HT leads melted / cant remove spark plug - Page 2 - MG-Rover.org Forums
 18Likes
post #21 of 30 (permalink) Old 17-05-2017, 23:08
Originally Posted by dert View Post
Personally, I'd just get a plug socket really hot...as in able to melt plastic hot then push it onto the plug. The heat should melt any plastic around the plug enabling the socket to push down onto the plug
unfortunetly i dont think that would work , it would be too cold by the time it got their , and the plastic would have no where to go , you would also brake the plug socket as it isnt going to take the stress when hot to undo it.
super_cds likes this.
Andy400 is offline
post #22 of 30 (permalink) Old 18-05-2017, 07:00
Stuck in the 80's...
As extreme as it seems, I would be giving serious consideration to removing the head to sort out this problem.
I would be concerned about any debris left behind finding its way into the combustion chambers in the future.
I would want to closely inspect each plug cavity after the plastic is considered gone to be happy. My view is that this can only be done with confidence when the plugs are removed without ANY chance of particles ending up in the chambers .
Not what you want to hear I know, but desperate times etc etc
Are there any other related jobs that need doing at the same time - water pump, cam belt etc?
Good luck!
IanMc is online now
post #23 of 30 (permalink) Old 18-05-2017, 09:59
Woof Woof
Can you not just belt a plug socket on to smash the burnt plastic? Then either suck or blow the debris out before completely removing the plug.
barkingdog is online now
post #24 of 30 (permalink) Old 18-05-2017, 12:58
As derts post above. Heat the plug spanner red hot and push it straight down over the plugs.
COLVERT is offline
post #25 of 30 (permalink) Old 18-05-2017, 14:20
Another whacky and potentially very dangerous idea:
Put a flammable liquid down the plug holes and set light to it - hoping to either soften or vapourise the plastic...
Watch your eyebrows!
dert and super_cds like this.
IanMc is online now
post #26 of 30 (permalink) Old 18-05-2017, 17:11
I have to disagree with you here, it is easy to heat up a plug socket next to the head, through the use of a blow torch. With regard to stress in the socket, my old bike ones were just pressed steel tube, they never broke but would bend a tad. the plug sockets either on an extension bar or like CCJ has shown would need to be extremely hot to become stressed. Worst case scenario buy a cheap plug socket which you don't care if it fails.....the other options ?
dert is offline
post #27 of 30 (permalink) Old 18-05-2017, 17:57 Thread Starter
Car: MGF + ZR
super_cds is offline
post #28 of 30 (permalink) Old 18-05-2017, 17:58 Thread Starter
Car: MGF + ZR
thank you all the hot socket did the trick
pics abbove 56k warning
IanMc, barkingdog and Incony like this.
post #29 of 30 (permalink) Old 18-05-2017, 20:02
well done... solution.. end of story..
i think there is something to be learned from this ... faith is often given by mistake...
the faith healer.... is super_cds knowledge now..
dont buy these ht leads, if you have an mgf...
Incony is offline
post #30 of 30 (permalink) Old 18-05-2017, 20:38
Maybe a shortened version of this thread, or this thread linked under "hints and tips", you never know it may helps someone else out in the future
dert is offline
Spark plug leads ... MikeVincent MGF and MGTF (Sponsored by MGFnTFBITZ) 4 03-07-2013 14:57
TI spark plug leads HBOMB Rover 600 2 20-07-2012 13:01
spark plug HT leads spark_olo Other Manufacturer models 5 16-04-2008 16:48
Spark plug leads order julie11 MGF and MGTF (Sponsored by MGFnTFBITZ) 2 05-02-2008 19:50
Stalling - spark plug leads?? ikga33 MG/R Modification & Tuning 4 08-12-2005 08:36
