HT leads melted / cant remove spark plug - MG-Rover.org Forums
 18Likes
post #1 of 30 (permalink) Old 14-05-2017, 22:16 Thread Starter
Car: MGF + ZR
Thumbs down HT leads melted / cant remove spark plug
trying to change the spark plugs today, took ages to get the wires off, they had melted them selfs solid down the hole.
finaly got them off but cant get the spark plug socket to sit on?
super_cds is offline
post #2 of 30 (permalink) Old 15-05-2017, 09:49
long reach spark plug socket? it needs to be long reach and minimal diameter, because of where the spark plug hex sits in relation to the head. it could be because the top of the plug is fouling your socket.. or it wont fit in the space?
if its because the hex is fouled with melted plastic... then you need a good torch and look down the plug hole space... to see..
if its because the top of the plug fouls the socket.. you need a different socket...
http://www.mgf.ultimatemg.com/group2...sparkplugs.htm
super_cds likes this.
Incony is offline
post #3 of 30 (permalink) Old 15-05-2017, 10:28 Thread Starter
Car: MGF + ZR
the socket worked ok on the zr a few months back, is the F different?
post #4 of 30 (permalink) Old 15-05-2017, 17:35
Woof Woof
What do you think caused them to melt? Have you had an overheat?
barkingdog is offline
post #5 of 30 (permalink) Old 15-05-2017, 17:56
As said, you need a long reach magnetic socket, like this.
Although you should check that there is nothing still in the wells that will obstruct the socket.
I'm wondering if there is still parts of the cap on the top of the plugs.
post #6 of 30 (permalink) Old 15-05-2017, 20:05 Thread Starter
Car: MGF + ZR
will get a pic when it stops raining, not sure of the history of the car not had it long
that looks the same as the zr with the coil packs built in
this f has a distributor, maybe they changed the size
post #7 of 30 (permalink) Old 15-05-2017, 20:55
no the size has not changed
Incony is offline
post #8 of 30 (permalink) Old 15-05-2017, 21:07
If you've access to a compressor, not the small cigar lighter tyre type, get the airline down the holes to blow out all the crud and then try again. If you haven't access to a compressor, I suggest you go out and buy one, even if you only purchase a 25litre one, you'll soon be thinking why had you never bought one before or sooner
david.c and super_cds like this.
dert is offline
post #9 of 30 (permalink) Old 15-05-2017, 21:34 Thread Starter
Car: MGF + ZR
looked like a melted candle twisting the lead i could hear cracking, thought it may of been the plug breaking but no.
it driped down over the silicone end and melted its self, to everything
post #10 of 30 (permalink) Old 16-05-2017, 12:00
Stuck in the 80's...
Secondary question of course, but what/whose leads were they?
If it were me I would be having a quiet word with the manufacturer or supplier...
IanMc is offline
post #11 of 30 (permalink) Old 16-05-2017, 12:32 Thread Starter
Car: MGF + ZR
got new leads now and they look all silicon soft, no hard plastic to melt
no idea of the make, cheap china crap i guess
post #12 of 30 (permalink) Old 16-05-2017, 13:20 Thread Starter
Car: MGF + ZR
pics
post #13 of 30 (permalink) Old 16-05-2017, 13:21 Thread Starter
Car: MGF + ZR
socket just spinds round and round due to all the melted crap around the out side of the plug
post #14 of 30 (permalink) Old 16-05-2017, 15:35
Long thin cheap screwy and a blow torch. Heat the screwy and melt the plastic scraping it out as you go. May take a while to get enough out but should work. Just keep trying to get the socket on, keep doing this until you do.
the chauffer is offline
post #15 of 30 (permalink) Old 16-05-2017, 16:53 Thread Starter
Car: MGF + ZR
tried running the engine for a while hoping it would soften it a bit but no good
will give the blowtorch a try thanks
post #16 of 30 (permalink) Old 17-05-2017, 16:20
if the plug lead failed inside.. i.e broke internally, the you would get HV sparks inside the lead insulation.. in effect a spark that jumps in two places... at the plug and in the lead, to get to earth...
its going to do that because the lead has very good outer insulation... but the plug is still functioning as it should...
so.. with sparks jumping inside the lead... and they are hot... it will melt, cook, burn..
eventually the car will start to misfire because the burning lead destroys the internal conductor, the spark cant jump the bigger gap.. and cant reach the plug.
of course, the other point of possible bad contact could be the top of the plug itself...
but still the consequence can be the same... a double point jumping HV spark
and anything close to it.. will burn... and if it was you - and you have a better path to earth than the plug... you get a shock...
i cant imagine how you are getting a good connection on the plug, if you cant get a plug spanner in, to take it out, and examine it.. let alone trying to run the engine with it like that.
given that it was running with the engine at full temp, and that point of the head where the plug goes into can reach temperatures close to the exhaust temperature, since it is in the cylinder, then the crap in the plug can still not degrade, but just melt at temps maybe red hot...
a blow torch wont apply its heat in the right place.. because the head itself, is acting as a heat absorber,,
if you can.. you need to be brutal, and if you cant clear a way for the plug spanner to fit, by using time and a fine point chisel to chip away what is fouling the plug spanner placement, then another option might be to adapt a fine cut hole saw... to a tube , that you can turn by hand outside the head... and just keep turning - with pressure until you cut away the melted crap - and free a path .
its not going to be easy to to do any of that... and time and patience is the best way...
i dont think heat is the answer,,, the head acting as a heatsink is going to make that near impossible.
another option might be an industrial electric soldering iron, since its tip can melt solder and is big, ( quarter inch flat tip ) it might be used as a scooping collector, ( it will ruin the tip but might do it ) a bit at a time...
if you have any of the old leads and can see by comparison which bit melted, then see if a very hot bit of steel rod will melt it..
maybe you can just do that.. heat the rod... scoop the crap out... clean the rod, heat the rod again etc...
Incony is offline
post #17 of 30 (permalink) Old 17-05-2017, 16:36 Thread Starter
Car: MGF + ZR
engine has been running fine, and the leads are still good
they are made from silicone with a hard plastic cover.
just the out side hard plastic melted and driped down the hole (you can see the run marks on the side wall) then set hard around the out side of the spark plug covering the gap around the out side.
post #18 of 30 (permalink) Old 17-05-2017, 20:14
long flat bladed screw driver a few hits and should fracture / shatter the plastic , then get either air to blast it out or a piece of garden hose shoved in the end of a hoover should get it out i would also smash the top of the plug to aid in getting the hose down to the plastic you will find after the first piece comes out the rest should come straight out with 1 or 2 hits .
then give the spark plug a few turns with the spark plug socket then hoover the rest out then remove and replace the spark plug and move on to the next one if the rest are the same .
Andy400 is offline
post #19 of 30 (permalink) Old 17-05-2017, 20:20
so if its not the lead or the plug that caused the melt... but the heat of the engine... then i would go hot metal rod route, trying it on the same type of plastic first... you need and easy way of remelting the plastic, instantly.. even if only for a short time... and scoop the melted stuff out..,, clean and do it again.. and again... etc etc..
you might need to shape the end of the rod to help you... a bit of 6mm threaded studding hammered to a tip would do..?
Incony is offline
post #20 of 30 (permalink) Old 17-05-2017, 21:18
Personally, I'd just get a plug socket really hot...as in able to melt plastic hot then push it onto the plug. The heat should melt any plastic around the plug enabling the socket to push down onto the plug
dert is offline
Spark plug leads ... MikeVincent MGF and MGTF (Sponsored by MGFnTFBITZ) 4 03-07-2013 14:57
TI spark plug leads HBOMB Rover 600 2 20-07-2012 13:01
spark plug HT leads spark_olo Other Manufacturer models 5 16-04-2008 16:48
Spark plug leads order julie11 MGF and MGTF (Sponsored by MGFnTFBITZ) 2 05-02-2008 19:50
Stalling - spark plug leads?? ikga33 MG/R Modification & Tuning 4 08-12-2005 08:36
