Intermitent coolant loss - MG-Rover.org Forums
post #1 of 3 (permalink) Old 08-10-2016, 12:28 Thread Starter
Dear all
My 2005 115 TF 1.6 is loosing coolant, but it is only doing so intermitently .
It will be fine for days then I will go out and find the header tank drained and a puddle under the engine. There is frusratingly no pattern to this it only occurs when the car has been stood usually overnight.
I can't see any obvious leak, I have hd this over a pit a checked too. However by the time I have driven it to my mate's garage wher the pit is the leak has stopped and all signs evaporated!
Any ideas???
Jon
jonthevicar is offline
post #2 of 3 (permalink) Old 08-10-2016, 12:44
The list could be quite long,
split in a hose which only shows after standing
underfloor pipes
etc etc
Put a piece of cardboard under the car when you park it up and you should get a better idea of the location of the leak.
hope that helps a little
Clive
Originally Posted by jonthevicar View Post
Dear all
Any ideas???
Jon
Mgwanderer is offline
post #3 of 3 (permalink) Old 08-10-2016, 14:33
As mgw suggests - put some card under and see where the marks are. My money's on the water pump or IMG...
Coolant loss after coolant flush. advice. xxxxxxxxxxxbananaLagan MG ZR / Rover 25, 200 & Streetwise 2 16-07-2014 12:43
hot air loss/slow coolant loss zr10504 MG ZR / Rover 25, 200 & Streetwise 4 24-04-2012 12:30
coolant loss fixed....now oil loss :-( Griffo MGF and MGTF (Sponsored by MGFnTFBITZ) 6 22-12-2010 13:19
V6 Coolant loss dacman MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 11-06-2009 11:48
75 knock and intermitent power loss..ideas? Gary Cork MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 22-07-2006 10:59
