #13 of 16 (permalink) Old 10-09-2015, 13:58
so with a bit of pulling and tugging this happened
so im guessing i need a replacement but.....will a generic one do ?
post #14 of 16 (permalink) Old 10-09-2015, 14:24
so after a bit of mutilation i managed to separate the two parts of the aerial i removed
so looks like ill only need a new interior for the existing base unit
post #15 of 16 (permalink) Old 10-09-2015, 14:35
Car: MG TF 160
Can't beat an old coat hanger
Hunter is offline
post #16 of 16 (permalink) Old 10-09-2015, 14:39
dont think that would look the part tho
ac howto sourfacedsod MG ZS / Rover 45 & 400 5 24-06-2009 13:22
Replacing the aerial mattk Rover 600 2 19-04-2009 11:21
Aerial mount seabass MGF and MGTF (Sponsored by MGFnTFBITZ) 8 23-06-2008 18:08
Rear Screen Replacement HOWTO iaross MGF and MGTF (Sponsored by MGFnTFBITZ) 9 14-09-2007 11:17
Replacing Aerial on MGF? Flyte MGF and MGTF (Sponsored by MGFnTFBITZ) 13 20-06-2006 15:36
